Unexpected behavior when combining Color Attributes with White Noise Texture #103255
Closed
opened 2022-12-16 03:02:38 +01:00 by Elias · 9 comments
Operating system: Windows-10-10.0.19044-SP0 64 Bits
Graphics card: NVIDIA GeForce RTX 2070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 517.00
Broken: version: 3.4.0, branch: blender-v3.4-release, commit date: 2022-12-06 18:46, hash: a95bf1ac01
Plugging in an object's color attributes into a white noise texture yields an unexpected banding pattern, even if every vertex shares the same exact color.
  1. Select the default cube and go into Vertex Paint mode, which will create a new color attribute.
    (notice how each vertex is pure white)
  2. Create a material for the cube.
  3. Add a White Noise Texture node, and plug the Value or Color into the Surface of the Material Output
  4. Add a Color Attribute node, and connect it to the Vector of the White Noise Texture
  5. Notice the banding pattern
Expected result would be identical to plugging in a solid white RGB node.
Actual results:
Blend file:
color attribute white noise bug.blend
**System Information** Operating system: Windows-10-10.0.19044-SP0 64 Bits Graphics card: NVIDIA GeForce RTX 2070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 517.00 **Blender Version** Broken: version: 3.4.0, branch: blender-v3.4-release, commit date: 2022-12-06 18:46, hash: `a95bf1ac01` Worked: (newest version of Blender that worked as expected) **Short description of error** Plugging in an object's color attributes into a white noise texture yields an unexpected banding pattern, even if every vertex shares the same exact color. **Exact steps for others to reproduce the error** 1. Select the default cube and go into Vertex Paint mode, which will create a new color attribute. (notice how each vertex is pure white) 2. Create a material for the cube. 3. Add a White Noise Texture node, and plug the Value or Color into the Surface of the Material Output 4. Add a Color Attribute node, and connect it to the Vector of the White Noise Texture 5. Notice the banding pattern Expected result would be identical to plugging in a solid white RGB node. ![blender_xie74Qdtg9.png](https://archive.blender.org/developer/F14060986/blender_xie74Qdtg9.png) ![blender_VJaaspd2iU.png](https://archive.blender.org/developer/F14060984/blender_VJaaspd2iU.png) Actual results: ![blender_Pmns47L7gI.png](https://archive.blender.org/developer/F14060987/blender_Pmns47L7gI.png) ![blender_jiT56z0bPb.png](https://archive.blender.org/developer/F14060989/blender_jiT56z0bPb.png) Blend file: [color attribute white noise bug.blend](https://archive.blender.org/developer/F14060955/color_attribute_white_noise_bug.blend)
Author
Added subscriber: @razzzmatazzz30297
Added subscriber: @mano-wii
I can confirm the behavior.
I'm not sure why this happens.
It is seen in both Eevee and Cycles.
And it only happens with White Noise Texture.
I can confirm the behavior. I'm not sure why this happens. It is seen in both Eevee and Cycles. And it only happens with `White Noise Texture`.
Member
Added subscriber: @CharlieJolly
Member
Added subscribers: @brecht, @LukasStockner
Member
This is caused by floating-point rounding differences.
The white noise node hashes its input, so the slightest change to any of its inputs will give a completely different output.
Since Vertex attributes are interpolated across the face, a calculation whose inputs depend on the shading location takes place. Of course, in exact arithmetic this should always give the same result since all vertices have the same value, but in floating-point arithmetic expressions like a*(1-b) + a*b might not always be exactly equal to a.
In this particular case, the difference in Cycles ends up being just one bit - 0x3F800000 (1.00000000...) vs. 0x3F7FFFFF (0.999999940395...). This tiny difference would never be visible for regular textures, but for white noise in particular it's enough to get a different output.
You can also demonstrate this without a white noise texture:
I don't think there's an easy fix for this, I'd lean towards just considering this a known limitation of the white noise texture.
@brecht, sounds good to you?
This is caused by floating-point rounding differences. The white noise node hashes its input, so the slightest change to any of its inputs will give a completely different output. Since Vertex attributes are interpolated across the face, a calculation whose inputs depend on the shading location takes place. Of course, in exact arithmetic this should always give the same result since all vertices have the same value, but in floating-point arithmetic expressions like `a*(1-b) + a*b` might not always be exactly equal to `a`. In this particular case, the difference in Cycles ends up being just one bit - `0x3F800000` (`1.00000000...`) vs. `0x3F7FFFFF` (`0.999999940395...`). This tiny difference would never be visible for regular textures, but for white noise in particular it's enough to get a different output. You can also demonstrate this without a white noise texture: ![Screenshot from 2022-12-17 01-06-55.png](https://archive.blender.org/developer/F14063832/Screenshot_from_2022-12-17_01-06-55.png) I don't think there's an easy fix for this, I'd lean towards just considering this a known limitation of the white noise texture. @brecht, sounds good to you?
Yes, I consider that a known limitation.
Member
Lukas Stockner self-assigned this 2022-12-17 03:37:20 +01:00
5 Participants
Reference: blender/blender#103255
