Regression: My blend file crashes when rendering in Blender 3.4 upwards, because of an unchecked NULL in the code. (stack trace provided) #103031
7 Participants
Reference: blender/blender#103031
Operating system: Windows-10-10.0.22000-SP0 64 Bits
Graphics card: Intel(R) HD Graphics 620 Intel 4.5.0 - Build 31.0.101.2111
Broken: version: 3.4.0, branch: blender-v3.4-release, commit date: 2022-12-06 18:46, hash:
a95bf1ac01
Worked: Any version prior to this
When rendering a large blend file in any build from 3.4 upwards I get a crash before the render starts. I have reproduced this in a debug build and can show where the issue is. I don't know the code so I am not sure why my blend file causes blender to get in this state and unfortunately it is commercially sensitive so can't share it.
I load up my blend file and hit render. It fairly quickly hits an access violation.
The call-stack is as follows:
The function where we access a null pointer is:
Looking through the code a little, it can be expected that the fine function may return NULL, this isn't checked before looking at the flag. I have no idea the conditions in my file which would cause it to return NULL though as I don't know the code, but there is a code-path through it where it would return NULL if you look up the stack a little.
Hope this helps in resolving the issue, it still works fine in version of Blender Prior to 3.4
Added subscriber: @Chris-Monachan
#103087 was marked as duplicate of this issue
#103010 was marked as duplicate of this issue
Added subscriber: @mod_moder
Is it in September builds? in 3.3, 3.4, 3.5?
It does not crash in 3.3.2 (2022-12-06 18:19), it does crash in the 3.4 Stable released this week, and in 3.5 (latest code from the repository which I used to build my debug build). Hope this helps.
It's just a test. I don't know this module, but I see recent commits. Usually bisect is made by people from the checker module, but since there is no project ...
In general here:
https://builder.blender.org/download/daily/
Open the archive (text below this week's links)
And try to find 2 versions between which it appeared.
The fastest way to jump far (for example)
https://builder.blender.org/download/daily/archive/blender-3.4.0-alpha+master.caf6225a3d01-windows.amd64-release.zip
If there are no problems, jump up, if not, a little below.
In general, I think it will take the longest to download all this, the search usually takes me no more than 10 minutes (when there are 150 downloaded versions)
Potential caused by: D16004: ViewLayer: fix missing sync in object APIs (fixes #101128)
Missing check on NULL
I think you should not look for a version, let's wait for the author's opinion, most likely he will be able to explain this without your project
My blend file crashes when rendering in Blender 3.4 upwards, because of an unchecked NULL in the code. (stack trace provided)to Regression: My blend file crashes when rendering in Blender 3.4 upwards, because of an unchecked NULL in the code. (stack trace provided)Added subscribers: @aras_p, @PratikPB2123
Changed status from 'Needs Triage' to: 'Needs Developer To Reproduce'
@aras_p hi, can you take a look?
In
e00f76c6a8
you'd removed the null check for*base
inrna_Object_indirect_only_get
Changed status from 'Needs Developer To Reproduce' to: 'Confirmed'
@Chris-Monachan yeah indeed the function seems to miss a
which was accidentally lost in
e00f76c6a8
(sorry, my bad!). If you can confirm that this fixes the regression, I can commit that into the codebase properly.Just in case it doesn't have a chance to test the build with this
And while doing this, you need to be sure that this is a working fix.
Can run a build bot?
@aras_p , yeah that does get me past that crash when I added that check to the function. Nicely done, thanks! It would be great if this fix could be merged back to the 3.4 branch as I use that for production work.
Added subscribers: @icedryst, @Siteth, @OmarEmaraDev
Added subscriber: @brecht
Restoring the NULL is the right solution, that can be committed.
This issue was referenced by
a47d1ad9d5
874319a344
Added subscribers: @RainerTrummer, @EAW
