Group Index input for the fill curve node #102285
6 Participants
Reference: blender/blender#102285
Add a "Group ID" integer input to the node, evaluated on the curve domain.
This will allow limiting intersections between separate curves, which can be helpful
as a performance optimization and for a simpler result.
The default value should be a single value of zero, and the number button should be hidden on the node.
To fill each curve separately, the "Index" node can be connected the group index.
Implementation
do_cdt
can have a newIndexMask
argumentMultiValueMap
to find groups of related indicesIndexMask
and map can be skippedChanged status from 'Needs Triage' to: 'Confirmed'
Added subscriber: @mod_moder
Added subscriber: @Swesik-Ramineni
Hello, I'm brand new to the Blender developer community and was hoping to work on this issue, but I was confused about a few points. What exactly is the "Group Index", how does it relate to the IndexMask, and what are these supposed to do in do_cdt exactly? Thank you in advance for any guidance.
@Swesik-Ramineni The group index is the key that the individual curves have. By concatenating the indices of curves with the same key into one array to obtain from its
IndexMask
(standert iterator factory, what know span of indices), we can iterate over all curves of single key. Due to this, it is possible to split all curves into severalIndexMask
and generate for each key its own instance - geometry from a set of filled curves.Thank you so much for the response. Just to clarify, for each index in IndexMask, I should append the evaluated points of the curve at that index to a new curve, which I pass as an input to delaunay_2d_calc?
The whole task is reduced to sweeping this iterator constructor over the entire list of curves (
index_range
) to an externalIndexMask
pointing to the list of curves belonging to the group.{https://developer.blender.org/diffusion/B/browse/master/source/blender/nodes/geometry/nodes/node_geo_curve_fill.cc$53}
(Of course, this is only a cursory answer to the question. I'm afraid if you write down everything that needs to be changed, then it will just be a diff patch to implement this)
@Swesik-Ramineni Also, if you have any more questions, you can always ask them in the geometry nodes chat to those who are online there (me, hans, and others)
Added subscriber: @emilis
FYI, I've picked this up, and I believe I have it working locally for regular curves. I just need to extend the behavior to grease pencil curves, since the Fill Curve node recently gained support for those via #113602.
Ack, I'm not able to create a test
.blend
file for the grease pencil because GPv3 is currently very broken on MacOS: #113601I get the sense that's not expected to be fixed particularly soon, so I will see if I can get someone else to create a simple test file for me.
I was able to work around the current GPv3 issues on MacOS well enough to be able to verify my implementation works for GPv3. The PR is #114048.
@HooglyBoogly, I just noticed this issue is still open, but I assume you meant to close it when you merged in #114048.
Right, thanks!
