Copy Rotation Constraint unexpectedly have numerical instability #102679
Reference: blender/blender#102679
Simplified Report
incorrectCopyRotationConstraint.blend
Original Report
Operating system: Windows 10, x64
Graphics card: GTX 1080
Broken:
e05e1e3691
,cac3e16cfb
,0759f671ce
Copy rotation from camera is inconsistant
Text.001 and asdfasd have linked animation, so they should essentially be the same.
constraintBug_v001.blend
Added subscriber: @candreacchio
Blender 3.2.1 - Copy Rotation from Camera inconsistantto Blender 3.2.1 - Copy Rotation Constraint from Camera inconsistantBlender 3.2.1 - Copy Rotation Constraint from Camera inconsistantto Copy Rotation Constraint unexpectedly have numerical instabilityChanged status from 'Needs Triage' to: 'Confirmed'
Thanks for the extra reference of this happening.
Whats even crazier, is with your extra file, if you select suzanne (that has the constraint). and then set the rotation to 4 degrees on the z axis... then it will invert.
Added subscriber: @ChrisLend
Can confirm, there seems to be an edge case.
I'd assume it is euler locking but none of the rotation order options seem to do anything
Edit: On the other hand, this might be working as intended
it is a bit clearer when you switch the cube with a suzanne like in this file
potential duplicate: https://developer.blender.org/T79118
not closing because I am not 100% sure
My original report is not the same, if you follow my instructions, it works correctly if it copies off a mesh, but not correctly if its copied off a camera (same animation)
sorry it makes no difference if the constraint points at the camera or not
the difference is that the rotation values between the two are different
camera: (91.1, -0.00..., z-animated)
text: (0,0, z-animated)
if you set the text to the same values you get the same result
I understand that yes your example doesnt matter if its on the camera or not. but my original report does not, which is the bug I am reporting.
I have copied pasted my example below for convience.
If the target is a mesh, it works fine. If the target is a camera, it does not. This is not the same as your report as your report doesn't matter if its a camera or not.
Added subscriber: @dr.sybren
@ChrisLend is right, though. The mesh object in your example file has a different rotation than the camera object, and thus the conclusion that the observed diffference must be caused by the object type (camera vs. mesh) unfounded. The difference in rotation is what matters here. Having a rotation such that one axis is (almost) mapped onto another (such as having X-rotation of 91°) is known to cause problems: Gimbal Lock.
I see this as a duplicate of #79118 indeed, in the sense that it is also caused by gimbal lock, and thus expected mathematical instability.
Closed as duplicate of #79118
