Importing file after making a new collection active hits an assert (View Layer Object Base out of sync) #101394
7 Participants
Reference: blender/blender#101394
Simplified Report
viewlayer_bug.blend
The script is as follows:
Original Report
Graphics card: NVIDIA GeForce RTX 3090/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 516.59
Broken: version: 3.4.0 Alpha, branch: master, commit date: 2022-09-21 22:34, hash:
20dc8393192f
Worked: version: 3.4.0 Alpha, branch: master, commit date: unknown, hash:
e1a9c16176df
-windows.amd64-releaseShort description of error
If you create a collection via python, in the code just after that, if you try to make it active, python will throw an error.
I think it must be a recently introduced bug, because you can actually see the collection in the outliner, and if you try the same code ( the make active collection part ) in a separate script execution, the code works.
To help, i suggest that maybe it can be related to recently introduced funcionality of lazy loading here? https://developer.blender.org/rB68589a31ebf
I suspect that because i´m trying to access to the viewlayer, and in fact, after executing the code, then you can use the exact same code just commenting the creation part ( collection creation code on the first line just worked ), then it works.
The code:
Just exectute the script in the file attached, it will throw the error. As mentioned above, after the first fail, if you comment the 2 first lines of code and execute it again ( because the collection its already created ) now it works.
It seems to be that the viewlayer isnt accessible even if its already created, like it needs blender to refresh the UI or something?{F13580347}
Added subscriber: @JVM
Added subscriber: @OmarEmaraDev
I guess that is the same as #101272. Which was fixed today in
4a60c4746d
. Can you try tomorrows daily build that includes the fix and see if indeed fixes the issue?looks like it @OmarEmaraDev , i´ll take a look, thanks!
I tried with the last daily build, blender-3.4.0-alpha+master.788f3d72cf89-windows.amd64-release.
Now it doesn´t throw the error, but still failing to make the collection active, to making the objects inside this collection selected... anything related to this is now ignored.
Same behaviour as before though, if you execute the script again after all is created, it works, but not on the first try, so it must remain some other sections of code, that aren´t aware of the updates, not only the view layers.
This part after the collection creation is ignored on the first script execution:
No collection active, no objects inside the collection selected.
if you execute it again ( when the collection it´s already existing and you can see it from the outliner ), then this part works normally
there´s still some parts that need updating imho.
I am confused because the newly added collection doesn't have any objects yet, so how are you trying to select its object?
As for the collection being active, it seems to be working fine for me. How do you determine that it isn't?
Can you clarify those points?
I can´t share the entire script because is an in-house tool and property of the company i´m working on.
This chunk function is to create that temp collection to import a USD file on it, make it active, then import the USD and finally select every object inside this collection.
The important thing here is that same code chunk worked before view layer changes, so the update fix must be incomplete somewhere.
On the last build, this same code does not select anything inside it and didn´t make the collection active.
Trying to make active a collection created in python failsto Importing file after making a new collection active hits an assert (View Layer Object Base out of sync)Changed status from 'Needs User Info' to: 'Confirmed'
Added subscriber: @Jeroen-Bakker
Assert is introduced by
68589a31eb
.During loading a scene can be copied. The original scene should be already be in synced before calling copy, because copy only accepts a ready only source scene.
Will try to reproduce to find the exact stack trace.
Added subscribers: @mont29, @monique
Analyzed the blend file and have the following question and remark:
A way to solve this could be that depsgraph syncs all viewlayers before copying. Or we could mark all dest viewlayers "dirty" when copying and remove the assert.
I would suggest the 2nd solution, but would like to hear from @mont29
Added subscribers: @Sergey, @dr.sybren
I think the depsgraph should ensure all view layers from all scenes it 'handles' are in sync when it starts an update process. Reason being, depsgraph expects valid 'static' data to work on (for relations building etc.), so imho one cannot expect it to work with non-updated 'dirty' viewlayers at all? @dr.sybren , @Sergey, maybe you have better insight here?
I am not sure what exactly it means. If the construction of depsgraph is somehow called on an invlaid state of the view layers, then the proper solution is to hide such access behind an API. To me it does not seem to be a good design to require all areas which needs to acccess view layers to ensure re-syncing of any kind. If it is something what needs to be done during evaluation, then it should follow typical tagging process. Depsgraph evaluation should not make decision to re-sync anything if it was not tagged for.
Reading both viewpoints, a solution can be to perform a sync on all view layers when copying the scene.
This issue was referenced by
4c320e2639
Tested today with blender-3.4.0-alpha+master.760a6aa1f5d6-windows.amd64-release
now blender crashes without throwing any error...
@JVM does the crash relates to this fix? If so can you include the file/script you are testing with?
@monique It is the same code included on the original report above, but now is directly crashing blender... so i can´t know exactly which part of the script is the culprit of the crash.
I´ll try to find some time tomorrow to test with a newer buildbot release, just to make sure that the issue isn´t related to a bad build... and if not, on monday i´ll try to debug manually my code to find out.
@monique I´ve debuged my code and for me it seems like the same problem.
Just after importing a USD file into my "TEST_COLLECTION" as before :
1- On the working blender version, all objects inside the "TEST_COLLECTION" collection were selected automatically right after the import for you, now this doesn´t work
2- If you try to force it, this doesn´t work either :
After that, my code relies on this selection, so it fails because nothing on the collection created previoulsy can be selected.
If you try to execute the exact same code in the script editor after the first execution, it works as expected, so its a refresh thing again.
If I understand your reply correctly the next script should fail, but after a factory-startup this seems to work on
954b834053
. Please correct me where I didn't understand it correctly.cubes.usdc
We also tried this when having multiple view layers. Can you try this?
Now this part it´s working on the las build from buildbot i´m using ( Broken: version: 3.4.0 Beta, branch: master, commit date: 2022-11-14 01:01, hash:
0190b104c8
)But unfortunately, i´ve found another one that can be related somehow with a lack of refresh on the view layer here ( https://developer.blender.org/T102550 )
Thanks!
