Regression: Surface Deform Modifier does not display correctly in Edit Mode while a Vertex Group is assigned to the Modifier. #100578
Closed
opened 2022-08-23 07:02:23 +02:00 by Starcat · 7 comments
Graphics card: NVIDIA GeForce GTX 1070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 512.15
Broken: version: 3.1.2, branch: master, commit date: 2022-03-31 17:40, hash: cc66d1020c
Broken: 3.4
Broken: 2.90
Worked: 2.83.20
Caused by deaff945d0
If I add a Surface Deform modifier to a mesh and assign a vertex group to the modifier, the Edit Mode viewport display will ignore this vertex group and display the mesh with all vertices affected.
While not in Edit Mode the mesh will display correctly in the viewport. Not an urgent bug, but would be helpful to have this fixed.
  1. Select the default cube and change to Edit Mode.
  2. Select a single face, add a vertex group, and assign this face to that vertex group.
  3. Change to Object Mode and duplicate the cube.
  4. Add the Surface Deform modifier to the original cube.
  5. Set the second cube as the Target and the single face as the Vertex Group.
  6. Bind the Target to the default cube.
  7. Change to Edit Mode with the Target cube selected and scale it up by any amount.
  8. Change back to Object Mode and hide the Target cube. The default cube is displayed correctly with only one face scaled up.
  9. Change to Edit Mode with the default cube selected and enable the display of the Surface Deform modifier in Edit Mode. The viewport will show the entire cube scaled up.
**System Information** Operating system: Windows-10-10.0.19043-SP0 64 Bits Graphics card: NVIDIA GeForce GTX 1070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 512.15 **Blender Version** Broken: version: 3.1.2, branch: master, commit date: 2022-03-31 17:40, hash: `cc66d1020c` Broken: 3.4 Broken: 2.90 Worked: 2.83.20 Caused by deaff945d0 **Short description of error** If I add a Surface Deform modifier to a mesh and assign a vertex group to the modifier, the Edit Mode viewport display will ignore this vertex group and display the mesh with all vertices affected. While not in Edit Mode the mesh will display correctly in the viewport. Not an urgent bug, but would be helpful to have this fixed. **Exact steps for others to reproduce the error** 1. Select the default cube and change to Edit Mode. 2. Select a single face, add a vertex group, and assign this face to that vertex group. 3. Change to Object Mode and duplicate the cube. 4. Add the Surface Deform modifier to the original cube. 5. Set the second cube as the Target and the single face as the Vertex Group. 6. Bind the Target to the default cube. 7. Change to Edit Mode with the Target cube selected and scale it up by any amount. 8. Change back to Object Mode and hide the Target cube. The default cube is displayed correctly with only one face scaled up. 9. Change to Edit Mode with the default cube selected and enable the display of the Surface Deform modifier in Edit Mode. The viewport will show the entire cube scaled up.
Author
Added subscriber: @Starcat
Member
Added subscriber: @lichtwerk
Member
Member
Can confirm, will check
Philipp Oeser self-assigned this 2022-08-23 09:34:56 +02:00
This issue was referenced by fd248e6bf9
This issue was referenced by fd248e6bf9947f4a1d9da07ebf788fbcf2018293
This issue was referenced by d269ad3535
This issue was referenced by d269ad3535950becd6904b30c44ad870485dcffe
Philipp Oeser changed title from Surface Deform Modifier does not display correctly in Edit Mode while a Vertex Group is assigned to the Modifier. to Regression: Surface Deform Modifier does not display correctly in Edit Mode while a Vertex Group is assigned to the Modifier. 2022-08-23 10:00:11 +02:00
Member
Reference: blender/blender#100578
