Freeze on performing any operation when compositor tab is open #101861
6 Participants
Reference: blender/blender#101861
Operating system: Windows-10-10.0.19044-SP0 64 Bits
Graphics card: NVIDIA GeForce RTX 2080 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 516.40
Broken: version: 3.3.1, branch: master, commit date: 2022-10-04 18:35, hash:
b292cfe5a9
Freeze on performing any operation when compositor tab is open.
Subsurf modifier seems important for redoing the issue
This is the continuation of #99695
The Bug in #99695 was fixed, but there seems to be more conditions which make the Compositor slow.
Dorian from Scatter5 was so nice and made again a simplified version of a secene with the bug.
The slowdown caused by an unkown combination of geometry nodes, which makes the Compositor unusable slow.
COMPOSITOR SLOW.blend
Added subscriber: @Rincewind3D-1
#103054 was marked as duplicate of this issue
Added subscriber: @mod_moder
This is a slightly simplified version. Please write in detail about what exactly your cryptomat layers are. As I understand it, their number correlates with the load.
It is also a prerequisite that an object with geometry nodes be in the collection.
COMPOSITOR SLOW (2).blend
The cryptomate layers are just node example. You can use any other nodes in the compositor to get the slowdown.
Open the file. Check the lags. Delete your layers. There are no lags. Describe what exactly you have indicated in these layers?
Indeed, your simplified file improved the lags massiv, but there are still there, but hardly noticable.
There is still some minor delay if add/remove or connect nodes in the compositor.
I recommend for analyzing the original file, after there the lag is more obvious.
I did a video from your simpified version.
You see, it's still lagging a bit.
The issue is propably connected to the complexity of the mesh in the scene which are used by the geo nodes.
blender_TXPgGfnqEI.mp4
I am not affiliated with a cryptomat. I don't know what this property is. And I don’t understand what kind of python the script is introduced in it. But the problem is with him. To more correctly name the problem, tell us what it is.
2022-10-16 20-57-49.mp4
Although I think I get it. If you move the object to another collection, there are no lags. It looks like you somehow specified a collection as a data source for the cryptomat. This in turn triggers an update each time.
+I won't be able to correctly fill out this report, so I hope I helped one of the render moderators with my investigation of this file.
Again, this issue should not be caused by Cryptomatte. I guess you can disable Cryptomatte completly and you still have the lag.
the issue is somehow caused by the geometry node which are attached to the "Some Geonodes" mesh. Those are referencing the mesh inside the collection.
Something inside the geo-nodes is causing the slowdown.
The geo-nodes are originally generated by Scatter5 (Blender addon). The creator from Scatter5 was so nice and simplified is geo-nodes as good as possible to make it easier to analyze why Blender has here this strange slowdown.
I guess the slowdown is based on the complexity of the mesh, inside the collection.
Sorry. I reviewed your file for problems with geometry nodes from the very beginning. After not finding them, I discovered that the cryptomat layer causes the collection to be recalculated every composer update. I am not affiliated with the composer and cryptomat. But the nodes of geometry do not count here. Here is the new version of the file. It contains nothing but
So I think the problem is somewhere in this. or in your script embedded in the cryptomat layer. But I will not be able to expand on this topic further, since this is not my area of activity.
Changed status from 'Confirmed' to: 'Needs Triage'
Changed status from 'Needs Triage' to: 'Needs Developer To Reproduce'
I'm able to redo this. Memory usage rises on performing any operation while compositor tab is open.
Reason is unclear to me so forwarding this report to devs
Removal of Subdivision surface modifier did solve the issue
Geometry nodes executes superfluously when the compositor node tree change Part 2to Freeze on performing any operation when compositor tab is openAs mentioned before, I guess it's a weird bug which is caused by the Geo Nodes in combination with complex geometry.
This issue is hunting me since I started to use Scatter5 and I already regocnized that that this lag appears more likley in scenes where my scattered objects have a more complex mesh.
This means, removing Subdivision surface modifier just treats the symptom ;)
No geonode error. You just made a modifier on a hidden tree model. Her subdiv has led to this 9 times. And this is called by updating the cryptomat layer
I delet this in my version
Please stop confusing people.
You can apply the subdivion modifier and disable Cryptomatte and you still get the slowdown.
But if you delete the "Pine V1 07" mesh and add to the collection a simple object (like a plane) the slow down is gone.
The Mesh inside this collection is referenced by a geo-node system, which is somehow responsible for the slowdown.
Hi, I'm not really sure how Geometry node tree is involved in this. Your file only has one GN tree of disconnected Group input+output node
I tried to simplify your file. Now it only has
Object
collection andPine V1 07
object. Freeze is also avoidable by moving the object outside of the collection#101861-simplified.blend
@Rincewind3D-1, could you share the exact way to recreate the file from scratch?
Did you import the model from somewhere with
Object
collection?@PratikPB2123 If you're interested, I've already done the simplification, my version can be found above
Added subscriber: @BD3D
OK, I found out something pretty weird.
I guess there are multiple triggers which are causing the compositor lag.
For the scene I shared here, it seems to be the subdivion modifier.
As soon I remove the subdivion modifier or disable the render toggle
the compositor is fast again.
If I load the original tree to a new scene I get also a (smaller) compositor lag, until I disable or remove the subdivision modifier.
Also appliyng the subdisvion modifier fixes the lag.
But there's still a second issue, which seems to be connected to the geo-nodes created by Scatter5.
Unfortunatelly this issue dosn't seem to be reproducable in this file.
If I open my original scene, where the issue occured and remove there the subdivison modifier from the trees, the lag improves darmatically, but is still not complelty gone.
This issue is verly likly caused by the geo-node setup.
@BD3D was so nice and somplified my original scene. So I can't you sent easily a simplified new version of the with the lag without the subdivion modifier. I guess Dorian removed the issue which is causing the geo-node slowdown in the simplified version from this issues, after we weren't are that also the subdivision modifier of some meshes are *addtionally causing slowdowns.
Btw, I'm not the only person who is getting Slow Downs in the compositor using the Scatter5 node system. At least on other user on the Scatter5 Discord told that he has in some scenes also Compositor lags.
The tree asset is from DAZ Studio and converted to Blender. I added this tree asset pack to my Asset Browser.
I guess we should focus in this ticket on why subdivision are causing a lag. And once this is fixed take again a look on the presumed geo-node slowdown.
Please, do we have a specific file with a problem, or is the problem still in the cryptomat and the layer script?
Added subscribers: @Tyrexchip, @OmarEmaraDev
just want to mention that I still have regularly new scenes where I can‘t use the compositor tab because of this issue.
I‘m surprised that there are no duplicates if this issue, after it seems to happen for me pretty regularly in new scenes.
good news, the problem described in this ticket seems to be solved in 4.1.
The files from this ticket are running now quick in 4.1.
But I've still some project (which I can't share) files where the compositor is super slow.
I will close this issue for now and open a new one as soon if I figure out what else is causing the slowness in Blender 4.1+
ah, I can't close this one, after I created it with an count which I no longer have access.
Problem might still there in 3.3/3.6LTS
Not sure if it would be fixed for LTS versions as well.
Not sure if older versions will get this one fixed.
I personally guessing that this one was not fixed with intention. Probably it's a side effect of all the performance optimizations done in the last time.
Most likely, yes. closing then.
