Display shows physics object original location during playback, not simulated location. #100601
Reference: blender/blender#100601
Operating system: Ubuntu 22.04.1
Graphics card: Nvidia RTX 2080
Broken: 3.2.2
Worked: unknown
I have a file/simulation where, during playback, physics objects briefly are displayed in their original (non-simulated) location. Manually advancing frames doesn't appear to cause the effect to occur (or occurs to briefly for me to notice). The initial sim that builds the cache doesn't cause it to occur (although that runs about as fast as the playback).
This doesn't appear to affect rendering. The physics simulation itself appears otherwise correct.
Screencast from 08-23-2022 04:53:18 PM.webm
I don't have a "safe" file to share publicly, despite attempts at a repro - these are corporate assets. I can probably share them privately, if necessary. The problem is that the issue appears at least partially resource-dependent, so may not reproduce on other machines anyways....
Both of the meshes in the scene are convex hull rigid bodies, with an additional collision modifier (to interact with softbodies). They have a child body with a geometry node tree.
Added subscriber: @Clockwork-Muse
Thanks for the report. Simple .blend file will help us to investigate this further
Sure, is there a way to privately upload/share the file? I don't want it on the public tracker.
Hi, I would suggest to make a simple version of file so that it'll be available publicly and more people can look into the issue.
Also reproduces on:
Operating system: Windows 11 - Dell XPS 15 9500
Graphics card: Nvidia GeForce GTX 1650 Ti
Broken: 3.2.2
Worked: unknown
Okay, I've managed to remove the original mesh geometry, and as much of the file as I can. If I change anything else the issue stops reproducing.
carton.001
(the mesh that doesn't display this issue).There appears to be a dependency cycle due to the use of the collision modifier; however, this doesn't seem to be the sole cause, because as near as I can tell it's intended to have both the collision modifier and rigid body physics on an object, plus the start of this file had multiple objects with both, but only
carton.002
showed this behavior...During simplification there were times when manual frame advance did retain the original item location. However, I haven't been able to check whether it would render with the incorrect location.
repro_simplified.blend
Side note - I have now gotten instances where it renders in the initial placed location as well. Note that parented objects may or may not be affected - some with geometry nodes show the nodes where I expect the simulated location to be, but some cases where there are multiple sub-objects have only some of them in the simulated location (and the rest in the initial location).
Added subscriber: @OmarEmaraDev
I can reproduce the issue in 3.2, but not on the latest version of Blender. Can you confirm that by trying a build from https://builder.blender.org/?
Yes, this appears to be fixed with nightly as well.
Probably for the same reason/commit as #100656.
