Objects linked from Asset Library ignore relative path preference #103546
6 Participants
Reference: blender/blender#103546
Operating system: Windows 11
Graphics card: GTX3060
Broken: 3.3.1
Worked: N/A
An object or collection that has been linked via the asset browser is always referenced via an absolute path even though the default preference is to link files with a relative path.
Expected Behavior: Blender should obey the relative path preference, regardless of how it was linked to the current Blend file (e.g. File->Link, Dragged in from File viewport and linked, or linked in from Asset library).
Actual Behavior: If something is linked from the asset browser, it ignores the relative paths flag, and creates a reference in the blend file with an absolute paths. (This then breaks linked assets when working with remote team members over cloud syncing services who have a different directory structure).
With the attached files:
If object is linked with
Link option
from file menu, it correctly shows relative patha.blend
c.blend
b.blend
Added subscriber: @DavidGilson-1
Changed status from 'Needs Triage' to: 'Needs Developer To Reproduce'
Hi, thanks for the report. I can confirm path for linked file is not absolute.
But File path shown in outliner is not independent on Relative path preference option.
Instead it appears to be depends on Relative path(relative_path) option from file browser
I'm not sure whether this is considered as a bug. Forwarding to devs.
Hi @PratikPB2123 ,
Thank you for looking into this !
@PratikPB2123 Just reviewing this and wanted to make sure I understood your posted. You confirmed my observations, but do you think the observed behavior is what Blender should or should not have?
@DavidGilson-1 hi, I think current behavior is correct.
In case of File > Link, you can adjust display method(relative or not) of each link object by
relative path
buttonBut for asset library we explicitly specify the path in preferences tab
I understand that the path of an asset library is absolute, and why that needs to be so. However, I don't see why that once objects are linked from the library, that their path cannot be set as relative, if that is what the user has set as their default preference in the main settings of Blender?
As thing stand, if you need to use relative paths (e.g working with a remote team via Dropbox or something similar), and you're using the asset library, you have to remember to manually change all the paths to relative, even though, you have set relative paths as your default preference. This is causing a lot of speed bumps with my colleagues and while I do my best to remember, I sometimes forget, and then blender file links are broken on my colleagues computers, until they tell me and I have to go back and manually set everything to relative.
I can live with doing things manually when it's necessary, but given that there is a preference for whether linked files should be absolute or relative, I don't really see a good reason for me to have to manually set things to relative, when I have already set that as my default preference, it should just do it by ... default!
Added subscriber: @pauanyu_blender
I also would benefit a lot from this. I have multiple blend files in the same asset library. Those blend files are importing assets from other blend files (in the same asset library).
Because all of the blend files are in the same asset library, I want them to use relative imports, so that way I can move the asset library around without any issue.
However, Blender is always using absolute imports, so that causes the asset library to completely break. This is really bad behavior.
Glad to hear my team isn't the only one affected by this!
Pinging this issue, as it would be great to see it resolved. The dev who first responded, @PratikPB2123 , didn't seem to think it was a problem if I understood him correctly, but I have to disagree. Anyone else out there?
@JulianEisel can you check?
@JulianEisel Your turf
This topic needs design work. Simply using the existing option from the Preferences is not a good choice IMO, since this is just supposed to be the default for new file browsing operations and you can still change that while file browsing. Just as @PratikPB2123 explained. It would also bother me that settings affecting asset library usage are spread across the Preferences.
For assets you'd probably want to be able to use relative paths for some asset libraries, absolute for others. Or maybe it differs per asset even. So a single global option doesn't make sense. A per asset library option seems like a better choice, plus maybe the possibility to override this temporarily in the asset browser? Similar to the new import method option in the Preferences:
ae84a2956e
In addition to this, I would like to find out to what degree this would be covered by Blender Projects (see #104883). For multi-file projects with their own dedicated asset libraries, I'd expect you'd want to use relative paths always. For personal asset libraries that are used across multiple projects, absolute paths is the better choice - I think. So, maybe we don't need an option for this, and just use relative paths for project libraries and absolute ones for personal, cross-project ones?
I'm unsure about this myself, so again: A design is needed. The asset browser is geared more towards using of personal asset libraries at this point, it's known that these (rather significant) weak spots exist.
Also, the preferences option doesn't make much sense to me anymore, the File Browser could just remember what it was set to last time. This should now be possible to implement, but wasn't back when the options was added to the Preferences.
As a user with multiple computers (laptop + desktop) with differing operating systems, absolute paths are difficult to deal with. If I want to be able to open a Blender file on both my computers, I cannot use absolute paths, since the OS dictates that user-space files live in different places.
A potentially robust solution would be to have some way to indicate that two Asset Libraries are the same (maybe the library name is good enough?), and then read assets relative to the asset library root, rather than the .blend file.
For example, a linked asset might have the path
${User Library}/Props/Indoors/Modern Table A
.Since 3.6 there's a Relative Path option per asset library, see https://developer.blender.org/docs/release_notes/3.6/pipeline_assets_io/#assets. So I'll consider this closed (this has never been a bug anyway, since the existing option was only meant for the File Browser, not for assets).
Blender Project support may further help address use-cases, see blender/blender!107655.
To clarify, does this relative path setting make the paths relative to the asset library? Pretty much, I'm looking for a solution to this use case:
I have a project file that imports an asset from the library
some_library
. The asset library is stored assome_library
in Blender's preferences on both computers.The project file is synced between both computers, but the asset library is on a NAS because it is very large.
Because of differences in how Windows vs. Mac OS handles mounted drives (and this isn't the only thing they handle differently), the file paths wouldn't work with absolute links, nor would they work with links relative to the project file.
On the Mac:
On the Windows computer:
When taking advantage of the per-library relative links setting, will I need to find missing links every time I switch computers? Or will Blender store those links relative to the user-defined Asset Library
some_library
as defined in preferences?
