FBX export error because of invalid NaN UV values. #102783
7 Participants
Reference: blender/blender#102783
Operating system: Linux-4.15.0-51-generic-x86_64-with-glibc2.27 64 Bits
Graphics card: GeForce GTX 850M/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 390.143
Broken: version: 3.3.1, branch: master, commit date: 2022-10-04 18:35, hash:
b292cfe5a9
Worked: never
Export of an element from attached file in FBX format cause error until UV is not removed.
Tested on 3.2, 3.3.1, 2.79
3.2 fbx error.blend
Added subscriber: @1D_Inc
blender/blender-addons#103583 was marked as duplicate of this issue
#103476 was marked as duplicate of this issue
Screenshot of an error
Added subscriber: @scurest
Cf #79775
Added subscribers: @lichtwerk, @PratikPB2123
@lichtwerk , looks like issue #79775 is not resolved yet
Added subscriber: @96artem1
Removed subscriber: @scurest
Added subscribers: @JJC, @mod_moder
Added subscriber: @Mysteryem-2
Added subscriber: @mont29
Changed status from 'Confirmed' to: 'Needs User Info'
For the records, this is NOT an issue in the FBX code, but in Blender, as stated in #79775, there should be no NaN values in mesh data, this is no valid data.
Would also be good to have info about how that .blend file was generated, we cannot handle data corruption cases just by getting the end result usually, we need steps to reproduce such data corruption.
FBX export error because of UVto FBX export error because of invalid NaN UV values.Such cases are extremely rare, it is hard to find the exact actions sequence. So, this is because of invalid mesh data.
Is it possible to detect such data with a special function?
Thank you for your reply~ I couldn't solve the problem, so I recreated it and worked on it. ~^^;;
@1D_Inc Mesh.validate() should catch and fix these now, at least in master (not sure when UVMaps where moved to the new generic attribute system, old UVMaps did not check for invalid number values, new float attributes do).
Sorry, but what is 'invalid NaN UV values'~?
'NaN' is a short for 'Not a Number', a computer way to represent invalid/'impossible' numbers, like e.g. the result of a division by zero. Such values should never exist in Blender mesh data.
When I tried to merge 10 pieces and export them, I got an error. Is it possible that this problem may occur in the process of merging mash~? Or can it be caused by not doing UV unwrap~?
I thought issue is in FBX code. So the mesh itself is corrupted.
Mesh.validate()
indeed fixes the problem. @1D_Inc , can you verify too?Perhaps we can close the report if above information is not available.
Thanks for the reply.^^ I wanted to know what was causing the problem and solve it, but now I can't. Because It seems that I deleted the blender file ( having problems) while cleaning up the folder~;; If I have the same problem again, I'll contact you again. Thank you~!
@1D_Inc hi, any updates on this?
@PratikPB2123 hi. It is hard to say.
Can fbx export verify meshes before actual export to achieve the solution that doesnot require programming skills at the user side?
For example, different software has "Audit" function which allow to checks and validate the scenes content in cases when such kind of error occurs.
I'm not sure if this is possible.
In some cases, spreadsheet can help to identify the problem
Will close this report for now since the culprit is corrupted mesh and not the FBX export code.
maybe we can track this in a separate report when you find necessary info.
