Blender 3.2.0 Crashes when selecting Hair Particle #100382
Closed
opened 2022-08-13 03:06:51 +02:00 by Mana Media · 2 comments
Operating system:
Graphics card:
Broken: (example: 2.80, edbf15d3c0, master, 2018-11-28, as found on the splash screen)
When applying a hair particle to any mesh, it crashes the program
Click on Cube
Select Particles from the Right Tabs
Hit the Plus Sign to Add Particle
Change from Emitter to Hair and the system immediately crashes
Translated Report (Full Report Below)
Process:               Blender [32670]
Path:                  /Applications/Blender.app/Contents/MacOS/Blender
Identifier:            org.blenderfoundation.blender
Version:               3.2.0 (3.2.0 2022-06-08)
Code Type:             X86-64 (Native)
Parent Process:        launchd [1]
User ID:               501
Date/Time:             2022-08-13 13:00:09.5046 +1200
OS Version:            macOS 12.4 (21F79)
Report Version:        12
Anonymous UUID:        05E90402-A0D0-888E-9B78-3973D674DB16
Time Awake Since Boot: 410000 seconds
System Integrity Protection: enabled
Crashed Thread:        0  Dispatch queue: com.apple.main-thread
Exception Type:        EXC_ARITHMETIC (SIGFPE)
Exception Codes:       0x0000000000000001, 0x0000000000000000
Exception Note:        EXC_CORPSE_NOTIFY
Termination Reason:    Namespace SIGNAL, Code 8 Floating point exception: 8
Terminating Process:   exc handler [32670]
Thread 0 Crashed::  Dispatch queue: com.apple.main-thread
0   AMDRadeonX4000GLDriver        	       0x123743c60 glrUpdateTexture + 1199
1   libGPUSupportMercury.dylib    	    0x7ff9151edae5 gpusLoadCurrentTextures + 638
2   AMDRadeonX4000GLDriver        	       0x123713764 gldUpdateDispatch + 243
3   GLEngine                      	    0x7ffa1de13529 gleDoDrawDispatchCoreGL3 + 673
4   GLEngine                      	    0x7ffa1dde6043 glDrawElementsInstancedBaseVertex_ACC_GL3Exec + 290
5   libGL.dylib                   	    0x7ffa1dd1b3cf glDrawElementsInstancedBaseVertex + 45
6   Blender                       	       0x1072de905 draw_call_single_do + 453
7   Blender                       	       0x1072dde86 drw_draw_pass_ex + 1766
8   Blender                       	       0x1072dd78f DRW_draw_pass + 31
9   Blender                       	       0x10731797a workbench_draw_sample + 330
10  Blender                       	       0x107317b5e workbench_draw_scene + 94
11  Blender                       	       0x1072d4619 drw_engines_draw_scene + 185
12  Blender                       	       0x1072d33f1 DRW_draw_render_loop_ex + 1457
13  Blender                       	       0x107f2e7da view3d_main_region_draw + 138
14  Blender                       	       0x10767a101 ED_region_do_draw + 337
15  Blender                       	       0x1071545fd wm_draw_update + 1773
16  Blender                       	       0x107151860 WM_main + 48
17  Blender                       	       0x106a1230e main + 878
18  dyld                          	       0x127e5051e start + 462
Thread 1:
0   libsystem_kernel.dylib        	    0x7ff804cec9b6 semaphore_wait_trap + 10
1   libdispatch.dylib             	    0x7ff804b727ce _dispatch_sema4_wait + 16
2   libdispatch.dylib             	    0x7ff804b72c9d _dispatch_semaphore_wait_slow + 98
3   Blender                       	       0x111e2a7b2 IlmThread_3_1::(anonymous namespace)::DefaultWorkerThread::run() + 50
4   Blender                       	       0x111e292ae void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_3_1::Thread::*)(), IlmThread_3_1::Thread*> >(void*) + 62
5   libsystem_pthread.dylib       	    0x7ff804d294e1 _pthread_start + 125
6   libsystem_pthread.dylib       	    0x7ff804d24f6b thread_start + 15
Thread 2:
Thread 3:
Thread 4:
Thread 5:: AMCP Logging Spool
1   caulk                         	    0x7ff80d8212e6 caulk::mach::semaphore::wait_or_error() + 16
2   caulk                         	    0x7ff80d809148 caulk::concurrent::details::worker_thread::run() + 36
3   caulk                         	    0x7ff80d808e0c void* caulk::thread_proxy<std::__1::tuple<caulk::thread::attributes, void (caulk::concurrent::details::worker_thread::*)(), std::__1::tuple<caulk::concurrent::details::worker_thread*> > >(void*) + 41
4   libsystem_pthread.dylib       	    0x7ff804d294e1 _pthread_start + 125
5   libsystem_pthread.dylib       	    0x7ff804d24f6b thread_start + 15
Thread 6:
0   libsystem_pthread.dylib       	    0x7ff804d24f48 start_wqthread + 0
Thread 7:: com.apple.audio.IOThread.client
0   libsystem_kernel.dylib        	    0x7ff804cec97a mach_msg_trap + 10
1   libsystem_kernel.dylib        	    0x7ff804cecce8 mach_msg + 56
2   CoreAudio                     	    0x7ff806974c87 HALB_MachPort::SendSimpleMessageWithSimpleReply(unsigned int, unsigned int, int, int&, bool, unsigned int) + 111
3   CoreAudio                     	    0x7ff8067ffd6b HALC_ProxyIOContext::IOWorkLoop() + 3909
4   CoreAudio                     	    0x7ff8067fe85d invocation function for block in HALC_ProxyIOContext::HALC_ProxyIOContext(unsigned int, unsigned int) + 63
5   CoreAudio                     	    0x7ff8069ca696 HALB_IOThread::Entry(void*) + 72
6   libsystem_pthread.dylib       	    0x7ff804d294e1 _pthread_start + 125
7   libsystem_pthread.dylib       	    0x7ff804d24f6b thread_start + 15
Thread 8:
0   libsystem_kernel.dylib        	    0x7ff804cef3ea __psynch_cvwait + 10
1   libsystem_pthread.dylib       	    0x7ff804d29a6f _pthread_cond_wait + 1249
2   libopenblas64_.0.dylib        	       0x13601249f blas_thread_server + 207
3   libsystem_pthread.dylib       	    0x7ff804d294e1 _pthread_start + 125
4   libsystem_pthread.dylib       	    0x7ff804d24f6b thread_start + 15
Thread 9:
Thread 10:
Thread 11:
1   Blender                       	       0x107147d98 tbb::internal::rml::private_worker::run() + 104
2   Blender                       	       0x107147d29 tbb::internal::rml::private_worker::thread_routine(void*) + 9
Thread 12:
Thread 13:
Thread 14:: com.apple.NSEventThread
2   CoreFoundation                	    0x7ff804df038d __CFRunLoopServiceMachPort + 319
3   CoreFoundation                	    0x7ff804deea18 __CFRunLoopRun + 1276
4   CoreFoundation                	    0x7ff804dede5c CFRunLoopRunSpecific + 562
5   AppKit                        	    0x7ff80799ac1e _NSEventThread + 132
Thread 15:
Thread 16:
Thread 17:
Thread 0 crashed with X86 Thread State (64-bit):
  rax: 0x0000000000000040  rbx: 0x0000600001e21720  rcx: 0x0000000000000000  rdx: 0x0000000000000000
  rdi: 0x00007f9e6b86da00  rsi: 0x0000000000000000  rbp: 0x00007ff7b9673c20  rsp: 0x00007ff7b9673bf0
   r8: 0x0000000000000000   r9: 0x000000000000008f  r10: 0x00007f9e6b86da48  r11: 0x0000000000000010
  r12: 0x000000000000000f  r13: 0x00007f9e6fae5ba0  r14: 0x00007f9e6b86da00  r15: 0x0000600000de7b60
  rip: 0x0000000123743c60  rfl: 0x0000000000010246  cr2: 0x000000012c81f000
Logical CPU:     0
Error Code:      0x00000000
Trap Number:     0
Thread 0 instruction stream:
  00 00 09 fa c1 e6 13 09-d6 09 de 09 ce 31 c0 41  .............1.A
  89 45 48 45 89 45 4c 41-89 45 50 41 89 75 54 0f  .EHE.ELA.EPA.uT.
  57 c0 41 0f 11 45 58 4d-85 ff 74 5c 49 8b 47 10  W.A..EXM..t\I.G.
  48 85 c0 74 53 48 8b 18-48 85 db 74 4b 66 41 83  H..tSH..H..tKfA.
  be 9c 01 00 00 00 49 8b-07 48 8b 40 10 41 8b 4d  ......I..H.@.A.M
  4c 78 10 89 ce c1 ee 10-81 e6 ff 3f 00 00 31 d2  Lx.........?..1.
 [48]f7 f6 41 89 45 50 49-8b 47 10 48 8b 40 20 41  H..A.EPI.G.H.@ A	<==
  89 45 48 48 c1 e8 20 0f-b7 c0 81 e1 00 00 ff ff  .EHH.. .........
  09 c1 41 89 4d 4c eb 0a-41 c7 45 50 00 00 00 00  ..A.ML..A.EP....
  31 db 49 8b 7d 18 48 39-fb 74 3b 48 85 ff 74 15  1.I.}.H9.t;H..t.
  4d 8d 7d 18 e8 1f 39 09-00 0f 57 c0 41 0f 11 47  M.}...9...W.A..G
  10 41 0f 11 07 48 85 db-74 1c 48 89 df e8 0c 39  .A...H..t.H....9
Binary Images:
       0x123711000 -        0x123828fff com.apple.AMDRadeonX4000GLDriver (4.8.54) <9a48f06c-82b0-3bdd-8f5d-69d94098e1b0> /System/Library/Extensions/AMDRadeonX4000GLDriver.bundle/Contents/MacOS/AMDRadeonX4000GLDriver
    0x7ff9151e6000 -     0x7ff9151f0fff libGPUSupportMercury.dylib (*) <5fcec882-890c-3c7a-a3dd-6e82f716199a> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupportMercury.dylib
    0x7ffa1dd20000 -     0x7ffa1dea9fff GLEngine (*) <a72561b7-7972-305a-8f85-0366b47b7a8f> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLEngine.bundle/GLEngine
    0x7ffa1dd15000 -     0x7ffa1dd1ffff libGL.dylib (*) <7a5491db-1b13-37bf-a174-112d53bf9031> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
       0x10688b000 -        0x116a72fff org.blenderfoundation.blender (3.2.0) <c389d82e-9893-3b04-bdfb-63e2e302564e> /Applications/Blender.app/Contents/MacOS/Blender
       0x127e4b000 -        0x127eb6fff dyld (*) <b70ce1ec-b902-3852-8268-05de00bfa8d5> /usr/lib/dyld
    0x7ff804ceb000 -     0x7ff804d22fff libsystem_kernel.dylib (*) <61711d11-e776-3bc3-b9a2-6f9f37cb8499> /usr/lib/system/libsystem_kernel.dylib
    0x7ff804b6f000 -     0x7ff804bb5fff libdispatch.dylib (*) <534511b9-b3b0-33a7-b1ea-402595d28bda> /usr/lib/system/libdispatch.dylib
    0x7ff804d23000 -     0x7ff804d2efff libsystem_pthread.dylib (*) <bc574849-1aae-31e7-b350-916dda999d97> /usr/lib/system/libsystem_pthread.dylib
    0x7ff80d807000 -     0x7ff80d828fff com.apple.audio.caulk (1.0) <42fecc51-73d2-3b5c-b109-208f4cb4c3cd> /System/Library/PrivateFrameworks/caulk.framework/Versions/A/caulk
    0x7ff806646000 -     0x7ff806d7afff com.apple.audio.CoreAudio (5.0) <1621fd80-991f-3b5f-97f3-dbbb21bdeba3> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
       0x135ce1000 -        0x13996cfff libopenblas64_.0.dylib (*) <10431d8f-5e3b-3bbc-abd5-81f6a73a5269> /Applications/Blender.app/Contents/Resources/3.2/python/lib/python3.10/site-packages/numpy/.dylibs/libopenblas64_.0.dylib
    0x7ff804d70000 -     0x7ff805272fff com.apple.CoreFoundation (6.9) <f8e45ef9-9fd2-3331-bb1b-703d5dacdaf1> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
    0x7ff8077ee000 -     0x7ff80867cfff com.apple.AppKit (6.9) <832ad371-d3b8-3061-b4e2-1c4e0cffce0b> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
External Modification Summary:
  Calls made by other processes targeting this process:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
  Calls made by this process:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
  Calls made by all processes on this machine:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=1.3G resident=0K(0%) swapped_out_or_unallocated=1.3G(100%)
Writable regions: Total=867.9M written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=867.9M(100%)
                                VIRTUAL   REGION
REGION TYPE                        SIZE    COUNT (non-coalesced)
Accelerate framework               384K        3
Activity Tracing                   256K        1
CG backing stores                 3840K        4
CG image                            84K        5
ColorSync                          220K       25
CoreAnimation                      112K        8
CoreGraphics                        12K        2
CoreUI image data                 1040K        7
Foundation                          16K        1
Kernel Alloc Once                    8K        1
MALLOC                           266.3M      198
MALLOC guard page                   32K        8
MALLOC_LARGE (reserved)            256K        1         reserved VM address space (unallocated)
MALLOC_NANO (reserved)           384.0M        1         reserved VM address space (unallocated)
ObjC additional data                15K        1
OpenGL GLSL                        256K        3
STACK GUARD                         72K       18
Stack                             20.1M       18
VM_ALLOCATE                      147.9M      271
VM_ALLOCATE (reserved)            32.0M        1         reserved VM address space (unallocated)
__CTF                               756        1
__DATA                            59.5M      415
__DATA_CONST                      15.3M      215
__DATA_DIRTY                       675K      119
__FONT_DATA                          4K        1
__GLSLBUILTINS                    5176K        1
__LINKEDIT                       727.5M       57
__TEXT                           618.5M      422
__UNICODE                          592K        1
dyld private memory               1152K        3
mapped file                      167.3M       24
shared memory                      768K       15
TOTAL                              2.4G     1851
TOTAL, minus reserved VM space     2.0G     1851
Full Report
{"app_name":"Blender","timestamp":"2022-08-13 13:00:10.00 +1200","app_version":"3.2.0","slice_uuid":"c389d82e-9893-3b04-bdfb-63e2e302564e","build_version":"3.2.0 2022-06-08","platform":1,"bundleID":"org.blenderfoundation.blender","share_with_app_devs":0,"is_first_party":0,"bug_type":"309","os_version":"macOS 12.4 (21F79)","incident_id":"80D07A91-2314-442C-92E9-433BFE00CE47","name":"Blender"}
  "uptime" : 410000,
  "procLaunch" : "2022-08-13 12:58:35.3522 +1200",
  "procRole" : "Foreground",
  "version" : 2,
  "userID" : 501,
  "deployVersion" : 210,
  "modelCode" : "iMac17,1",
  "procStartAbsTime" : 415810803494807,
  "coalitionID" : 15377,
  "osVersion" : {
    "train" : "macOS 12.4",
    "build" : "21F79",
    "releaseType" : "User"
  "captureTime" : "2022-08-13 13:00:09.5046 +1200",
  "incident" : "80D07A91-2314-442C-92E9-433BFE00CE47",
  "bug_type" : "309",
  "pid" : 32670,
  "procExitAbsTime" : 415904938136089,
  "cpuType" : "X86-64",
  "procName" : "Blender",
  "procPath" : "\/Applications\/Blender.app\/Contents\/MacOS\/Blender",
  "bundleInfo" : {"CFBundleShortVersionString":"3.2.0","CFBundleVersion":"3.2.0 2022-06-08","CFBundleIdentifier":"org.blenderfoundation.blender"},
  "storeInfo" : {"deviceIdentifierForVendor":"6B227A37-ADEF-5DBD-B6F1-7E3F7DB3591E","thirdParty":true},
  "parentProc" : "launchd",
  "parentPid" : 1,
  "coalitionName" : "org.blenderfoundation.blender",
  "crashReporterKey" : "05E90402-A0D0-888E-9B78-3973D674DB16",
  "sip" : "enabled",
  "isCorpse" : 1,
  "exception" : {"codes":"0x0000000000000001, 0x0000000000000000","rawCodes":[1,0],"type":"EXC_ARITHMETIC","signal":"SIGFPE"},
  "termination" : {"flags":0,"code":8,"namespace":"SIGNAL","indicator":"Floating point exception: 8","byProc":"exc handler","byPid":32670},
  "extMods" : {"caller":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"system":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"targeted":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"warnings":0},
  "faultingThread" : 0,
  "threads" : [{"triggered":true,"id":4772558,"instructionState":{"instructionStream":{"bytes":[0,0,9,250,193,230,19,9,214,9,222,9,206,49,192,65,137,69,72,69,137,69,76,65,137,69,80,65,137,117,84,15,87,192,65,15,17,69,88,77,133,255,116,92,73,139,71,16,72,133,192,116,83,72,139,24,72,133,219,116,75,102,65,131,190,156,1,0,0,0,73,139,7,72,139,64,16,65,139,77,76,120,16,137,206,193,238,16,129,230,255,63,0,0,49,210,72,247,246,65,137,69,80,73,139,71,16,72,139,64,32,65,137,69,72,72,193,232,32,15,183,192,129,225,0,0,255,255,9,193,65,137,77,76,235,10,65,199,69,80,0,0,0,0,49,219,73,139,125,24,72,57,251,116,59,72,133,255,116,21,77,141,125,24,232,31,57,9,0,15,87,192,65,15,17,71,16,65,15,17,7,72,133,219,116,28,72,137,223,232,12,57],"offset":96}},"threadState":{"r13":{"value":140318455258016},"rax":{"value":64},"rflags":{"value":66118},"cpu":{"value":0},"r14":{"value":140318385560064},"rsi":{"value":0},"r8":{"value":0},"cr2":{"value":5041680384},"rdx":{"value":0},"r10":{"value":140318385560136},"r9":{"value":143},"r15":{"value":105553130847072},"rbx":{"value":105553147860768},"trap":{"value":0},"err":{"value":0},"r11":{"value":16},"rip":{"value":4889787488,"matchesCrashFrame":1},"rbp":{"value":140701944200224},"rsp":{"value":140701944200176},"r12":{"value":15},"rcx":{"value":0},"flavor":"x86_THREAD_STATE","rdi":{"value":140318385560064}},"queue":"com.apple.main-thread","frames":[{"imageOffset":207968,"symbol":"glrUpdateTexture","symbolLocation":1199,"imageIndex":0},{"imageOffset":31461,"symbol":"gpusLoadCurrentTextures","symbolLocation":638,"imageIndex":1},{"imageOffset":10084,"symbol":"gldUpdateDispatch","symbolLocation":243,"imageIndex":0},{"imageOffset":996649,"symbol":"gleDoDrawDispatchCoreGL3","symbolLocation":673,"imageIndex":2},{"imageOffset":811075,"symbol":"glDrawElementsInstancedBaseVertex_ACC_GL3Exec","symbolLocation":290,"imageIndex":2},{"imageOffset":25551,"symbol":"glDrawElementsInstancedBaseVertex","symbolLocation":45,"imageIndex":3},{"imageOffset":10828037,"symbol":"draw_call_single_do","symbolLocation":453,"imageIndex":4},{"imageOffset":10825350,"symbol":"drw_draw_pass_ex","symbolLocation":1766,"imageIndex":4},{"imageOffset":10823567,"symbol":"DRW_draw_pass","symbolLocation":31,"imageIndex":4},{"imageOffset":11061626,"symbol":"workbench_draw_sample","symbolLocation":330,"imageIndex":4},{"imageOffset":11062110,"symbol":"workbench_draw_scene","symbolLocation":94,"imageIndex":4},{"imageOffset":10786329,"symbol":"drw_engines_draw_scene","symbolLocation":185,"imageIndex":4},{"imageOffset":10781681,"symbol":"DRW_draw_render_loop_ex","symbolLocation":1457,"imageIndex":4},{"imageOffset":23738330,"symbol":"view3d_main_region_draw","symbolLocation":138,"imageIndex":4},{"imageOffset":14610689,"symbol":"ED_region_do_draw","symbolLocation":337,"imageIndex":4},{"imageOffset":9213437,"symbol":"wm_draw_update","symbolLocation":1773,"imageIndex":4},{"imageOffset":9201760,"symbol":"WM_main","symbolLocation":48,"imageIndex":4},{"imageOffset":1602318,"symbol":"main","symbolLocation":878,"imageIndex":4},{"imageOffset":21790,"symbol":"start","symbolLocation":462,"imageIndex":5}]},{"id":4772613,"frames":[{"imageOffset":6582,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":6},{"imageOffset":14286,"symbol":"_dispatch_sema4_wait","symbolLocation":16,"imageIndex":7},{"imageOffset":15517,"symbol":"_dispatch_semaphore_wait_slow","symbolLocation":98,"imageIndex":7},{"imageOffset":190445490,"symbol":"IlmThread_3_1::(anonymous namespace)::DefaultWorkerThread::run()","symbolLocation":50,"imageIndex":4},{"imageOffset":190440110,"symbol":"void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_3_1::Thread::*)(), IlmThread_3_1::Thread*> >(void*)","symbolLocation":62,"imageIndex":4},{"imageOffset":25825,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8043,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":4772614,"frames":[{"imageOffset":6582,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":6},{"imageOffset":14286,"symbol":"_dispatch_sema4_wait","symbolLocation":16,"imageIndex":7},{"imageOffset":15517,"symbol":"_dispatch_semaphore_wait_slow","symbolLocation":98,"imageIndex":7},{"imageOffset":190445490,"symbol":"IlmThread_3_1::(anonymous namespace)::DefaultWorkerThread::run()","symbolLocation":50,"imageIndex":4},{"imageOffset":190440110,"symbol":"void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_3_1::Thread::*)(), IlmThread_3_1::Thread*> >(void*)","symbolLocation":62,"imageIndex":4},{"imageOffset":25825,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8043,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":4772615,"frames":[{"imageOffset":6582,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":6},{"imageOffset":14286,"symbol":"_dispatch_sema4_wait","symbolLocation":16,"imageIndex":7},{"imageOffset":15517,"symbol":"_dispatch_semaphore_wait_slow","symbolLocation":98,"imageIndex":7},{"imageOffset":190445490,"symbol":"IlmThread_3_1::(anonymous namespace)::DefaultWorkerThread::run()","symbolLocation":50,"imageIndex":4},{"imageOffset":190440110,"symbol":"void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_3_1::Thread::*)(), IlmThread_3_1::Thread*> >(void*)","symbolLocation":62,"imageIndex":4},{"imageOffset":25825,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8043,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":4772616,"frames":[{"imageOffset":6582,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":6},{"imageOffset":14286,"symbol":"_dispatch_sema4_wait","symbolLocation":16,"imageIndex":7},{"imageOffset":15517,"symbol":"_dispatch_semaphore_wait_slow","symbolLocation":98,"imageIndex":7},{"imageOffset":190445490,"symbol":"IlmThread_3_1::(anonymous namespace)::DefaultWorkerThread::run()","symbolLocation":50,"imageIndex":4},{"imageOffset":190440110,"symbol":"void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_3_1::Thread::*)(), IlmThread_3_1::Thread*> >(void*)","symbolLocation":62,"imageIndex":4},{"imageOffset":25825,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8043,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":4772619,"name":"AMCP Logging Spool","frames":[{"imageOffset":6582,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":6},{"imageOffset":107238,"symbol":"caulk::mach::semaphore::wait_or_error()","symbolLocation":16,"imageIndex":9},{"imageOffset":8520,"symbol":"caulk::concurrent::details::worker_thread::run()","symbolLocation":36,"imageIndex":9},{"imageOffset":7692,"symbol":"void* caulk::thread_proxy<std::__1::tuple<caulk::thread::attributes, void (caulk::concurrent::details::worker_thread::*)(), std::__1::tuple<caulk::concurrent::details::worker_thread*> > >(void*)","symbolLocation":41,"imageIndex":9},{"imageOffset":25825,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8043,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":4772655,"frames":[{"imageOffset":8008,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":8}]},{"id":4772673,"name":"com.apple.audio.IOThread.client","frames":[{"imageOffset":6522,"symbol":"mach_msg_trap","symbolLocation":10,"imageIndex":6},{"imageOffset":7400,"symbol":"mach_msg","symbolLocation":56,"imageIndex":6},{"imageOffset":3337351,"symbol":"HALB_MachPort::SendSimpleMessageWithSimpleReply(unsigned int, unsigned int, int, int&, bool, unsigned int)","symbolLocation":111,"imageIndex":10},{"imageOffset":1809771,"symbol":"HALC_ProxyIOContext::IOWorkLoop()","symbolLocation":3909,"imageIndex":10},{"imageOffset":1804381,"symbol":"invocation function for block in HALC_ProxyIOContext::HALC_ProxyIOContext(unsigned int, unsigned int)","symbolLocation":63,"imageIndex":10},{"imageOffset":3688086,"symbol":"HALB_IOThread::Entry(void*)","symbolLocation":72,"imageIndex":10},{"imageOffset":25825,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8043,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":4772694,"frames":[{"imageOffset":17386,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":6},{"imageOffset":27247,"symbol":"_pthread_cond_wait","symbolLocation":1249,"imageIndex":8},{"imageOffset":3347615,"symbol":"blas_thread_server","symbolLocation":207,"imageIndex":11},{"imageOffset":25825,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8043,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":4772695,"frames":[{"imageOffset":17386,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":6},{"imageOffset":27247,"symbol":"_pthread_cond_wait","symbolLocation":1249,"imageIndex":8},{"imageOffset":3347615,"symbol":"blas_thread_server","symbolLocation":207,"imageIndex":11},{"imageOffset":25825,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8043,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":4772696,"frames":[{"imageOffset":17386,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":6},{"imageOffset":27247,"symbol":"_pthread_cond_wait","symbolLocation":1249,"imageIndex":8},{"imageOffset":3347615,"symbol":"blas_thread_server","symbolLocation":207,"imageIndex":11},{"imageOffset":25825,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8043,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":4772709,"frames":[{"imageOffset":6582,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":6},{"imageOffset":9162136,"symbol":"tbb::internal::rml::private_worker::run()","symbolLocation":104,"imageIndex":4},{"imageOffset":9162025,"symbol":"tbb::internal::rml::private_worker::thread_routine(void*)","symbolLocation":9,"imageIndex":4},{"imageOffset":25825,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8043,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":4772710,"frames":[{"imageOffset":6582,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":6},{"imageOffset":9162136,"symbol":"tbb::internal::rml::private_worker::run()","symbolLocation":104,"imageIndex":4},{"imageOffset":9162025,"symbol":"tbb::internal::rml::private_worker::thread_routine(void*)","symbolLocation":9,"imageIndex":4},{"imageOffset":25825,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8043,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":4772711,"frames":[{"imageOffset":6582,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":6},{"imageOffset":9162136,"symbol":"tbb::internal::rml::private_worker::run()","symbolLocation":104,"imageIndex":4},{"imageOffset":9162025,"symbol":"tbb::internal::rml::private_worker::thread_routine(void*)","symbolLocation":9,"imageIndex":4},{"imageOffset":25825,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8043,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":4772740,"name":"com.apple.NSEventThread","frames":[{"imageOffset":6522,"symbol":"mach_msg_trap","symbolLocation":10,"imageIndex":6},{"imageOffset":7400,"symbol":"mach_msg","symbolLocation":56,"imageIndex":6},{"imageOffset":525197,"symbol":"__CFRunLoopServiceMachPort","symbolLocation":319,"imageIndex":12},{"imageOffset":518680,"symbol":"__CFRunLoopRun","symbolLocation":1276,"imageIndex":12},{"imageOffset":515676,"symbol":"CFRunLoopRunSpecific","symbolLocation":562,"imageIndex":12},{"imageOffset":1756190,"symbol":"_NSEventThread","symbolLocation":132,"imageIndex":13},{"imageOffset":25825,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8043,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":4773578,"frames":[{"imageOffset":8008,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":8}]},{"id":4773586,"frames":[{"imageOffset":8008,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":8}]},{"id":4773587,"frames":[{"imageOffset":8008,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":8}]}],
  "usedImages" : [
    "source" : "P",
    "arch" : "x86_64",
    "base" : 4889579520,
    "CFBundleShortVersionString" : "4.8.54",
    "CFBundleIdentifier" : "com.apple.AMDRadeonX4000GLDriver",
    "size" : 1146880,
    "uuid" : "9a48f06c-82b0-3bdd-8f5d-69d94098e1b0",
    "path" : "\/System\/Library\/Extensions\/AMDRadeonX4000GLDriver.bundle\/Contents\/MacOS\/AMDRadeonX4000GLDriver",
    "name" : "AMDRadeonX4000GLDriver",
    "CFBundleVersion" : "4.0.8"
    "source" : "P",
    "arch" : "x86_64",
    "base" : 140707777896448,
    "size" : 45056,
    "uuid" : "5fcec882-890c-3c7a-a3dd-6e82f716199a",
    "path" : "\/System\/Library\/PrivateFrameworks\/GPUSupport.framework\/Versions\/A\/Libraries\/libGPUSupportMercury.dylib",
    "name" : "libGPUSupportMercury.dylib"
    "source" : "P",
    "arch" : "x86_64",
    "base" : 140712218853376,
    "size" : 1613824,
    "uuid" : "a72561b7-7972-305a-8f85-0366b47b7a8f",
    "path" : "\/System\/Library\/Frameworks\/OpenGL.framework\/Versions\/A\/Resources\/GLEngine.bundle\/GLEngine",
    "name" : "GLEngine"
    "source" : "P",
    "arch" : "x86_64",
    "base" : 140712218808320,
    "size" : 45056,
    "uuid" : "7a5491db-1b13-37bf-a174-112d53bf9031",
    "path" : "\/System\/Library\/Frameworks\/OpenGL.framework\/Versions\/A\/Libraries\/libGL.dylib",
    "name" : "libGL.dylib"
    "source" : "P",
    "arch" : "x86_64",
    "base" : 4404588544,
    "CFBundleShortVersionString" : "3.2.0",
    "CFBundleIdentifier" : "org.blenderfoundation.blender",
    "size" : 270434304,
    "uuid" : "c389d82e-9893-3b04-bdfb-63e2e302564e",
    "path" : "\/Applications\/Blender.app\/Contents\/MacOS\/Blender",
    "name" : "Blender",
    "CFBundleVersion" : "3.2.0 2022-06-08"
    "source" : "P",
    "arch" : "x86_64",
    "base" : 4964265984,
    "size" : 442368,
    "uuid" : "b70ce1ec-b902-3852-8268-05de00bfa8d5",
    "path" : "\/usr\/lib\/dyld",
    "name" : "dyld"
    "source" : "P",
    "arch" : "x86_64",
    "base" : 140703209271296,
    "size" : 229376,
    "uuid" : "61711d11-e776-3bc3-b9a2-6f9f37cb8499",
    "path" : "\/usr\/lib\/system\/libsystem_kernel.dylib",
    "name" : "libsystem_kernel.dylib"
    "source" : "P",
    "arch" : "x86_64",
    "base" : 140703207714816,
    "size" : 290816,
    "uuid" : "534511b9-b3b0-33a7-b1ea-402595d28bda",
    "path" : "\/usr\/lib\/system\/libdispatch.dylib",
    "name" : "libdispatch.dylib"
    "source" : "P",
    "arch" : "x86_64",
    "base" : 140703209500672,
    "size" : 49152,
    "uuid" : "bc574849-1aae-31e7-b350-916dda999d97",
    "path" : "\/usr\/lib\/system\/libsystem_pthread.dylib",
    "name" : "libsystem_pthread.dylib"
    "source" : "P",
    "arch" : "x86_64",
    "base" : 140703355138048,
    "CFBundleShortVersionString" : "1.0",
    "CFBundleIdentifier" : "com.apple.audio.caulk",
    "size" : 139264,
    "uuid" : "42fecc51-73d2-3b5c-b109-208f4cb4c3cd",
    "path" : "\/System\/Library\/PrivateFrameworks\/caulk.framework\/Versions\/A\/caulk",
    "name" : "caulk"
    "source" : "P",
    "arch" : "x86_64",
    "base" : 140703235858432,
    "CFBundleShortVersionString" : "5.0",
    "CFBundleIdentifier" : "com.apple.audio.CoreAudio",
    "size" : 7557120,
    "uuid" : "1621fd80-991f-3b5f-97f3-dbbb21bdeba3",
    "path" : "\/System\/Library\/Frameworks\/CoreAudio.framework\/Versions\/A\/CoreAudio",
    "name" : "CoreAudio",
    "CFBundleVersion" : "5.0"
    "source" : "P",
    "arch" : "x86_64",
    "base" : 5197664256,
    "size" : 63488000,
    "uuid" : "10431d8f-5e3b-3bbc-abd5-81f6a73a5269",
    "path" : "\/Applications\/Blender.app\/Contents\/Resources\/3.2\/python\/lib\/python3.10\/site-packages\/numpy\/.dylibs\/libopenblas64_.0.dylib",
    "name" : "libopenblas64_.0.dylib"
    "source" : "P",
    "arch" : "x86_64h",
    "base" : 140703209816064,
    "CFBundleShortVersionString" : "6.9",
    "CFBundleIdentifier" : "com.apple.CoreFoundation",
    "size" : 5255168,
    "uuid" : "f8e45ef9-9fd2-3331-bb1b-703d5dacdaf1",
    "path" : "\/System\/Library\/Frameworks\/CoreFoundation.framework\/Versions\/A\/CoreFoundation",
    "name" : "CoreFoundation",
    "CFBundleVersion" : "1863"
    "source" : "P",
    "arch" : "x86_64",
    "base" : 140703254372352,
    "CFBundleIdentifier" : "com.apple.AppKit",
    "size" : 15265792,
    "uuid" : "832ad371-d3b8-3061-b4e2-1c4e0cffce0b",
    "path" : "\/System\/Library\/Frameworks\/AppKit.framework\/Versions\/C\/AppKit",
    "name" : "AppKit",
    "CFBundleVersion" : "2113.50.132"
  "sharedCache" : {
  "base" : 140703206244352,
  "size" : 15220686848,
  "uuid" : "398acfb4-57f6-31e0-bc82-e9959e5c92ce"
  "vmSummary" : "ReadOnly portion of Libraries: Total=1.3G resident=0K(0%) swapped_out_or_unallocated=1.3G(100%)\nWritable regions: Total=867.9M written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=867.9M(100%)\n\n                                VIRTUAL   REGION \nREGION TYPE                        SIZE    COUNT (non-coalesced) \n===========                     =======  ======= \nAccelerate framework               384K        3 \nActivity Tracing                   256K        1 \nCG backing stores                 3840K        4 \nCG image                            84K        5 \nColorSync                          220K       25 \nCoreAnimation                      112K        8 \nCoreGraphics                        12K        2 \nCoreUI image data                 1040K        7 \nFoundation                          16K        1 \nKernel Alloc Once                    8K        1 \nMALLOC                           266.3M      198 \nMALLOC guard page                   32K        8 \nMALLOC_LARGE (reserved)            256K        1         reserved VM address space (unallocated)\nMALLOC_NANO (reserved)           384.0M        1         reserved VM address space (unallocated)\nObjC additional data                15K        1 \nOpenGL GLSL                        256K        3 \nSTACK GUARD                         72K       18 \nStack                             20.1M       18 \nVM_ALLOCATE                      147.9M      271 \nVM_ALLOCATE (reserved)            32.0M        1         reserved VM address space (unallocated)\n__CTF                               756        1 \n__DATA                            59.5M      415 \n__DATA_CONST                      15.3M      215 \n__DATA_DIRTY                       675K      119 \n__FONT_DATA                          4K        1 \n__GLSLBUILTINS                    5176K        1 \n__LINKEDIT                       727.5M       57 \n__TEXT                           618.5M      422 \n__UNICODE                          592K        1 \ndyld private memory               1152K        3 \nmapped file                      167.3M       24 \nshared memory                      768K       15 \n===========                     =======  ======= \nTOTAL                              2.4G     1851 \nTOTAL, minus reserved VM space     2.0G     1851 \n",
  "legacyInfo" : {
  "threadTriggered" : {
    "queue" : "com.apple.main-thread"
  "trialInfo" : {
  "rollouts" : [
      "rolloutId" : "6112e14f37f5d11121dcd519",
      "factorPackIds" : {
        "SIRI_TEXT_TO_SPEECH" : "62f3b99fd7b78f3a74434a79"
      "deploymentId" : 240000198
      "rolloutId" : "60186475825c62000ccf5450",
      "factorPackIds" : {
      "deploymentId" : 240000025
  "experiments" : [
**System Information** Operating system: Graphics card: **Blender Version** Broken: (example: 2.80, edbf15d3c044, master, 2018-11-28, as found on the splash screen) Worked: (newest version of Blender that worked as expected) **Short description of error** When applying a hair particle to any mesh, it crashes the program **Exact steps for others to reproduce the error** Click on Cube Select Particles from the Right Tabs Hit the Plus Sign to Add Particle Change from Emitter to Hair and the system immediately crashes ```lines=18 ------------------------------------- Translated Report (Full Report Below) ------------------------------------- Process: Blender [32670] Path: /Applications/Blender.app/Contents/MacOS/Blender Identifier: org.blenderfoundation.blender Version: 3.2.0 (3.2.0 2022-06-08) Code Type: X86-64 (Native) Parent Process: launchd [1] User ID: 501 Date/Time: 2022-08-13 13:00:09.5046 +1200 OS Version: macOS 12.4 (21F79) Report Version: 12 Anonymous UUID: 05E90402-A0D0-888E-9B78-3973D674DB16 Time Awake Since Boot: 410000 seconds System Integrity Protection: enabled Crashed Thread: 0 Dispatch queue: com.apple.main-thread Exception Type: EXC_ARITHMETIC (SIGFPE) Exception Codes: 0x0000000000000001, 0x0000000000000000 Exception Note: EXC_CORPSE_NOTIFY Termination Reason: Namespace SIGNAL, Code 8 Floating point exception: 8 Terminating Process: exc handler [32670] Thread 0 Crashed:: Dispatch queue: com.apple.main-thread 0 AMDRadeonX4000GLDriver 0x123743c60 glrUpdateTexture + 1199 1 libGPUSupportMercury.dylib 0x7ff9151edae5 gpusLoadCurrentTextures + 638 2 AMDRadeonX4000GLDriver 0x123713764 gldUpdateDispatch + 243 3 GLEngine 0x7ffa1de13529 gleDoDrawDispatchCoreGL3 + 673 4 GLEngine 0x7ffa1dde6043 glDrawElementsInstancedBaseVertex_ACC_GL3Exec + 290 5 libGL.dylib 0x7ffa1dd1b3cf glDrawElementsInstancedBaseVertex + 45 6 Blender 0x1072de905 draw_call_single_do + 453 7 Blender 0x1072dde86 drw_draw_pass_ex + 1766 8 Blender 0x1072dd78f DRW_draw_pass + 31 9 Blender 0x10731797a workbench_draw_sample + 330 10 Blender 0x107317b5e workbench_draw_scene + 94 11 Blender 0x1072d4619 drw_engines_draw_scene + 185 12 Blender 0x1072d33f1 DRW_draw_render_loop_ex + 1457 13 Blender 0x107f2e7da view3d_main_region_draw + 138 14 Blender 0x10767a101 ED_region_do_draw + 337 15 Blender 0x1071545fd wm_draw_update + 1773 16 Blender 0x107151860 WM_main + 48 17 Blender 0x106a1230e main + 878 18 dyld 0x127e5051e start + 462 Thread 1: 0 libsystem_kernel.dylib 0x7ff804cec9b6 semaphore_wait_trap + 10 1 libdispatch.dylib 0x7ff804b727ce _dispatch_sema4_wait + 16 2 libdispatch.dylib 0x7ff804b72c9d _dispatch_semaphore_wait_slow + 98 3 Blender 0x111e2a7b2 IlmThread_3_1::(anonymous namespace)::DefaultWorkerThread::run() + 50 4 Blender 0x111e292ae void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_3_1::Thread::*)(), IlmThread_3_1::Thread*> >(void*) + 62 5 libsystem_pthread.dylib 0x7ff804d294e1 _pthread_start + 125 6 libsystem_pthread.dylib 0x7ff804d24f6b thread_start + 15 Thread 2: 0 libsystem_kernel.dylib 0x7ff804cec9b6 semaphore_wait_trap + 10 1 libdispatch.dylib 0x7ff804b727ce _dispatch_sema4_wait + 16 2 libdispatch.dylib 0x7ff804b72c9d _dispatch_semaphore_wait_slow + 98 3 Blender 0x111e2a7b2 IlmThread_3_1::(anonymous namespace)::DefaultWorkerThread::run() + 50 4 Blender 0x111e292ae void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_3_1::Thread::*)(), IlmThread_3_1::Thread*> >(void*) + 62 5 libsystem_pthread.dylib 0x7ff804d294e1 _pthread_start + 125 6 libsystem_pthread.dylib 0x7ff804d24f6b thread_start + 15 Thread 3: 0 libsystem_kernel.dylib 0x7ff804cec9b6 semaphore_wait_trap + 10 1 libdispatch.dylib 0x7ff804b727ce _dispatch_sema4_wait + 16 2 libdispatch.dylib 0x7ff804b72c9d _dispatch_semaphore_wait_slow + 98 3 Blender 0x111e2a7b2 IlmThread_3_1::(anonymous namespace)::DefaultWorkerThread::run() + 50 4 Blender 0x111e292ae void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_3_1::Thread::*)(), IlmThread_3_1::Thread*> >(void*) + 62 5 libsystem_pthread.dylib 0x7ff804d294e1 _pthread_start + 125 6 libsystem_pthread.dylib 0x7ff804d24f6b thread_start + 15 Thread 4: 0 libsystem_kernel.dylib 0x7ff804cec9b6 semaphore_wait_trap + 10 1 libdispatch.dylib 0x7ff804b727ce _dispatch_sema4_wait + 16 2 libdispatch.dylib 0x7ff804b72c9d _dispatch_semaphore_wait_slow + 98 3 Blender 0x111e2a7b2 IlmThread_3_1::(anonymous namespace)::DefaultWorkerThread::run() + 50 4 Blender 0x111e292ae void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_3_1::Thread::*)(), IlmThread_3_1::Thread*> >(void*) + 62 5 libsystem_pthread.dylib 0x7ff804d294e1 _pthread_start + 125 6 libsystem_pthread.dylib 0x7ff804d24f6b thread_start + 15 Thread 5:: AMCP Logging Spool 0 libsystem_kernel.dylib 0x7ff804cec9b6 semaphore_wait_trap + 10 1 caulk 0x7ff80d8212e6 caulk::mach::semaphore::wait_or_error() + 16 2 caulk 0x7ff80d809148 caulk::concurrent::details::worker_thread::run() + 36 3 caulk 0x7ff80d808e0c void* caulk::thread_proxy<std::__1::tuple<caulk::thread::attributes, void (caulk::concurrent::details::worker_thread::*)(), std::__1::tuple<caulk::concurrent::details::worker_thread*> > >(void*) + 41 4 libsystem_pthread.dylib 0x7ff804d294e1 _pthread_start + 125 5 libsystem_pthread.dylib 0x7ff804d24f6b thread_start + 15 Thread 6: 0 libsystem_pthread.dylib 0x7ff804d24f48 start_wqthread + 0 Thread 7:: com.apple.audio.IOThread.client 0 libsystem_kernel.dylib 0x7ff804cec97a mach_msg_trap + 10 1 libsystem_kernel.dylib 0x7ff804cecce8 mach_msg + 56 2 CoreAudio 0x7ff806974c87 HALB_MachPort::SendSimpleMessageWithSimpleReply(unsigned int, unsigned int, int, int&, bool, unsigned int) + 111 3 CoreAudio 0x7ff8067ffd6b HALC_ProxyIOContext::IOWorkLoop() + 3909 4 CoreAudio 0x7ff8067fe85d invocation function for block in HALC_ProxyIOContext::HALC_ProxyIOContext(unsigned int, unsigned int) + 63 5 CoreAudio 0x7ff8069ca696 HALB_IOThread::Entry(void*) + 72 6 libsystem_pthread.dylib 0x7ff804d294e1 _pthread_start + 125 7 libsystem_pthread.dylib 0x7ff804d24f6b thread_start + 15 Thread 8: 0 libsystem_kernel.dylib 0x7ff804cef3ea __psynch_cvwait + 10 1 libsystem_pthread.dylib 0x7ff804d29a6f _pthread_cond_wait + 1249 2 libopenblas64_.0.dylib 0x13601249f blas_thread_server + 207 3 libsystem_pthread.dylib 0x7ff804d294e1 _pthread_start + 125 4 libsystem_pthread.dylib 0x7ff804d24f6b thread_start + 15 Thread 9: 0 libsystem_kernel.dylib 0x7ff804cef3ea __psynch_cvwait + 10 1 libsystem_pthread.dylib 0x7ff804d29a6f _pthread_cond_wait + 1249 2 libopenblas64_.0.dylib 0x13601249f blas_thread_server + 207 3 libsystem_pthread.dylib 0x7ff804d294e1 _pthread_start + 125 4 libsystem_pthread.dylib 0x7ff804d24f6b thread_start + 15 Thread 10: 0 libsystem_kernel.dylib 0x7ff804cef3ea __psynch_cvwait + 10 1 libsystem_pthread.dylib 0x7ff804d29a6f _pthread_cond_wait + 1249 2 libopenblas64_.0.dylib 0x13601249f blas_thread_server + 207 3 libsystem_pthread.dylib 0x7ff804d294e1 _pthread_start + 125 4 libsystem_pthread.dylib 0x7ff804d24f6b thread_start + 15 Thread 11: 0 libsystem_kernel.dylib 0x7ff804cec9b6 semaphore_wait_trap + 10 1 Blender 0x107147d98 tbb::internal::rml::private_worker::run() + 104 2 Blender 0x107147d29 tbb::internal::rml::private_worker::thread_routine(void*) + 9 3 libsystem_pthread.dylib 0x7ff804d294e1 _pthread_start + 125 4 libsystem_pthread.dylib 0x7ff804d24f6b thread_start + 15 Thread 12: 0 libsystem_kernel.dylib 0x7ff804cec9b6 semaphore_wait_trap + 10 1 Blender 0x107147d98 tbb::internal::rml::private_worker::run() + 104 2 Blender 0x107147d29 tbb::internal::rml::private_worker::thread_routine(void*) + 9 3 libsystem_pthread.dylib 0x7ff804d294e1 _pthread_start + 125 4 libsystem_pthread.dylib 0x7ff804d24f6b thread_start + 15 Thread 13: 0 libsystem_kernel.dylib 0x7ff804cec9b6 semaphore_wait_trap + 10 1 Blender 0x107147d98 tbb::internal::rml::private_worker::run() + 104 2 Blender 0x107147d29 tbb::internal::rml::private_worker::thread_routine(void*) + 9 3 libsystem_pthread.dylib 0x7ff804d294e1 _pthread_start + 125 4 libsystem_pthread.dylib 0x7ff804d24f6b thread_start + 15 Thread 14:: com.apple.NSEventThread 0 libsystem_kernel.dylib 0x7ff804cec97a mach_msg_trap + 10 1 libsystem_kernel.dylib 0x7ff804cecce8 mach_msg + 56 2 CoreFoundation 0x7ff804df038d __CFRunLoopServiceMachPort + 319 3 CoreFoundation 0x7ff804deea18 __CFRunLoopRun + 1276 4 CoreFoundation 0x7ff804dede5c CFRunLoopRunSpecific + 562 5 AppKit 0x7ff80799ac1e _NSEventThread + 132 6 libsystem_pthread.dylib 0x7ff804d294e1 _pthread_start + 125 7 libsystem_pthread.dylib 0x7ff804d24f6b thread_start + 15 Thread 15: 0 libsystem_pthread.dylib 0x7ff804d24f48 start_wqthread + 0 Thread 16: 0 libsystem_pthread.dylib 0x7ff804d24f48 start_wqthread + 0 Thread 17: 0 libsystem_pthread.dylib 0x7ff804d24f48 start_wqthread + 0 Thread 0 crashed with X86 Thread State (64-bit): rax: 0x0000000000000040 rbx: 0x0000600001e21720 rcx: 0x0000000000000000 rdx: 0x0000000000000000 rdi: 0x00007f9e6b86da00 rsi: 0x0000000000000000 rbp: 0x00007ff7b9673c20 rsp: 0x00007ff7b9673bf0 r8: 0x0000000000000000 r9: 0x000000000000008f r10: 0x00007f9e6b86da48 r11: 0x0000000000000010 r12: 0x000000000000000f r13: 0x00007f9e6fae5ba0 r14: 0x00007f9e6b86da00 r15: 0x0000600000de7b60 rip: 0x0000000123743c60 rfl: 0x0000000000010246 cr2: 0x000000012c81f000 Logical CPU: 0 Error Code: 0x00000000 Trap Number: 0 Thread 0 instruction stream: 00 00 09 fa c1 e6 13 09-d6 09 de 09 ce 31 c0 41 .............1.A 89 45 48 45 89 45 4c 41-89 45 50 41 89 75 54 0f .EHE.ELA.EPA.uT. 57 c0 41 0f 11 45 58 4d-85 ff 74 5c 49 8b 47 10 W.A..EXM..t\I.G. 48 85 c0 74 53 48 8b 18-48 85 db 74 4b 66 41 83 H..tSH..H..tKfA. be 9c 01 00 00 00 49 8b-07 48 8b 40 10 41 8b 4d ......I..H.@.A.M 4c 78 10 89 ce c1 ee 10-81 e6 ff 3f 00 00 31 d2 Lx.........?..1. [48]f7 f6 41 89 45 50 49-8b 47 10 48 8b 40 20 41 H..A.EPI.G.H.@ A <== 89 45 48 48 c1 e8 20 0f-b7 c0 81 e1 00 00 ff ff .EHH.. ......... 09 c1 41 89 4d 4c eb 0a-41 c7 45 50 00 00 00 00 ..A.ML..A.EP.... 31 db 49 8b 7d 18 48 39-fb 74 3b 48 85 ff 74 15 1.I.}.H9.t;H..t. 4d 8d 7d 18 e8 1f 39 09-00 0f 57 c0 41 0f 11 47 M.}...9...W.A..G 10 41 0f 11 07 48 85 db-74 1c 48 89 df e8 0c 39 .A...H..t.H....9 Binary Images: 0x123711000 - 0x123828fff com.apple.AMDRadeonX4000GLDriver (4.8.54) <9a48f06c-82b0-3bdd-8f5d-69d94098e1b0> /System/Library/Extensions/AMDRadeonX4000GLDriver.bundle/Contents/MacOS/AMDRadeonX4000GLDriver 0x7ff9151e6000 - 0x7ff9151f0fff libGPUSupportMercury.dylib (*) <5fcec882-890c-3c7a-a3dd-6e82f716199a> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupportMercury.dylib 0x7ffa1dd20000 - 0x7ffa1dea9fff GLEngine (*) <a72561b7-7972-305a-8f85-0366b47b7a8f> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLEngine.bundle/GLEngine 0x7ffa1dd15000 - 0x7ffa1dd1ffff libGL.dylib (*) <7a5491db-1b13-37bf-a174-112d53bf9031> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib 0x10688b000 - 0x116a72fff org.blenderfoundation.blender (3.2.0) <c389d82e-9893-3b04-bdfb-63e2e302564e> /Applications/Blender.app/Contents/MacOS/Blender 0x127e4b000 - 0x127eb6fff dyld (*) <b70ce1ec-b902-3852-8268-05de00bfa8d5> /usr/lib/dyld 0x7ff804ceb000 - 0x7ff804d22fff libsystem_kernel.dylib (*) <61711d11-e776-3bc3-b9a2-6f9f37cb8499> /usr/lib/system/libsystem_kernel.dylib 0x7ff804b6f000 - 0x7ff804bb5fff libdispatch.dylib (*) <534511b9-b3b0-33a7-b1ea-402595d28bda> /usr/lib/system/libdispatch.dylib 0x7ff804d23000 - 0x7ff804d2efff libsystem_pthread.dylib (*) <bc574849-1aae-31e7-b350-916dda999d97> /usr/lib/system/libsystem_pthread.dylib 0x7ff80d807000 - 0x7ff80d828fff com.apple.audio.caulk (1.0) <42fecc51-73d2-3b5c-b109-208f4cb4c3cd> /System/Library/PrivateFrameworks/caulk.framework/Versions/A/caulk 0x7ff806646000 - 0x7ff806d7afff com.apple.audio.CoreAudio (5.0) <1621fd80-991f-3b5f-97f3-dbbb21bdeba3> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio 0x135ce1000 - 0x13996cfff libopenblas64_.0.dylib (*) <10431d8f-5e3b-3bbc-abd5-81f6a73a5269> /Applications/Blender.app/Contents/Resources/3.2/python/lib/python3.10/site-packages/numpy/.dylibs/libopenblas64_.0.dylib 0x7ff804d70000 - 0x7ff805272fff com.apple.CoreFoundation (6.9) <f8e45ef9-9fd2-3331-bb1b-703d5dacdaf1> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7ff8077ee000 - 0x7ff80867cfff com.apple.AppKit (6.9) <832ad371-d3b8-3061-b4e2-1c4e0cffce0b> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit External Modification Summary: Calls made by other processes targeting this process: task_for_pid: 0 thread_create: 0 thread_set_state: 0 Calls made by this process: task_for_pid: 0 thread_create: 0 thread_set_state: 0 Calls made by all processes on this machine: task_for_pid: 0 thread_create: 0 thread_set_state: 0 VM Region Summary: ReadOnly portion of Libraries: Total=1.3G resident=0K(0%) swapped_out_or_unallocated=1.3G(100%) Writable regions: Total=867.9M written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=867.9M(100%) VIRTUAL REGION REGION TYPE SIZE COUNT (non-coalesced) =========== ======= ======= Accelerate framework 384K 3 Activity Tracing 256K 1 CG backing stores 3840K 4 CG image 84K 5 ColorSync 220K 25 CoreAnimation 112K 8 CoreGraphics 12K 2 CoreUI image data 1040K 7 Foundation 16K 1 Kernel Alloc Once 8K 1 MALLOC 266.3M 198 MALLOC guard page 32K 8 MALLOC_LARGE (reserved) 256K 1 reserved VM address space (unallocated) MALLOC_NANO (reserved) 384.0M 1 reserved VM address space (unallocated) ObjC additional data 15K 1 OpenGL GLSL 256K 3 STACK GUARD 72K 18 Stack 20.1M 18 VM_ALLOCATE 147.9M 271 VM_ALLOCATE (reserved) 32.0M 1 reserved VM address space (unallocated) __CTF 756 1 __DATA 59.5M 415 __DATA_CONST 15.3M 215 __DATA_DIRTY 675K 119 __FONT_DATA 4K 1 __GLSLBUILTINS 5176K 1 __LINKEDIT 727.5M 57 __TEXT 618.5M 422 __UNICODE 592K 1 dyld private memory 1152K 3 mapped file 167.3M 24 shared memory 768K 15 =========== ======= ======= TOTAL 2.4G 1851 TOTAL, minus reserved VM space 2.0G 1851 ----------- Full Report ----------- {"app_name":"Blender","timestamp":"2022-08-13 13:00:10.00 +1200","app_version":"3.2.0","slice_uuid":"c389d82e-9893-3b04-bdfb-63e2e302564e","build_version":"3.2.0 2022-06-08","platform":1,"bundleID":"org.blenderfoundation.blender","share_with_app_devs":0,"is_first_party":0,"bug_type":"309","os_version":"macOS 12.4 (21F79)","incident_id":"80D07A91-2314-442C-92E9-433BFE00CE47","name":"Blender"} { "uptime" : 410000, "procLaunch" : "2022-08-13 12:58:35.3522 +1200", "procRole" : "Foreground", "version" : 2, "userID" : 501, "deployVersion" : 210, "modelCode" : "iMac17,1", "procStartAbsTime" : 415810803494807, "coalitionID" : 15377, "osVersion" : { "train" : "macOS 12.4", "build" : "21F79", "releaseType" : "User" }, "captureTime" : "2022-08-13 13:00:09.5046 +1200", "incident" : "80D07A91-2314-442C-92E9-433BFE00CE47", "bug_type" : "309", "pid" : 32670, "procExitAbsTime" : 415904938136089, "cpuType" : "X86-64", "procName" : "Blender", "procPath" : "\/Applications\/Blender.app\/Contents\/MacOS\/Blender", "bundleInfo" : {"CFBundleShortVersionString":"3.2.0","CFBundleVersion":"3.2.0 2022-06-08","CFBundleIdentifier":"org.blenderfoundation.blender"}, "storeInfo" : {"deviceIdentifierForVendor":"6B227A37-ADEF-5DBD-B6F1-7E3F7DB3591E","thirdParty":true}, "parentProc" : "launchd", "parentPid" : 1, "coalitionName" : "org.blenderfoundation.blender", "crashReporterKey" : "05E90402-A0D0-888E-9B78-3973D674DB16", "sip" : "enabled", "isCorpse" : 1, "exception" : {"codes":"0x0000000000000001, 0x0000000000000000","rawCodes":[1,0],"type":"EXC_ARITHMETIC","signal":"SIGFPE"}, "termination" : {"flags":0,"code":8,"namespace":"SIGNAL","indicator":"Floating point exception: 8","byProc":"exc handler","byPid":32670}, "extMods" : {"caller":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"system":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"targeted":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"warnings":0}, "faultingThread" : 0, "threads" : [{"triggered":true,"id":4772558,"instructionState":{"instructionStream":{"bytes":[0,0,9,250,193,230,19,9,214,9,222,9,206,49,192,65,137,69,72,69,137,69,76,65,137,69,80,65,137,117,84,15,87,192,65,15,17,69,88,77,133,255,116,92,73,139,71,16,72,133,192,116,83,72,139,24,72,133,219,116,75,102,65,131,190,156,1,0,0,0,73,139,7,72,139,64,16,65,139,77,76,120,16,137,206,193,238,16,129,230,255,63,0,0,49,210,72,247,246,65,137,69,80,73,139,71,16,72,139,64,32,65,137,69,72,72,193,232,32,15,183,192,129,225,0,0,255,255,9,193,65,137,77,76,235,10,65,199,69,80,0,0,0,0,49,219,73,139,125,24,72,57,251,116,59,72,133,255,116,21,77,141,125,24,232,31,57,9,0,15,87,192,65,15,17,71,16,65,15,17,7,72,133,219,116,28,72,137,223,232,12,57],"offset":96}},"threadState":{"r13":{"value":140318455258016},"rax":{"value":64},"rflags":{"value":66118},"cpu":{"value":0},"r14":{"value":140318385560064},"rsi":{"value":0},"r8":{"value":0},"cr2":{"value":5041680384},"rdx":{"value":0},"r10":{"value":140318385560136},"r9":{"value":143},"r15":{"value":105553130847072},"rbx":{"value":105553147860768},"trap":{"value":0},"err":{"value":0},"r11":{"value":16},"rip":{"value":4889787488,"matchesCrashFrame":1},"rbp":{"value":140701944200224},"rsp":{"value":140701944200176},"r12":{"value":15},"rcx":{"value":0},"flavor":"x86_THREAD_STATE","rdi":{"value":140318385560064}},"queue":"com.apple.main-thread","frames":[{"imageOffset":207968,"symbol":"glrUpdateTexture","symbolLocation":1199,"imageIndex":0},{"imageOffset":31461,"symbol":"gpusLoadCurrentTextures","symbolLocation":638,"imageIndex":1},{"imageOffset":10084,"symbol":"gldUpdateDispatch","symbolLocation":243,"imageIndex":0},{"imageOffset":996649,"symbol":"gleDoDrawDispatchCoreGL3","symbolLocation":673,"imageIndex":2},{"imageOffset":811075,"symbol":"glDrawElementsInstancedBaseVertex_ACC_GL3Exec","symbolLocation":290,"imageIndex":2},{"imageOffset":25551,"symbol":"glDrawElementsInstancedBaseVertex","symbolLocation":45,"imageIndex":3},{"imageOffset":10828037,"symbol":"draw_call_single_do","symbolLocation":453,"imageIndex":4},{"imageOffset":10825350,"symbol":"drw_draw_pass_ex","symbolLocation":1766,"imageIndex":4},{"imageOffset":10823567,"symbol":"DRW_draw_pass","symbolLocation":31,"imageIndex":4},{"imageOffset":11061626,"symbol":"workbench_draw_sample","symbolLocation":330,"imageIndex":4},{"imageOffset":11062110,"symbol":"workbench_draw_scene","symbolLocation":94,"imageIndex":4},{"imageOffset":10786329,"symbol":"drw_engines_draw_scene","symbolLocation":185,"imageIndex":4},{"imageOffset":10781681,"symbol":"DRW_draw_render_loop_ex","symbolLocation":1457,"imageIndex":4},{"imageOffset":23738330,"symbol":"view3d_main_region_draw","symbolLocation":138,"imageIndex":4},{"imageOffset":14610689,"symbol":"ED_region_do_draw","symbolLocation":337,"imageIndex":4},{"imageOffset":9213437,"symbol":"wm_draw_update","symbolLocation":1773,"imageIndex":4},{"imageOffset":9201760,"symbol":"WM_main","symbolLocation":48,"imageIndex":4},{"imageOffset":1602318,"symbol":"main","symbolLocation":878,"imageIndex":4},{"imageOffset":21790,"symbol":"start","symbolLocation":462,"imageIndex":5}]},{"id":4772613,"frames":[{"imageOffset":6582,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":6},{"imageOffset":14286,"symbol":"_dispatch_sema4_wait","symbolLocation":16,"imageIndex":7},{"imageOffset":15517,"symbol":"_dispatch_semaphore_wait_slow","symbolLocation":98,"imageIndex":7},{"imageOffset":190445490,"symbol":"IlmThread_3_1::(anonymous namespace)::DefaultWorkerThread::run()","symbolLocation":50,"imageIndex":4},{"imageOffset":190440110,"symbol":"void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_3_1::Thread::*)(), IlmThread_3_1::Thread*> >(void*)","symbolLocation":62,"imageIndex":4},{"imageOffset":25825,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8043,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":4772614,"frames":[{"imageOffset":6582,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":6},{"imageOffset":14286,"symbol":"_dispatch_sema4_wait","symbolLocation":16,"imageIndex":7},{"imageOffset":15517,"symbol":"_dispatch_semaphore_wait_slow","symbolLocation":98,"imageIndex":7},{"imageOffset":190445490,"symbol":"IlmThread_3_1::(anonymous namespace)::DefaultWorkerThread::run()","symbolLocation":50,"imageIndex":4},{"imageOffset":190440110,"symbol":"void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_3_1::Thread::*)(), IlmThread_3_1::Thread*> >(void*)","symbolLocation":62,"imageIndex":4},{"imageOffset":25825,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8043,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":4772615,"frames":[{"imageOffset":6582,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":6},{"imageOffset":14286,"symbol":"_dispatch_sema4_wait","symbolLocation":16,"imageIndex":7},{"imageOffset":15517,"symbol":"_dispatch_semaphore_wait_slow","symbolLocation":98,"imageIndex":7},{"imageOffset":190445490,"symbol":"IlmThread_3_1::(anonymous namespace)::DefaultWorkerThread::run()","symbolLocation":50,"imageIndex":4},{"imageOffset":190440110,"symbol":"void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_3_1::Thread::*)(), IlmThread_3_1::Thread*> >(void*)","symbolLocation":62,"imageIndex":4},{"imageOffset":25825,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8043,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":4772616,"frames":[{"imageOffset":6582,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":6},{"imageOffset":14286,"symbol":"_dispatch_sema4_wait","symbolLocation":16,"imageIndex":7},{"imageOffset":15517,"symbol":"_dispatch_semaphore_wait_slow","symbolLocation":98,"imageIndex":7},{"imageOffset":190445490,"symbol":"IlmThread_3_1::(anonymous namespace)::DefaultWorkerThread::run()","symbolLocation":50,"imageIndex":4},{"imageOffset":190440110,"symbol":"void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_3_1::Thread::*)(), IlmThread_3_1::Thread*> >(void*)","symbolLocation":62,"imageIndex":4},{"imageOffset":25825,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8043,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":4772619,"name":"AMCP Logging Spool","frames":[{"imageOffset":6582,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":6},{"imageOffset":107238,"symbol":"caulk::mach::semaphore::wait_or_error()","symbolLocation":16,"imageIndex":9},{"imageOffset":8520,"symbol":"caulk::concurrent::details::worker_thread::run()","symbolLocation":36,"imageIndex":9},{"imageOffset":7692,"symbol":"void* caulk::thread_proxy<std::__1::tuple<caulk::thread::attributes, void (caulk::concurrent::details::worker_thread::*)(), std::__1::tuple<caulk::concurrent::details::worker_thread*> > >(void*)","symbolLocation":41,"imageIndex":9},{"imageOffset":25825,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8043,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":4772655,"frames":[{"imageOffset":8008,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":8}]},{"id":4772673,"name":"com.apple.audio.IOThread.client","frames":[{"imageOffset":6522,"symbol":"mach_msg_trap","symbolLocation":10,"imageIndex":6},{"imageOffset":7400,"symbol":"mach_msg","symbolLocation":56,"imageIndex":6},{"imageOffset":3337351,"symbol":"HALB_MachPort::SendSimpleMessageWithSimpleReply(unsigned int, unsigned int, int, int&, bool, unsigned int)","symbolLocation":111,"imageIndex":10},{"imageOffset":1809771,"symbol":"HALC_ProxyIOContext::IOWorkLoop()","symbolLocation":3909,"imageIndex":10},{"imageOffset":1804381,"symbol":"invocation function for block in HALC_ProxyIOContext::HALC_ProxyIOContext(unsigned int, unsigned int)","symbolLocation":63,"imageIndex":10},{"imageOffset":3688086,"symbol":"HALB_IOThread::Entry(void*)","symbolLocation":72,"imageIndex":10},{"imageOffset":25825,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8043,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":4772694,"frames":[{"imageOffset":17386,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":6},{"imageOffset":27247,"symbol":"_pthread_cond_wait","symbolLocation":1249,"imageIndex":8},{"imageOffset":3347615,"symbol":"blas_thread_server","symbolLocation":207,"imageIndex":11},{"imageOffset":25825,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8043,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":4772695,"frames":[{"imageOffset":17386,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":6},{"imageOffset":27247,"symbol":"_pthread_cond_wait","symbolLocation":1249,"imageIndex":8},{"imageOffset":3347615,"symbol":"blas_thread_server","symbolLocation":207,"imageIndex":11},{"imageOffset":25825,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8043,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":4772696,"frames":[{"imageOffset":17386,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":6},{"imageOffset":27247,"symbol":"_pthread_cond_wait","symbolLocation":1249,"imageIndex":8},{"imageOffset":3347615,"symbol":"blas_thread_server","symbolLocation":207,"imageIndex":11},{"imageOffset":25825,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8043,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":4772709,"frames":[{"imageOffset":6582,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":6},{"imageOffset":9162136,"symbol":"tbb::internal::rml::private_worker::run()","symbolLocation":104,"imageIndex":4},{"imageOffset":9162025,"symbol":"tbb::internal::rml::private_worker::thread_routine(void*)","symbolLocation":9,"imageIndex":4},{"imageOffset":25825,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8043,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":4772710,"frames":[{"imageOffset":6582,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":6},{"imageOffset":9162136,"symbol":"tbb::internal::rml::private_worker::run()","symbolLocation":104,"imageIndex":4},{"imageOffset":9162025,"symbol":"tbb::internal::rml::private_worker::thread_routine(void*)","symbolLocation":9,"imageIndex":4},{"imageOffset":25825,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8043,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":4772711,"frames":[{"imageOffset":6582,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":6},{"imageOffset":9162136,"symbol":"tbb::internal::rml::private_worker::run()","symbolLocation":104,"imageIndex":4},{"imageOffset":9162025,"symbol":"tbb::internal::rml::private_worker::thread_routine(void*)","symbolLocation":9,"imageIndex":4},{"imageOffset":25825,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8043,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":4772740,"name":"com.apple.NSEventThread","frames":[{"imageOffset":6522,"symbol":"mach_msg_trap","symbolLocation":10,"imageIndex":6},{"imageOffset":7400,"symbol":"mach_msg","symbolLocation":56,"imageIndex":6},{"imageOffset":525197,"symbol":"__CFRunLoopServiceMachPort","symbolLocation":319,"imageIndex":12},{"imageOffset":518680,"symbol":"__CFRunLoopRun","symbolLocation":1276,"imageIndex":12},{"imageOffset":515676,"symbol":"CFRunLoopRunSpecific","symbolLocation":562,"imageIndex":12},{"imageOffset":1756190,"symbol":"_NSEventThread","symbolLocation":132,"imageIndex":13},{"imageOffset":25825,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8043,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":4773578,"frames":[{"imageOffset":8008,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":8}]},{"id":4773586,"frames":[{"imageOffset":8008,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":8}]},{"id":4773587,"frames":[{"imageOffset":8008,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":8}]}], "usedImages" : [ { "source" : "P", "arch" : "x86_64", "base" : 4889579520, "CFBundleShortVersionString" : "4.8.54", "CFBundleIdentifier" : "com.apple.AMDRadeonX4000GLDriver", "size" : 1146880, "uuid" : "9a48f06c-82b0-3bdd-8f5d-69d94098e1b0", "path" : "\/System\/Library\/Extensions\/AMDRadeonX4000GLDriver.bundle\/Contents\/MacOS\/AMDRadeonX4000GLDriver", "name" : "AMDRadeonX4000GLDriver", "CFBundleVersion" : "4.0.8" }, { "source" : "P", "arch" : "x86_64", "base" : 140707777896448, "size" : 45056, "uuid" : "5fcec882-890c-3c7a-a3dd-6e82f716199a", "path" : "\/System\/Library\/PrivateFrameworks\/GPUSupport.framework\/Versions\/A\/Libraries\/libGPUSupportMercury.dylib", "name" : "libGPUSupportMercury.dylib" }, { "source" : "P", "arch" : "x86_64", "base" : 140712218853376, "size" : 1613824, "uuid" : "a72561b7-7972-305a-8f85-0366b47b7a8f", "path" : "\/System\/Library\/Frameworks\/OpenGL.framework\/Versions\/A\/Resources\/GLEngine.bundle\/GLEngine", "name" : "GLEngine" }, { "source" : "P", "arch" : "x86_64", "base" : 140712218808320, "size" : 45056, "uuid" : "7a5491db-1b13-37bf-a174-112d53bf9031", "path" : "\/System\/Library\/Frameworks\/OpenGL.framework\/Versions\/A\/Libraries\/libGL.dylib", "name" : "libGL.dylib" }, { "source" : "P", "arch" : "x86_64", "base" : 4404588544, "CFBundleShortVersionString" : "3.2.0", "CFBundleIdentifier" : "org.blenderfoundation.blender", "size" : 270434304, "uuid" : "c389d82e-9893-3b04-bdfb-63e2e302564e", "path" : "\/Applications\/Blender.app\/Contents\/MacOS\/Blender", "name" : "Blender", "CFBundleVersion" : "3.2.0 2022-06-08" }, { "source" : "P", "arch" : "x86_64", "base" : 4964265984, "size" : 442368, "uuid" : "b70ce1ec-b902-3852-8268-05de00bfa8d5", "path" : "\/usr\/lib\/dyld", "name" : "dyld" }, { "source" : "P", "arch" : "x86_64", "base" : 140703209271296, "size" : 229376, "uuid" : "61711d11-e776-3bc3-b9a2-6f9f37cb8499", "path" : "\/usr\/lib\/system\/libsystem_kernel.dylib", "name" : "libsystem_kernel.dylib" }, { "source" : "P", "arch" : "x86_64", "base" : 140703207714816, "size" : 290816, "uuid" : "534511b9-b3b0-33a7-b1ea-402595d28bda", "path" : "\/usr\/lib\/system\/libdispatch.dylib", "name" : "libdispatch.dylib" }, { "source" : "P", "arch" : "x86_64", "base" : 140703209500672, "size" : 49152, "uuid" : "bc574849-1aae-31e7-b350-916dda999d97", "path" : "\/usr\/lib\/system\/libsystem_pthread.dylib", "name" : "libsystem_pthread.dylib" }, { "source" : "P", "arch" : "x86_64", "base" : 140703355138048, "CFBundleShortVersionString" : "1.0", "CFBundleIdentifier" : "com.apple.audio.caulk", "size" : 139264, "uuid" : "42fecc51-73d2-3b5c-b109-208f4cb4c3cd", "path" : "\/System\/Library\/PrivateFrameworks\/caulk.framework\/Versions\/A\/caulk", "name" : "caulk" }, { "source" : "P", "arch" : "x86_64", "base" : 140703235858432, "CFBundleShortVersionString" : "5.0", "CFBundleIdentifier" : "com.apple.audio.CoreAudio", "size" : 7557120, "uuid" : "1621fd80-991f-3b5f-97f3-dbbb21bdeba3", "path" : "\/System\/Library\/Frameworks\/CoreAudio.framework\/Versions\/A\/CoreAudio", "name" : "CoreAudio", "CFBundleVersion" : "5.0" }, { "source" : "P", "arch" : "x86_64", "base" : 5197664256, "size" : 63488000, "uuid" : "10431d8f-5e3b-3bbc-abd5-81f6a73a5269", "path" : "\/Applications\/Blender.app\/Contents\/Resources\/3.2\/python\/lib\/python3.10\/site-packages\/numpy\/.dylibs\/libopenblas64_.0.dylib", "name" : "libopenblas64_.0.dylib" }, { "source" : "P", "arch" : "x86_64h", "base" : 140703209816064, "CFBundleShortVersionString" : "6.9", "CFBundleIdentifier" : "com.apple.CoreFoundation", "size" : 5255168, "uuid" : "f8e45ef9-9fd2-3331-bb1b-703d5dacdaf1", "path" : "\/System\/Library\/Frameworks\/CoreFoundation.framework\/Versions\/A\/CoreFoundation", "name" : "CoreFoundation", "CFBundleVersion" : "1863" }, { "source" : "P", "arch" : "x86_64", "base" : 140703254372352, "CFBundleShortVersionString" : "6.9", "CFBundleIdentifier" : "com.apple.AppKit", "size" : 15265792, "uuid" : "832ad371-d3b8-3061-b4e2-1c4e0cffce0b", "path" : "\/System\/Library\/Frameworks\/AppKit.framework\/Versions\/C\/AppKit", "name" : "AppKit", "CFBundleVersion" : "2113.50.132" } ], "sharedCache" : { "base" : 140703206244352, "size" : 15220686848, "uuid" : "398acfb4-57f6-31e0-bc82-e9959e5c92ce" }, "vmSummary" : "ReadOnly portion of Libraries: Total=1.3G resident=0K(0%) swapped_out_or_unallocated=1.3G(100%)\nWritable regions: Total=867.9M written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=867.9M(100%)\n\n VIRTUAL REGION \nREGION TYPE SIZE COUNT (non-coalesced) \n=========== ======= ======= \nAccelerate framework 384K 3 \nActivity Tracing 256K 1 \nCG backing stores 3840K 4 \nCG image 84K 5 \nColorSync 220K 25 \nCoreAnimation 112K 8 \nCoreGraphics 12K 2 \nCoreUI image data 1040K 7 \nFoundation 16K 1 \nKernel Alloc Once 8K 1 \nMALLOC 266.3M 198 \nMALLOC guard page 32K 8 \nMALLOC_LARGE (reserved) 256K 1 reserved VM address space (unallocated)\nMALLOC_NANO (reserved) 384.0M 1 reserved VM address space (unallocated)\nObjC additional data 15K 1 \nOpenGL GLSL 256K 3 \nSTACK GUARD 72K 18 \nStack 20.1M 18 \nVM_ALLOCATE 147.9M 271 \nVM_ALLOCATE (reserved) 32.0M 1 reserved VM address space (unallocated)\n__CTF 756 1 \n__DATA 59.5M 415 \n__DATA_CONST 15.3M 215 \n__DATA_DIRTY 675K 119 \n__FONT_DATA 4K 1 \n__GLSLBUILTINS 5176K 1 \n__LINKEDIT 727.5M 57 \n__TEXT 618.5M 422 \n__UNICODE 592K 1 \ndyld private memory 1152K 3 \nmapped file 167.3M 24 \nshared memory 768K 15 \n=========== ======= ======= \nTOTAL 2.4G 1851 \nTOTAL, minus reserved VM space 2.0G 1851 \n", "legacyInfo" : { "threadTriggered" : { "queue" : "com.apple.main-thread" } }, "trialInfo" : { "rollouts" : [ { "rolloutId" : "6112e14f37f5d11121dcd519", "factorPackIds" : { "SIRI_TEXT_TO_SPEECH" : "62f3b99fd7b78f3a74434a79" }, "deploymentId" : 240000198 }, { "rolloutId" : "60186475825c62000ccf5450", "factorPackIds" : { }, "deploymentId" : 240000025 } ], "experiments" : [ ] } } ```
Author
Added subscriber: @manamedia
Member
Closed as duplicate of #83199
2 Participants
Reference: blender/blender#100382
