Startup EXCEPTION_ACCESS_VIOLATION crash on Windows 10 with newer NVidia drivers #102114
5 Participants
Reference: blender/blender#102114
Operating system: Windows 10 Build 19044
Graphics card: NVIDIA GeForce GTX 1060 6GB/PCIe/SSE2
Broken:
Win10 - 3.2.0, hash:
e05e1e3691
Win10 - 3.3.2 Release Candidate, hash:
2a7b8e78e1
Win10 - 3.4.0 Alpha, hash:
e75be000e3
Worked:
Win 8.1 - All versions above
Win 10 - Unknown
Blender will crash silently every N startups (varies with Blender and driver versions) on Windows 10. Using
blender_factory_startup.cmd
showsEXCEPTION_ACCESS_VIOLATION
errors when it crashes.I don't know since when it's happening, it's been a while since I've used Blender. New versions were released and I updated my GPU driver in the meanwhile. I started to try different GPU drivers after comparing the Blender behavior in Windows 8.1, where I couldn't make it crash no matter the Blender version tried.
Newer drivers and newer builds have a significantly higher chance of crashing on Win 10. There's the possibility this is not new behavior, but I didn't notice it because it's significantly harder to make it crash on older drivers. Example:
Win 8.1, 3.4.0 Alpha, NVIDIA 473.04 - 25 tries, no crash
Win 10, 3.4.0 Alpha, NVIDIA 516.59 - crash every ~3 tries
Win 10, 3.4.0 Alpha, NVIDIA 472.12 - crash every ~22 tries
I'm using the most recent driver available for Win 8.1, which was released in January. Trying a similar version for Win 10 makes Blender more stable, but the debug_output is empty when it crashes.
I ran
chkdsk
,dism /restorehealth
, andsfc /scannow
in Win 10 for good measure, no errors found.I've attached two sample outputs from a crash in which the debug file isn't empty + another from a different crash when running the gpu debug cmd.
blender_debug_output.txt
blender_system_info.txt
blender_debug_output_(gpu).txt
Added subscriber: @crowe
Added subscriber: @OmarEmaraDev
Can you attach the actual crash file found in
C:\Users\Crowe\AppData\Local\Temp\blender.crash.txt
?Sorry, forgot to attach these! Unfortunately all stack traces show Symbols not available, but I've automated the blender startup and log collection proccess if it crashes, so here are two crash startup log examples with files containing most info.
1
blender.crash.txt
2
blender.crash.txt
I see. I am not sure what might be causing that.
Added subscriber: @LazyDodo
Can't reproduce on win10/516.59 on a 1660 tried about 30 times...
Hi, thanks for the report. Does it happen in default cube file? when does this happen (I mean do you've any particular reproducing case)?
Have you recently tweaked GPU settings? Crash log doesn't contain more relevant information so not sure what is the real cause.
Hi, any updates?
