Documentation doesn't match with UI #100041
Eevee & Viewport
Rendering & Cycles
Needs Information from Developers
5 Participants
Reference: blender/blender-manual#100041
Operating system: macOS-10.15.7-x86_64-i386-64bit 64 Bits
Broken: version: 3.3.0 Alpha, branch: master, commit date: 2022-07-14 22:44, hash:
blender/blender@0e9367fc29
In this section of the user manual:
Regions => Vertical/Horizontal Split
There is a piece of text describing the area splitting function:
This is no longer matching with the actual UI display. What you see on the UI is a plus sign icon (+) appear and you will have to drag that plus cursor inside - for vertical split, or down/up for horizontal split.
Please update the documentation to match the UI behaviour
Added subscriber: @hoanguk
Added subscriber: @pablovazquez
Nice catch! Screenshots on this page and many others need to be updated.
Maintaining documentation is a community effort. Would you be up for updating these images? Something similar to what's already there but with the latest UI in 3.3 Beta would be enough I think. Perhaps using a higher resolution scale in the preferences.
You can also drop by #docs to discuss.
Thanks!
I would not mind doing it if I have time. At the moment, I'm translating a huge amount of text to Vietnamese. I choose to ignore ones that no longer matches the UI but other than that I'm translating texts that do, and also reading up on changes as well. In short, I cannot as I have no time left. Thank you for asking.
Info on this page
Status Bar
no longer applied. One has to RIGHT click on the bar to review a popup menu and choose which items to display. Please update.
I need to know which section of the current 3.3 manual still working as designed and documented, so I can continue the translation. Can someone in charge with the Documentation informing us translators please?
Added subscriber: @Blendify
This is a hard question to answer because the manual is not updated chapter by chapter.
You can see a list of changes still pending here: #98243
Added subscriber: @Matthew-Hinson
I think the part about area splitting is in fact still correct. It's just a bit confusing because there two ways of doing it:
For the status bar, the documentation already says to use RMB to choose the information to display, so I'm not sure what's wrong there.
I think the part that created confusion for me is :
I was looking for an indicator line which doesn't appear. Instead, I see the cross icon (+) . Next is the text should mention the fact that one need to drag the mouse "inside" for vertical split, and "up/down" for horizontal split.
The indicator line appears when you use the context menu. That's also what that part of the documentation is about.
The (+) cursor is documented separately on the "Areas" page.
Matthew, you're so correct. I tried the context menu again and it worked exactly the way it is described. I did not see this before. Thank you for commenting and guidance.
Bast Regards,
Closing this task as resolved as it appears to have been a misunderstanding.
