Object saved as Shade Smooth in 3.3 was Shaded Flat in 3.4 render #103139
Closed
opened 2022-12-11 18:20:02 +01:00 by James Tomkinson · 13 comments
Operating system: Windows-10-10.0.22621-SP0 64 Bits
Graphics card: NVIDIA GeForce GTX 1050/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 526.98
Broken: version: 3.4.0, branch: blender-v3.4-release, commit date: 2022-12-06 18:46, hash: a95bf1ac01
Worked: 3.3.0
If I render some items saved in 3.3 as "Shade Smooth", they render as Flat in 3.4.0 and can "take coaxing" to Shade Smooth again.
  • Use the attached file kettle 32 saved 2.blend
  • attempt to Shade Smooth and render: might still shade Flat.
**System Information** Operating system: Windows-10-10.0.22621-SP0 64 Bits Graphics card: NVIDIA GeForce GTX 1050/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 526.98 **Blender Version** Broken: version: 3.4.0, branch: blender-v3.4-release, commit date: 2022-12-06 18:46, hash: `a95bf1ac01` Worked: 3.3.0 **Short description of error** If I render some items saved in 3.3 as "Shade Smooth", they render as Flat in 3.4.0 and can "take coaxing" to Shade Smooth again. **Exact steps for others to reproduce the error** - Use the attached file [kettle 32 saved 2.blend](https://archive.blender.org/developer/F14052554/kettle_32_saved_2.blend) - open and render in version 3.3.0, see ![kettle_32.jpg](https://archive.blender.org/developer/F14052558/kettle_32.jpg) - open and render in version 3.4.0, see ![kettle_33.jpg](https://archive.blender.org/developer/F14052561/kettle_33.jpg) - attempt to Shade Smooth and render: might still shade Flat.
Added subscriber: @jamestomk
Added subscriber: @mod_moder
version: 3.4.0, branch: blender-v3.4-release, commit date: 2022-12-07 11:39, hash: 175bd38201
Can't confirm
version: 3.4.0, branch: blender-v3.4-release, commit date: 2022-12-07 11:39, hash: `175bd38201` ![image.png](https://archive.blender.org/developer/F14052581/image.png) Can't confirm
Member
Member
Member
Hi, thanks for the report. I can confirm this in 3.4 and succeeding versions. Though node tree is bit complex. Could you simplify it a bit?
Also some nodes are undefined in provided file
@mod_moder, switch to viewport rendering and select cycles render engine :)
Hi, thanks for the report. I can confirm this in 3.4 and succeeding versions. Though node tree is bit complex. Could you simplify it a bit? Also some nodes are undefined in provided file ![image.png](https://archive.blender.org/developer/F14053348/image.png) - - - @mod_moder, switch to viewport rendering and select cycles render engine :)
i replaced the Combine node with a defined combine node (why was it not "defined"?). It made no difference to the render
> In #103139#1458810, @PratikPB2123 wrote: > Hi, thanks for the report. I can confirm this in 3.4 and succeeding versions. Though node tree is bit complex. Could you simplify it a bit? > Also some nodes are undefined in provided file > ![image.png](https://archive.blender.org/developer/F14053348/image.png) > - - - > @mod_moder, switch to viewport rendering and select cycles render engine :) i replaced the Combine node with a defined combine node (why was it not "defined"?). It made no difference to the render [kettle 32 saved 2.blend](https://archive.blender.org/developer/F14056243/kettle_32_saved_2.blend) ![Screenshot 2022-12-13 170939.png](https://archive.blender.org/developer/F14056248/Screenshot_2022-12-13_170939.png)
Member
@jamestomk hi, thanks for the update. I think difference is due to Normal map node. This is just a guess though. Could you simplify the file further? It's really hard to detect the problem with large and hierarchy of nodes
problem: I am using a Material from "Material Library VX" and so am unfamiliar with it. I'll report a bug there and link to this one.
This probably also implies that other users will run into a similar problem.
> In #103139#1460010, @PratikPB2123 wrote: > @jamestomk hi, thanks for the update. I think difference is due to Normal map node. This is just a guess though. Could you simplify the file further? It's really hard to detect the problem with large and hierarchy of nodes problem: I am using a Material from "Material Library VX" and so am unfamiliar with it. I'll report a bug there and link to this one. This probably also implies that other users will run into a similar problem.
I submitted a bug report against the add-on in case they want to comment on this report.
I submitted a [bug report ](https://developer.blender.org/T103305) against the add-on in case they want to comment on this report.
Changed status from 'Needs User Info' to: 'Resolved'
James Tomkinson self-assigned this 2022-12-27 01:28:08 +01:00
unknown material, not supported.
Changed status from 'Resolved' to: 'Archived'
James Tomkinson was unassigned by Iliya Katushenock 2022-12-27 08:55:29 +01:00
Reference: blender/blender#103139
