Multi-GPU rendering crashing #101758
2 Participants
Reference: blender/blender#101758
Operating system: Ubuntu 22.04
Graphics card: nVidia A10 x 4
Broken: 3.1.1
Worked: N/A
Doing command line rendering with --cycles-device CUDA on a multi-GPU machine results in a core dump and blender crash. Running the same command with a single GPU machine results in successful renders.
I have developed a remote rendering system to perform rendering on cloud infrastructure. The heart of the system is Blender, taking advantage of the command line rendering capability.
I have a multi-GPU system with 4 nVdidia A10 graphics cards, CUDA 11.7 fully setup and the latest drivers. I perform the rendering in a docker image where Blender 3.3.1 is installed at /usr/local/blender. The script that’s running inside calls the command line:
If I run this docker passing only a single GPU into the image, it runs perfectly and outputs a rendered image. If I pass it multiple GPUs though, the rendering appears to run, but when Blender goes to save the output file I get an error:
I’ve verified that other CUDA workloads work with multiple GPUs both on the base machine and inside the docker image. This is the only things that’s breaking.
I ran the command with --debug-cycles enabled and the full output is attached as log.txt
log.txt
Added subscriber: @Nathan-Huntoon
Hi, thanks for the report. Uploaded Log file doesn't contain any relevant information of the crash.
I'm not sure if this is an issue in Blender or the docker container you're running on remote machine. But rendering in multi-GPU device has some work scheduling issues I guess. see: #89833 (Cycles: multi-device rendering performance) and #95687 (Cycle CPU + GPU hybrid path tracer)
Does this happen with "any" blend file and when Optix is used for GPU acceleration.
