EEVEE AOV blank if not attached or too distantly connected to material output node #100278
Reference: blender/blender#100278
Graphics card: NVIDIA GeForce RTX 2070 SUPER/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 516.59
Broken: version: 3.2.1, branch: master, commit date: 2022-07-05 15:44, hash:
a2d59b2dac
Worked: 3.1
Behavior changed after
80859a6cb2
In eevee, the AOV output node doesn't work unless it is connected to the material output node.
1 open attached blend file eevee_AOV_bug.blend
2 turn on viewport shading
3 you will not see the custom AOV in the viewport or if you render
4 connect the diffuse shader output to the material output
5 you will notice the AOV becomes visible in the viewport and renders
You may be think the simple work-around is just to make sure the AOV output is in the same node tree as the material output, but I have also noticed, if the AOV output is too distantly connected to the material output, then it won't output anything too.
Added subscriber: @TroyAC
Upon further test, I additionally realize the custom AOVs don't work in eevee if the material they are a part of is set to a blend mode other than opaque. I suppose this makes sense with the know limitation of the blender compositor not working well with transparents and semitransparents.
Added subscriber: @fclem
Thanks for the report. I'm able to recreate this issue from scratch. Behavior changed after
80859a6cb2
@fclem, can you check this report?
Added subscriber: @Jeroen-Bakker
AOV should work for opaque, hashed and clipped blend mode. Only alpha hash isn't supported. If that is not the case this should be added in its own report.
I would say this is expected behavior. The AOVs are only written if the Material has a surface shader. The lack of a surface shader is used to detect volume only materials so we cannot create a dummy shader if the material has any AOV output. Cycles behaves the same way.
As for the blend modes support, I checked and only the
Alpha Blend
isn't supported.
