CUDA ERROR AT RAMDOM TIMES #101587
Closed
opened 2022-10-04 11:09:18 +02:00 by Morgane · 16 comments
Operating system: Windows-10-10.0.19044-SP0 64 Bits
Graphics card: NVIDIA GeForce RTX 3080 Laptop GPU/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 517.48
Broken: version: 3.3.0, branch: master, commit date: 2022-09-06 15:39, hash: 0759f671ce
Addon Information
Name: Cycles Render Engine ()
Author:
When I try to render or navigate in render mode (even for a simple scene), got random CUDA errors (failed to create cuda context is the most frequent error) I tryed EVERYTHING (I even reinstalled windows/ graphic drivers/ cuda drivers/ better settings in Nvidia panel/ studio AND game ready drivers) and I don't know how to use my GPU correctly in Blender anymore...
Activate blender cycles engine with both CUDA or OPTIX, with both CPU & GPU or just GPU (I tested everything) and try to navigate in render mode or render an image
Made with simples scene with 2 panel lights, a human mesh and a ground panel
blender_system_info.txt
creepy house_15920_autosave.blend
blender_debug_output.txt
**System Information** Operating system: Windows-10-10.0.19044-SP0 64 Bits Graphics card: NVIDIA GeForce RTX 3080 Laptop GPU/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 517.48 **Blender Version** Broken: version: 3.3.0, branch: master, commit date: 2022-09-06 15:39, hash: `0759f671ce` Worked: (newest version of Blender that worked as expected) **Addon Information** Name: Cycles Render Engine () Author: **Short description of error** When I try to render or navigate in render mode (even for a simple scene), got random CUDA errors (failed to create cuda context is the most frequent error) I tryed EVERYTHING (I even reinstalled windows/ graphic drivers/ cuda drivers/ better settings in Nvidia panel/ studio AND game ready drivers) and I don't know how to use my GPU correctly in Blender anymore... **Exact steps for others to reproduce the error** Activate blender cycles engine with both CUDA or OPTIX, with both CPU & GPU or just GPU (I tested everything) and try to navigate in render mode or render an image Made with simples scene with 2 panel lights, a human mesh and a ground panel [blender_system_info.txt](https://archive.blender.org/developer/F13614497/blender_system_info.txt) [creepy house_15920_autosave.blend](https://archive.blender.org/developer/F13614496/creepy_house_15920_autosave.blend) [blender_debug_output.txt](https://archive.blender.org/developer/F13614495/blender_debug_output.txt)
Author
Added subscriber: @Morgane-DANO
Member
Member
Member
Thanks for the report. What error you've been getting? Could you share it?
open Blender's installation directory and double click on the blender_debug_gpu.cmd. This will start Blender in debug mode and create log files. Try to reproduce the error
again. Once it crashes or you close Blender manually the Windows Explorer should open and show you up to two files, a debug log and the system information. Add them to your
bug report by clicking on the upload button as shown in the screenshot below or via drag and drop. Please also upload the crash log located in C:\Users\[your username]\AppData\Local\Temp\[project name].crash.txt (or simply type %TEMP% into the path bar of the Windows Explorer).2019_12_04_upload_icon_developer_blender_org.png
Thanks for the report. What error you've been getting? Could you share it? > open Blender's installation directory and double click on the `blender_debug_gpu.cmd`. This will start Blender in debug mode and create log files. Try to reproduce the error > again. Once it crashes or you close Blender manually the Windows Explorer should open and show you up to two files, a debug log and the system information. Add them to your > bug report by clicking on the upload button as shown in the screenshot below or via drag and drop. Please also upload the crash log located in `C:\Users\[your > username]\AppData\Local\Temp\[project name].crash.txt` (or simply type `%TEMP%` into the path bar of the Windows Explorer).![2019_12_04_upload_icon_developer_blender_org.png](https://archive.blender.org/developer/F8190038/2019_12_04_upload_icon_developer_blender_org.png)
Author
@PratikPB2123 thank you, I'll do that and get back to you as soon as I can. Have a good day.
Author
Here's the files you asked for, not sure if the temp file is the correct one, but this was the only file with the correct name I found there.
[blender_system_info.txt](https://archive.blender.org/developer/F13614497/blender_system_info.txt) [creepy house_15920_autosave.blend](https://archive.blender.org/developer/F13614496/creepy_house_15920_autosave.blend) [blender_debug_output.txt](https://archive.blender.org/developer/F13614495/blender_debug_output.txt) Here's the files you asked for, not sure if the temp file is the correct one, but this was the only file with the correct name I found there.
Member
Member
Member
Hi, thanks for the information.
I'm not able to replicate the error. What exactly are reproducing steps? just render an image? Do I need to change render properties before the final render?
Please check CPU + GPU usage during the rendering.
Did you try to replicate the error with factory settings: {nav File > Defaults > Load Factory Settings}
Hi, thanks for the information. I'm not able to replicate the error. What exactly are reproducing steps? just render an image? Do I need to change render properties before the final render? Please check CPU + GPU usage during the rendering. Did you try to replicate the error with factory settings: {nav File > Defaults > Load Factory Settings}
Author
It's very complicated because this error is just random, sometime it happens with the same file sometimes not. Sometimes with complicated files sometimes just with a simple one. However, it always hapen with minimum 10 min spent working on the file. This error occur both in render mode work and when I want to final render.
Yes I tried with factory settings too when I upgrated to the newest version. This happen since version 2.8 I suppose.
Did you found something in the error report ?
Could it be caused be a shader addon not loading correctly ?
It's very complicated because this error is just random, sometime it happens with the same file sometimes not. Sometimes with complicated files sometimes just with a simple one. However, it always hapen with minimum 10 min spent working on the file. This error occur both in render mode work and when I want to final render. Yes I tried with factory settings too when I upgrated to the newest version. This happen since version 2.8 I suppose. Did you found something in the error report ? Could it be caused be a shader addon not loading correctly ?
Member
Member
Add-on would not be a culprit here since you're able to confirm the issue with factory reset.
This is still unclear to me
Have you tweaked GPU settings recently?
> Could it be caused be a shader addon not loading correctly ? Add-on would not be a culprit here since you're able to confirm the issue with factory reset. > What exactly are reproducing steps? just render an image? Do I need to change render properties before the final render? This is still unclear to me Have you tweaked GPU settings recently?
Member
Member
Hi, any updates?
Hi, any updates?
Member
Member
No activity for more than a week. As per the tracker policy we assume the issue is gone and can be closed. Thanks again for the report. If the problem persists please open a new report with the required information.
2 Participants
Reference: blender/blender#101587
