Memory leak in particular file containing vdb #101240
Open
opened 2022-09-21 06:22:58 +02:00 by Tommy fei · 12 comments
Operating system:win11
Graphics card:3070ti,cpu 12700H
Broken:3.3.0,0759f671celf,master,2022-09-06 15:39
Worked:null
After opening the model and exiting without doing anything, the following memory leak message will be printed in the system console window on exit
  • Open the uploaded file and close it without any additional operation
  • Notice the memory leak info in console.
    Deleting VDB files from the file doesn't result in memory leak
    fantasy_castal_final_contents.blend
**System Information** Operating system:win11 Graphics card:3070ti,cpu 12700H **Blender Version** Broken:3.3.0,0759f671celf,master,2022-09-06 15:39 Worked:null **Short description of error** After opening the model and exiting without doing anything, the following memory leak message will be printed in the system console window on exit ![image.png](https://archive.blender.org/developer/F13537226/image.png) **Exact steps for others to reproduce the error** - Open the uploaded file and close it without any additional operation - Notice the memory leak info in console. Deleting VDB files from the file doesn't result in memory leak [fantasy_castal_final_contents.blend](https://archive.blender.org/developer/F13550147/fantasy_castal_final_contents.blend)
Author
Added subscriber: @Tommy-fei
#101243 was marked as duplicate of this issue
Member
Member
Member
Hi, thanks for the report. 2GB file is way more for the investigation. Please simplify the file as much as you can.
Normally .blend files can be simplified by removing most objects and disabling settings, until the problem reveals itself more clearly.
Hi, thanks for the report. 2GB file is way more for the investigation. Please simplify the file as much as you can. Normally .blend files can be simplified by removing most objects and disabling settings, until the problem reveals itself more clearly.
Author
Hi, I have simplified the model and found that it is the file packed inside the blend that has this problem, presumably it is this vdb file, do you have any suggestions from your side?
Hi, I have simplified the model and found that it is the file packed inside the blend that has this problem, presumably it is this vdb file, do you have any suggestions from your side? [fantasy_castal_final_contents.blend](https://archive.blender.org/developer/F13550147/fantasy_castal_final_contents.blend)
Member
Member
VDB files seems responsible. Deleting them doesn't cause the memory leak.
Pratik Borhade changed title from Not freed memory blocks to Memory leak in particular file containing vdb 2022-09-22 06:46:25 +02:00
Author
I seem to need this for my model, is there any other way if I don't delete it?
> In #101240#1420979, @PratikPB2123 wrote: > VDB files seems responsible. Deleting them doesn't cause the memory leak. I seem to need this for my model, is there any other way if I don't delete it?
Author
I also tried creating a new blend project and found that if I pack other vdb files inside blend there is also a memory leak, can this be fixed please? Thank you very much!
> In #101240#1420979, @PratikPB2123 wrote: > VDB files seems responsible. Deleting them doesn't cause the memory leak. I also tried creating a new blend project and found that if I pack other vdb files inside blend there is also a memory leak, can this be fixed please? Thank you very much!
Member
From where you got these vdb files?
Author
I downloaded the vdb file from this site
https://jangafx.com/software/embergen/download/free-vdb-animations/
> In #101240#1421011, @PratikPB2123 wrote: > From where you got these vdb files? I downloaded the vdb file from this site https://jangafx.com/software/embergen/download/free-vdb-animations/
Philipp Oeser removed the
label 2023-02-10 08:43:43 +01:00
Reference: blender/blender#101240
