Regression: Cursor arrow shows up after fill operation execution #102650
Closed
opened 2022-11-21 07:21:23 +01:00 by Pratik Borhade · 22 comments
Member
Operating system: Windows-10-10.0.22000-SP0 64 Bits
Graphics card: NVIDIA GeForce RTX 3050 Laptop GPU/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 512.78
Broken: 3.5
Worked: 3.3
Change in cursor behavior came with bf85074148
Cursor arrow appears after performing fill operations. It'll disappear again when cursor is moved over other area
I guess only circular point with red outline is expected when tool is selected
  • Open uploaded file
  • Select fill tool (notice cursor)
  • Attempt to fill closed region
  • After filling the closed area, default cursor arrow appears
  • Move cursor over other area (cursor arrow is gone now)
    #102650.blend
System Information Operating system: Windows-10-10.0.22000-SP0 64 Bits Graphics card: NVIDIA GeForce RTX 3050 Laptop GPU/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 512.78 **Blender Version** Broken: 3.5 Worked: 3.3 Change in cursor behavior came with bf85074148 **Short description of error** Cursor arrow appears after performing fill operations. It'll disappear again when cursor is moved over other area I guess only circular point with red outline is expected when tool is selected **Exact steps for others to reproduce the error** - Open uploaded file - Select fill tool (notice cursor) - Attempt to fill closed region - After filling the closed area, default cursor arrow appears - Move cursor over other area (cursor arrow is gone now) [#102650.blend](https://archive.blender.org/developer/F13954465/T102650.blend)
Author
Member
Member
Added subscriber: @OmarEmaraDev
Member
Can't reproduce on Linux X11 myself.
Member
Added subscriber: @lichtwerk
Member
Member
Can confirm, will check
Member
This seems to be a two-step regression:
  • fill tool now requires two clicks for the fill
  • cursor changes to default (as reported here)
This seems to be a two-step regression: - fill tool now requires **two clicks** for the fill - cursor changes to default (as reported here)
Added subscriber: @antoniov
No, you don't need two clicks... the reason is you have enabled the help lines, so the first click enable the help lines and with the wheel mouse you can change the size. The second click is the confirmation.
> In #102650#1448914, @lichtwerk wrote: > This seems to be a two-step regression: > - fill tool now requires **two clicks** for the fill > - cursor changes to default (as reported here) No, you don't need two clicks... the reason is you have enabled the help lines, so the first click enable the help lines and with the wheel mouse you can change the size. The second click is the confirmation.
[2022-11-21 09-58-19.mp4](https://archive.blender.org/developer/F13955213/2022-11-21_09-58-19.mp4)
Member
Ah, we are talking https://docs.blender.org/manual/en/3.5/grease_pencil/modes/draw/tools/fill.html#automatic-gap-closure
(sorry, wasnt aware of this new feature)
It is a bit redundant for already closed shapes like in this report, but will make myself familiar with the gap filling
> In #102650#1448916, @antoniov wrote: > No, you don't need two clicks... the reason is you have enabled the help lines, so the first click enable the help lines and with the wheel mouse you can change the size. The second click is the confirmation. Ah, we are talking https://docs.blender.org/manual/en/3.5/grease_pencil/modes/draw/tools/fill.html#automatic-gap-closure (sorry, wasnt aware of this new feature) It is a bit redundant for already closed shapes like in this report, but will make myself familiar with the gap filling
Member
thx for the video!
thx for the video!
Member
As for the cursor change in behavior: this came with bf85074148
Member
@antoniov: seems like the call to WM_cursor_set(CTX_wm_window(C), WM_CURSOR_DEFAULT); is redundant?
@antoniov: seems like the call to `WM_cursor_set(CTX_wm_window(C), WM_CURSOR_DEFAULT);` is redundant?
I don't think so except I miss something. When you do the first click, the cursor changes to a pencil cursor, but if you press MMB to change size of extend lines, the cursor chages while you move... as soon you release MMB the cursor back to pencil cursor.
> In #102650#1448945, @lichtwerk wrote: > @antoniov: seems like the call to `WM_cursor_set(CTX_wm_window(C), WM_CURSOR_DEFAULT);` is redundant? I don't think so except I miss something. When you do the first click, the cursor changes to a pencil cursor, but if you press `MMB` to change size of extend lines, the cursor chages while you move... as soon you release `MMB` the cursor back to pencil cursor.
Author
Member
Can we raise the priority since this is a regression? May not be a top priority issue.
Really I don't see the bug. If you enable visual aids you must use two clicks because the first is to start and the second to confirm...during this time the cursor must be the pencil, when you confirm, the cursor is reseted. If you disable visual aids is only one click and the cursor is reset perfectly also.
Really I don't see the bug. If you enable `visual aids` you must use two clicks because the first is to start and the second to confirm...during this time the cursor must be the pencil, when you confirm, the cursor is reseted. If you disable `visual aids` is only one click and the cursor is reset perfectly also.
Member
It should probably not be WM_CURSOR_DEFAULT though? (havent checked in depth though)
It should probably not be `WM_CURSOR_DEFAULT` though? (havent checked in depth though)
Author
Member
@antoniov ok, you mean cursor reset to default "arrow"?
But Later if I move mouse over other area (let's say properties panel), it'll remove the "default cursor arrow". Isn't this inconsistent? :)
> during this time the cursor must be the pencil, when you confirm, the cursor is reseted @antoniov ok, you mean cursor reset to default "arrow"? But Later if I move mouse over other area (let's say properties panel), it'll remove the "default cursor arrow". Isn't this inconsistent? :)
Philipp Oeser self-assigned this 2022-11-23 13:54:42 +01:00
Member
Got a fix
Got a fix
This issue was referenced by b0810f788c
This issue was referenced by b0810f788c9edb326300320d482502c5f5ea28e2
Member
5 Participants
Reference: blender/blender#102650
