Blender not loading correct #100739
Closed
opened 2022-08-31 21:59:18 +02:00 by Miguel · 15 comments
Operating system: AMD Atlhon 3000G unknown.png
16GB RAM
Graphics card: Radeon Vega 3
Broken: all
Worked: no version
when I start blender, it doesn't load the textures correctly, and also leaves everything stretched
I haven't used Blender for a while, and yesterday when I went to open it I came across this error
**System Information** Operating system: AMD Atlhon 3000G ![unknown.png](https://archive.blender.org/developer/F13442269/unknown.png) 16GB RAM Graphics card: Radeon Vega 3 **Blender Version** Broken: all Worked: no version **Short description of error** when I start blender, it doesn't load the textures correctly, and also leaves everything stretched I haven't used Blender for a while, and yesterday when I went to open it I came across this error **Exact steps for others to reproduce the error** when I start blender
Author
Added subscriber: @Alenda
#100762 was marked as duplicate of this issue
Added subscriber: @iss
Please download alpha build from https://builder.blender.org/download/daily/ and run blender_debug_log.cmd. After you close Blender, upload 2 created files.
Please download alpha build from https://builder.blender.org/download/daily/ and run `blender_debug_log.cmd`. After you close Blender, upload 2 created files.
Author
This comment was removed by @Alenda
*This comment was removed by @Alenda*
Thanks for info. Your GPU driver is up to date. Can you download alpha build from https://builder.blender.org/download/daily/ and check if that will be any better?
If that won't work I can only recommend trying to download older version from https://www.blender.org/download/previous-versions/. Knowing which version is last working would be useful too.
Thanks for info. Your GPU driver is up to date. Can you download alpha build from https://builder.blender.org/download/daily/ and check if that will be any better? If that won't work I can only recommend trying to download older version from https://www.blender.org/download/previous-versions/. Knowing which version is last working would be useful too.
Author
Author
thanks for the help, I'll try the other versions to see if any works, if not no problem
> In #100739#1410763, @iss wrote: > Thanks for info. Your GPU driver is up to date. Can you download alpha build from https://builder.blender.org/download/daily/ and check if that will be any better? > > If that won't work I can only recommend trying to download older version from https://www.blender.org/download/previous-versions/. Knowing which version is last working would be useful too. thanks for the help, I'll try the other versions to see if any works, if not no problem
Added subscriber: @deadpin
This is probably the same as #100096 - the new AMD driver versions seem broken for many people.
Member
Member
This is indeed same as #100096
system-info file @Alenda had uploaded earlier: F13442475
This is indeed same as #100096 system-info file @Alenda had uploaded earlier: [F13442475](https://archive.blender.org/developer/F13442475/blender_system_info.txt)
Member
Closed as duplicate of #100096
Member
Added subscriber: @kisielino3
5 Participants
Reference: blender/blender#100739
