Blender crashes frequently when rendering Smoke Simulation (Manta Flow) with Cycles using GPU #102491
Reference: blender/blender#102491
Operating system: Windows-10-10.0.22000-SP0 64 Bits
Graphics card: NVIDIA GeForce RTX 3080/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 526.86
system-info.txt
Broken: version: 3.4.0 Alpha, branch: master, commit date: 2022-10-03 00:19, hash:
d4d40f3b69
Blender crashes frequently when rendering Smoke Simulation (Manta Flow) with Cycles using GPU, when configured with either CUDA or OptiX, having checked both the CPU (Ryzen 7 3700X) and GPU (Nvidia GeForce RTX 3080). It looks like it only crashes when both checkboxes are activated.
I think this strongly depends on the Hardware I'm using.
Added subscriber: @Facu
Hi, thanks for the report. Please check again in newer development build: https://builder.blender.org/download/daily/
I tried to redo it locally with
Quick Liquid
but didn't get the crashCrash may not be hardware specific. Please also upload crash logs:
Open Blender's installation directory and double click on the
blender_debug_gpu.cmd
. This will start Blender in debug mode and create log files. Try to reproduce the error again. Once it crashes or you close Blender manually the Windows Explorer should open and show you up to two files, a debug log and the system information. Add them to your bug report by clicking on the upload button as shown in the screenshot below or via drag and drop. Please also upload the crash log located inC:\Users\[your username]\AppData\Local\Temp\[project name].crash.txt
(or simply type%TEMP%
into the path bar of the Windows Explorer).blender_debug_output.txt
blender_system_info.txt
I tried it on the latest version of 3.5.0 Alpha and had to try a few times in order to reproduce it. I did reproduce it when I increased a little the Resolution of the Smoke Simulation. Here are the two logs files as requested. Regarding the other crash.txt file, I din't find it in the Temp directory.
Please let me know if you need anything else.
hi, thanks for the information. Does this happen in particular blend/volume file? say
Grinder16.blend
in this case? Could you attach it?Perhaps crash happens due to high memory usage? Can you observe hardware utilization and memory usage at the time of crash?
I could not find any information associated with crash in log file.
Hi, I'm not sure if this only happens in a partular blend/volume file. I'm sorry but I can't provide this file, is for a client. I will check the memory usage and the hardware utilization, and try to reproduce it in a new file. I'll let you know when I find out something.
Hi, any updates?
