Regression: Grease pencil: applying armature does not work. It is now similar to removing the armature modifier #103234
Closed
opened 2022-12-15 08:00:24 +01:00 by Tim · 16 comments
Hi! First of all thank you for your great job!
Operating system: Windows 11
Graphics card: NVIDIA GeForce RTX 2080 SUPER
Broken: 3.4.0, 3.3.0, 3.2.0
Worked: 3.1.2
Caused by cff6eb6580.
The applying armature doesn't work for grease pencil. It is now similar to removing the armature modifier
  1. Create grease pencil with two strokes.
  2. Create armature with two bones chain.
  3. Assing each stroke to its bone.
  4. Make some pose - rotate one of the bone.
  5. Apply the armature modifier.
    Result is similar to removing the modifier - all strokes will return to initial poses.
#103234.blend
Best wishes,
Tim
Hi! First of all thank you for your great job! **System Information** Operating system: Windows 11 Graphics card: NVIDIA GeForce RTX 2080 SUPER **Blender Version** Broken: 3.4.0, 3.3.0, 3.2.0 Worked: 3.1.2 Caused by cff6eb6580. **Short description of error** The applying armature doesn't work for grease pencil. It is now similar to removing the armature modifier **Exact steps for others to reproduce the error** 1. Create grease pencil with two strokes. 2. Create armature with two bones chain. 3. Assing each stroke to its bone. 4. Make some pose - rotate one of the bone. 5. Apply the armature modifier. Result is similar to removing the modifier - all strokes will return to initial poses. ![image.png](https://archive.blender.org/developer/F14058665/image.png) ![image.png](https://archive.blender.org/developer/F14058681/image.png) ![image.png](https://archive.blender.org/developer/F14058685/image.png) [#103234.blend](https://archive.blender.org/developer/F14058745/T103234.blend) Best wishes, Tim
Author
Added subscriber: @Tim-Kravchenko
Member
Added subscriber: @lichtwerk
Member
Member
Can confirm, will check
Broken: all versions.
Not true, this was working in 3.1.2
Can confirm, will check > Broken: all versions. Not true, this was working in 3.1.2
Author
Thanks, @lichtwerk! I checked only 3.3.0 and 3.4.0. So I thought it never worked)
> In #103234#1460832, @lichtwerk wrote: > Can confirm, will check > >> Broken: all versions. > Not true, this was working in 3.1.2 Thanks, @lichtwerk! I checked only 3.3.0 and 3.4.0. So I thought it never worked)
Added subscribers: @antoniov, @frogstomp-4
@lichtwerk there was a change in applying layer transformation in 3.2: https://developer.blender.org/D14844
Possible cause maybe?
cc @antoniov
@lichtwerk there was a change in applying layer transformation in 3.2: https://developer.blender.org/D14844 Possible cause maybe? cc @antoniov
Member
@frogstomp-4 : think it is something else that broke this, will bisect...
cc @antoniov
This patch was for bake animation and it's not related to this modifier.
> In #103234#1460843, @frogstomp-4 wrote: > @lichtwerk there was a change in applying layer transformation in 3.2: https://developer.blender.org/D14844 > Possible cause maybe? > cc @antoniov This patch was for bake animation and it's not related to this modifier.
Member
Seems like the armature modifier needs to do this with the original bGPdata (it passes the evaluated object to generic_bake_deform_stroke though)
Caused by cff6eb6580. Seems like the armature modifier needs to do this with the **original** bGPdata (it passes the **evaluated** object to `generic_bake_deform_stroke` though)
Philipp Oeser changed title from Grease pencil: applying armature does not work. It is now similar to removing the armature modifier to Regression: Grease pencil: applying armature does not work. It is now similar to removing the armature modifier 2022-12-15 09:38:43 +01:00
Member
Havent checked why this mixture of original and evaluated is needed (in fact, it doesnt seem like this is actually needed, see second example), but here are two changes that potentionally "fix":
diff --git a/source/blender/gpencil_modifiers/intern/MOD_gpencil_util.c b/source/blender/gpencil_modifiers/intern/MOD_gpencil_util.c
index d4ada842d0b..a5d13796249 100644
--- a/source/blender/gpencil_modifiers/intern/MOD_gpencil_util.c
+++ b/source/blender/gpencil_modifiers/intern/MOD_gpencil_util.c
@@ -178,9 +178,10 @@ void generic_bake_deform_stroke(
   Scene *scene = DEG_get_evaluated_scene(depsgraph);
   bGPdata *gpd = ob->data;
+  bGPdata *gpd_orig = (bGPdata *)DEG_get_original_id(&gpd->id);
   int oldframe = (int)DEG_get_ctime(depsgraph);
-  LISTBASE_FOREACH (bGPDlayer *, gpl, &gpd->layers) {
+  LISTBASE_FOREACH (bGPDlayer *, gpl, &gpd_orig->layers) {
     LISTBASE_FOREACH (bGPDframe *, gpf, &gpl->frames) {
       if (retime) {
         scene->r.cfra = gpf->framenum;
diff --git a/source/blender/gpencil_modifiers/intern/MOD_gpencilarmature.c b/source/blender/gpencil_modifiers/intern/MOD_gpencilarmature.c
index d99d9950efb..5163f4d7020 100644
--- a/source/blender/gpencil_modifiers/intern/MOD_gpencilarmature.c
+++ b/source/blender/gpencil_modifiers/intern/MOD_gpencilarmature.c
@@ -118,14 +118,12 @@ static void bakeModifier(Main *UNUSED(bmain),
                          GpencilModifierData *md,
                          Object *ob)
-  Object *object_eval = DEG_get_evaluated_object(depsgraph, ob);
   ArmatureGpencilModifierData *mmd = (ArmatureGpencilModifierData *)md;
-  GpencilModifierData *md_eval = BKE_gpencil_modifiers_findby_name(object_eval, md->name);
   if (mmd->object == NULL) {
     return;
-  generic_bake_deform_stroke(depsgraph, md_eval, object_eval, true, deformStroke);
+  generic_bake_deform_stroke(depsgraph, md, ob, true, deformStroke);
 static bool isDisabled(GpencilModifierData *md, int UNUSED(userRenderParams))
Havent checked why this mixture of original and evaluated is needed (in fact, it doesnt seem like this is actually needed, see second example), but here are two changes that potentionally "fix": ``` diff --git a/source/blender/gpencil_modifiers/intern/MOD_gpencil_util.c b/source/blender/gpencil_modifiers/intern/MOD_gpencil_util.c index d4ada842d0b..a5d13796249 100644 --- a/source/blender/gpencil_modifiers/intern/MOD_gpencil_util.c +++ b/source/blender/gpencil_modifiers/intern/MOD_gpencil_util.c @@ -178,9 +178,10 @@ void generic_bake_deform_stroke( { Scene *scene = DEG_get_evaluated_scene(depsgraph); bGPdata *gpd = ob->data; + bGPdata *gpd_orig = (bGPdata *)DEG_get_original_id(&gpd->id); int oldframe = (int)DEG_get_ctime(depsgraph); - LISTBASE_FOREACH (bGPDlayer *, gpl, &gpd->layers) { + LISTBASE_FOREACH (bGPDlayer *, gpl, &gpd_orig->layers) { LISTBASE_FOREACH (bGPDframe *, gpf, &gpl->frames) { if (retime) { scene->r.cfra = gpf->framenum; ``` ``` diff --git a/source/blender/gpencil_modifiers/intern/MOD_gpencilarmature.c b/source/blender/gpencil_modifiers/intern/MOD_gpencilarmature.c index d99d9950efb..5163f4d7020 100644 --- a/source/blender/gpencil_modifiers/intern/MOD_gpencilarmature.c +++ b/source/blender/gpencil_modifiers/intern/MOD_gpencilarmature.c @@ -118,14 +118,12 @@ static void bakeModifier(Main *UNUSED(bmain), GpencilModifierData *md, Object *ob) { - Object *object_eval = DEG_get_evaluated_object(depsgraph, ob); ArmatureGpencilModifierData *mmd = (ArmatureGpencilModifierData *)md; - GpencilModifierData *md_eval = BKE_gpencil_modifiers_findby_name(object_eval, md->name); if (mmd->object == NULL) { return; } - generic_bake_deform_stroke(depsgraph, md_eval, object_eval, true, deformStroke); + generic_bake_deform_stroke(depsgraph, md, ob, true, deformStroke); } static bool isDisabled(GpencilModifierData *md, int UNUSED(userRenderParams)) ```
@lichtwerk The right fix is this:
                          Object *ob)
     return;
@lichtwerk The right fix is this: ``` diff --git a/source/blender/gpencil_modifiers/intern/MOD_gpencilarmature.c b/source/blender/gpencil_modifiers/intern/MOD_gpencilarmature.c index d99d9950efb..5163f4d7020 100644 --- a/source/blender/gpencil_modifiers/intern/MOD_gpencilarmature.c +++ b/source/blender/gpencil_modifiers/intern/MOD_gpencilarmature.c @@ -118,14 +118,12 @@ static void bakeModifier(Main *UNUSED(bmain), GpencilModifierData *md, Object *ob) { - Object *object_eval = DEG_get_evaluated_object(depsgraph, ob); ArmatureGpencilModifierData *mmd = (ArmatureGpencilModifierData *)md; - GpencilModifierData *md_eval = BKE_gpencil_modifiers_findby_name(object_eval, md->name); if (mmd->object == NULL) { return; } - generic_bake_deform_stroke(depsgraph, md_eval, object_eval, true, deformStroke); + generic_bake_deform_stroke(depsgraph, md, ob, true, deformStroke); } static bool isDisabled(GpencilModifierData *md, int UNUSED(userRenderParams)) ```
This issue was referenced by 6aacbdd716
This issue was referenced by 6aacbdd716fa979f2d02ae2b7c0fcb2fdc0554e4
This issue was referenced by d4a6108ef2
This issue was referenced by d4a6108ef292ee43aa0d5315fdcfd51c9a5da629
This issue was referenced by e0ef5f3602
This issue was referenced by e0ef5f360222148d52e68d820df499dd6da5ce8a
Antonio Vazquez self-assigned this 2022-12-15 10:53:40 +01:00
5 Participants
Reference: blender/blender#103234
