Scripting: creating a corner-domain color attribute doesn't make it active #103564
7 Participants
Reference: blender/blender#103564
Operating system: Linux
Broken: blender-3.5.0-alpha+master.3340cc810203-linux.x86_64-release
Creating a color attribute with "Face Corner" domain on a mesh with no color attributes does not always make the new attribute active.
Create a cube and then run this script.
Observe that the active color attribute is
None
for both CORNER domain cases.Somewhat bizarrely, this does work if you use
mesh = bpy.data.meshes.new('TestMesh')
instead of your cube.Added subscriber: @scurest
Added subscriber: @mod_moder
Changed status from 'Needs Triage' to: 'Needs Developer To Reproduce'
I've found strange behaviors in how the active attribute works exactly.
Is it normal for an attribute to not be active?
Yes, as described in the report, the code will print only the first 2 attributes as active of the 4 created
Added subscriber: @JulienDuroure
I don't know if this is related, but creating the color attribute also doesn't make it active for rendering (the little camera next to the name). This is different that how UV maps behave. This also means it doesn't work with eg. Color Attribute nodes with a blank name. I know this used to work in previous versions.
This definitely sounds like a bug. But I think the new behavior for making a color attribute active is better. Just creating a new color attribute with the Python API probably shouldn't change the active status, in case it was set explicitly by the user.
The report is about creating the first color attribute though. I expect if there's only one, it's active. I'm not sure what the behavior is when there are already other color attributes.
edit: For UV maps, creating the first UV map makes it active. Creating subsequent ones does not change the active map. I think this is how color attributes should work (and I think they did use to work that way).
Ah, I see. That sounds more reasonable I suppose. Thanks.
Changed status from 'Needs Developer To Reproduce' to: 'Confirmed'
This issue was referenced by
101d04f41f
Sorry, I just tried blender-3.5.0-alpha+master.1beaec46b8e3 and this still seems to work only sometimes.
Adding a vertex color through the old API
C.object.data.vertex_colors.new(name="Color")
to a newly created Cube does not make the color attribute active/default. Note that if you select the color attribute in the UI, delete it, and then run the same line again though, the second time it does make it active/default. So there's something weird going on.Importing a .dae/.obj file with vertex colors results in a color attribute that's active, but not default (the little camera).
@lichtwerk
@scurest : could you create a new report for both of these? (since these are a bit different than
color_attributes.new
.Feel free to subscribe me there (or even assign to me)
