Regression : crash opening file with uv from GN primitive #103837
Closed
opened 2023-01-12 17:22:41 +01:00 by Julien Duroure · 12 comments
Member
Operating system: Mint
Graphics card: Nvidia RTX
Broken: 3.5 alpha 2b4bf586ad (today build)
Worked: 3.5 alpha 3 days ago
Caused by d397ecae32
Segmentation Fault opening the attached file:
26_material_override_by_modifiers.blend
Open the file
The daily build 3 days ago opened it without any issue.
**System Information** Operating system: Mint Graphics card: Nvidia RTX **Blender Version** Broken: 3.5 alpha 2b4bf586ade5 (today build) Worked: 3.5 alpha 3 days ago Caused by d397ecae32 **Short description of error** Segmentation Fault opening the attached file: [26_material_override_by_modifiers.blend](https://archive.blender.org/developer/F14146011/26_material_override_by_modifiers.blend) **Exact steps for others to reproduce the error** Open the file The daily build 3 days ago opened it without any issue.
Author
Member
Added subscriber: @JulienDuroure
Member
Added subscribers: @lichtwerk, @PratikPB2123
Member
Member
Hi, I can repro the crash. Not bisected yet but I suspect 6c774feba2
@lichtwerk , can you check? On my end, crash did not happen in debug-lite build (neither with --debug and -t flag).
Hi, I can repro the crash. Not bisected yet but I suspect 6c774feba2 @lichtwerk , can you check? On my end, crash did not happen in debug-lite build (neither with --debug and -t flag).
Member
Can also repro, will check
Member
Getting this:
==1805984==ERROR: AddressSanitizer: heap-buffer-overflow on address 0x602000144aa0 at pc 0x7fac16a49d21 bp 0x7ffd31934690 sp 0x7ffd31933e40
WRITE of size 6 at 0x602000144aa0 thread T0
    - 0 0x7fac16a49d20 in __interceptor_memcpy (/lib64/libasan.so.8+0x49d20)
    - 1 0x1c2f2a3f in BLI_strncpy /blender/source/blender/blenlib/intern/string.c:73
    - 2 0x3cfe1aa in version_geometry_nodes_primitive_uv_maps /blender/source/blender/blenloader/intern/versioning_300.cc:900
    - 3 0x3d388c9 in blo_do_versions_300 /blender/source/blender/blenloader/intern/versioning_300.cc:3822
    - 4 0x3bb5da7 in do_versions /blender/source/blender/blenloader/intern/readfile.cc:3539
    - 5 0x3bbaf29 in blo_read_file_internal /blender/source/blender/blenloader/intern/readfile.cc:3873
    - 6 0x3db1c8f in BLO_read_from_file /blender/source/blender/blenloader/intern/readblenentry.cc:400
    - 7 0xbed6eb3 in BKE_blendfile_read /blender/source/blender/blenkernel/intern/blendfile.c:502
    - 8 0x3a623ef in WM_file_read /blender/source/blender/windowmanager/intern/wm_files.c:963
    - 9 0x3a6ebad in wm_file_read_opwrap /blender/source/blender/windowmanager/intern/wm_files.c:2594
    - 10 0x3a6fbaf in wm_open_mainfile__open /blender/source/blender/windowmanager/intern/wm_files.c:2716
    - 11 0x3a6ef26 in operator_state_dispatch /blender/source/blender/windowmanager/intern/wm_files.c:2630
    - 12 0x3a6fe0d in wm_open_mainfile_dispatch /blender/source/blender/windowmanager/intern/wm_files.c:2740
    - 13 0x3a6f1e6 in wm_open_mainfile__discard_changes /blender/source/blender/windowmanager/intern/wm_files.c:2669
    - 14 0x3a6ef26 in operator_state_dispatch /blender/source/blender/windowmanager/intern/wm_files.c:2630
    - 15 0x3a6fe0d in wm_open_mainfile_dispatch /blender/source/blender/windowmanager/intern/wm_files.c:2740
    - 16 0x3a6fe36 in wm_open_mainfile_invoke /blender/source/blender/windowmanager/intern/wm_files.c:2745
    - 17 0x3a236f0 in wm_operator_invoke /blender/source/blender/windowmanager/intern/wm_event_system.cc:1474
    - 18 0x3a2557d in wm_operator_call_internal /blender/source/blender/windowmanager/intern/wm_event_system.cc:1707
    - 19 0x3a25682 in WM_operator_name_call_ptr /blender/source/blender/windowmanager/intern/wm_event_system.cc:1721
    - 20 0x3a26b95 in WM_operator_name_call_ptr_with_depends_on_cursor /blender/source/blender/windowmanager/intern/wm_event_system.cc:1914
    - 21 0x9de572c in ui_apply_but_funcs_after /blender/source/blender/editors/interface/interface_handlers.cc:1017
    - 22 0x9e77561 in ui_handler_region_menu /blender/source/blender/editors/interface/interface_handlers.cc:11418
    - 23 0x3a1c67b in wm_handler_ui_call /blender/source/blender/windowmanager/intern/wm_event_system.cc:791
    - 24 0x3a357c8 in wm_handlers_do_intern /blender/source/blender/windowmanager/intern/wm_event_system.cc:3244
    - 25 0x3a368f2 in wm_handlers_do /blender/source/blender/windowmanager/intern/wm_event_system.cc:3361
    - 26 0x3a3faee in wm_event_do_handlers /blender/source/blender/windowmanager/intern/wm_event_system.cc:3954
    - 27 0x39fac44 in WM_main /blender/source/blender/windowmanager/intern/wm.c:640
    - 28 0x7cc0c6 in main /blender/source/creator/creator.c:585
    - 29 0x7fac0ec2950f in __libc_start_call_main (/lib64/libc.so.6+0x2950f)
    - 30 0x7fac0ec295c8 in __libc_start_main_impl (/lib64/libc.so.6+0x295c8)
    - 31 0x7cb454 in _start (/build_linux_debug/bin/blender+0x7cb454)
0x602000144aa0 is located 4 bytes to the right of 12-byte region [0x602000144a90,0x602000144a9c)
allocated by thread T0 here:
    - 0 0x7fac16aba097 in calloc (/lib64/libasan.so.8+0xba097)
    - 1 0x1c4374e3 in MEM_lockfree_callocN /blender/intern/guardedalloc/intern/mallocn_lockfree_impl.c:208
    - 2 0x55c6183 in bNodeSocketValueBoolean* MEM_cnew<bNodeSocketValueBoolean>(char const*) /blender/intern/guardedalloc/MEM_guardedalloc.h:302
    - 3 0x55bb943 in node_socket_init_default_value /blender/source/blender/nodes/intern/node_socket.cc:316
    - 4 0xffd68d in node_socket_set_typeinfo /blender/source/blender/blenkernel/intern/node.cc:1213
    - 5 0x1001212 in make_socket /blender/source/blender/blenkernel/intern/node.cc:1549
    - 6 0x1002461 in nodeAddSocket /blender/source/blender/blenkernel/intern/node.cc:1704
    - 7 0x1002bae in nodeAddStaticSocket /blender/source/blender/blenkernel/intern/node.cc:1925
    - 8 0x55d3cd4 in blender::nodes::decl::Bool::build(bNodeTree&, bNode&) const /blender/source/blender/nodes/intern/node_socket_declarations.cc:272
    - 9 0x55b9437 in refresh_socket_list /blender/source/blender/nodes/intern/node_socket.cc:196
    - 10 0x55ba901 in refresh_node /blender/source/blender/nodes/intern/node_socket.cc:252
    - 11 0x55bad56 in node_verify_sockets /blender/source/blender/nodes/intern/node_socket.cc:265
    - 12 0xffbab4 in node_add_sockets_from_type /blender/source/blender/blenkernel/intern/node.cc:1079
    - 13 0xffc708 in node_init /blender/source/blender/blenkernel/intern/node.cc:1131
    - 14 0xffd3d9 in node_set_typeinfo /blender/source/blender/blenkernel/intern/node.cc:1191
    - 15 0x1007074 in nodeAddNode /blender/source/blender/blenkernel/intern/node.cc:2217
    - 16 0x1007679 in nodeAddStaticNode /blender/source/blender/blenkernel/intern/node.cc:2246
    - 17 0x3cfd30d in version_geometry_nodes_primitive_uv_maps /blender/source/blender/blenloader/intern/versioning_300.cc:862
    - 18 0x3d388c9 in blo_do_versions_300 /blender/source/blender/blenloader/intern/versioning_300.cc:3822
    - 19 0x3bb5da7 in do_versions /blender/source/blender/blenloader/intern/readfile.cc:3539
    - 20 0x3bbaf29 in blo_read_file_internal /blender/source/blender/blenloader/intern/readfile.cc:3873
    - 21 0x3db1c8f in BLO_read_from_file /blender/source/blender/blenloader/intern/readblenentry.cc:400
    - 22 0xbed6eb3 in BKE_blendfile_read /blender/source/blender/blenkernel/intern/blendfile.c:502
    - 23 0x3a623ef in WM_file_read /blender/source/blender/windowmanager/intern/wm_files.c:963
    - 24 0x3a6ebad in wm_file_read_opwrap /blender/source/blender/windowmanager/intern/wm_files.c:2594
    - 25 0x3a6fbaf in wm_open_mainfile__open /blender/source/blender/windowmanager/intern/wm_files.c:2716
    - 26 0x3a6ef26 in operator_state_dispatch /blender/source/blender/windowmanager/intern/wm_files.c:2630
    - 27 0x3a6fe0d in wm_open_mainfile_dispatch /blender/source/blender/windowmanager/intern/wm_files.c:2740
    - 28 0x3a6f1e6 in wm_open_mainfile__discard_changes /blender/source/blender/windowmanager/intern/wm_files.c:2669
    - 29 0x3a6ef26 in operator_state_dispatch /blender/source/blender/windowmanager/intern/wm_files.c:2630
SUMMARY: AddressSanitizer: heap-buffer-overflow (/lib64/libasan.so.8+0x49d20) in __interceptor_memcpy
Shadow bytes around the buggy address:
  0x0c0480020900: fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa
  0x0c0480020910: fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa
  0x0c0480020920: fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa
  0x0c0480020930: fa fa fa fa fa fa fa fa fa fa fa fa fa fa 00 04
  0x0c0480020940: fa fa fa fa fa fa fa fa fa fa 00 00 fa fa 00 04
=>0x0c0480020950: fa fa 00 04[fa]fa 00 04 fa fa 00 04 fa fa 00 00
  0x0c0480020960: fa fa 00 00 fa fa 00 04 fa fa 00 00 fa fa 00 00
  0x0c0480020970: fa fa 00 00 fa fa 00 04 fa fa 00 04 fa fa 00 04
  0x0c0480020980: fa fa 00 00 fa fa 00 00 fa fa 00 00 fa fa 00 04
  0x0c0480020990: fa fa 00 00 fa fa fd fd fa fa fd fd fa fa 00 04
  0x0c04800209a0: fa fa 00 00 fa fa 00 00 fa fa 00 04 fa fa 00 00
Shadow byte legend (one shadow byte represents 8 application bytes):
  Addressable:           00
  Partially addressable: 01 02 03 04 05 06 07
  Heap left redzone:       fa
  Freed heap region:       fd
  Stack left redzone:      f1
  Stack mid redzone:       f2
  Stack right redzone:     f3
  Stack after return:      f5
  Stack use after scope:   f8
  Global redzone:          f9
  Global init order:       f6
  Poisoned by user:        f7
  Container overflow:      fc
  Array cookie:            ac
  Intra object redzone:    bb
  ASan internal:           fe
  Left alloca redzone:     ca
  Right alloca redzone:    cb
==1805984==ABORTING
Getting this: ``` ==1805984==ERROR: AddressSanitizer: heap-buffer-overflow on address 0x602000144aa0 at pc 0x7fac16a49d21 bp 0x7ffd31934690 sp 0x7ffd31933e40 WRITE of size 6 at 0x602000144aa0 thread T0 - 0 0x7fac16a49d20 in __interceptor_memcpy (/lib64/libasan.so.8+0x49d20) - 1 0x1c2f2a3f in BLI_strncpy /blender/source/blender/blenlib/intern/string.c:73 - 2 0x3cfe1aa in version_geometry_nodes_primitive_uv_maps /blender/source/blender/blenloader/intern/versioning_300.cc:900 - 3 0x3d388c9 in blo_do_versions_300 /blender/source/blender/blenloader/intern/versioning_300.cc:3822 - 4 0x3bb5da7 in do_versions /blender/source/blender/blenloader/intern/readfile.cc:3539 - 5 0x3bbaf29 in blo_read_file_internal /blender/source/blender/blenloader/intern/readfile.cc:3873 - 6 0x3db1c8f in BLO_read_from_file /blender/source/blender/blenloader/intern/readblenentry.cc:400 - 7 0xbed6eb3 in BKE_blendfile_read /blender/source/blender/blenkernel/intern/blendfile.c:502 - 8 0x3a623ef in WM_file_read /blender/source/blender/windowmanager/intern/wm_files.c:963 - 9 0x3a6ebad in wm_file_read_opwrap /blender/source/blender/windowmanager/intern/wm_files.c:2594 - 10 0x3a6fbaf in wm_open_mainfile__open /blender/source/blender/windowmanager/intern/wm_files.c:2716 - 11 0x3a6ef26 in operator_state_dispatch /blender/source/blender/windowmanager/intern/wm_files.c:2630 - 12 0x3a6fe0d in wm_open_mainfile_dispatch /blender/source/blender/windowmanager/intern/wm_files.c:2740 - 13 0x3a6f1e6 in wm_open_mainfile__discard_changes /blender/source/blender/windowmanager/intern/wm_files.c:2669 - 14 0x3a6ef26 in operator_state_dispatch /blender/source/blender/windowmanager/intern/wm_files.c:2630 - 15 0x3a6fe0d in wm_open_mainfile_dispatch /blender/source/blender/windowmanager/intern/wm_files.c:2740 - 16 0x3a6fe36 in wm_open_mainfile_invoke /blender/source/blender/windowmanager/intern/wm_files.c:2745 - 17 0x3a236f0 in wm_operator_invoke /blender/source/blender/windowmanager/intern/wm_event_system.cc:1474 - 18 0x3a2557d in wm_operator_call_internal /blender/source/blender/windowmanager/intern/wm_event_system.cc:1707 - 19 0x3a25682 in WM_operator_name_call_ptr /blender/source/blender/windowmanager/intern/wm_event_system.cc:1721 - 20 0x3a26b95 in WM_operator_name_call_ptr_with_depends_on_cursor /blender/source/blender/windowmanager/intern/wm_event_system.cc:1914 - 21 0x9de572c in ui_apply_but_funcs_after /blender/source/blender/editors/interface/interface_handlers.cc:1017 - 22 0x9e77561 in ui_handler_region_menu /blender/source/blender/editors/interface/interface_handlers.cc:11418 - 23 0x3a1c67b in wm_handler_ui_call /blender/source/blender/windowmanager/intern/wm_event_system.cc:791 - 24 0x3a357c8 in wm_handlers_do_intern /blender/source/blender/windowmanager/intern/wm_event_system.cc:3244 - 25 0x3a368f2 in wm_handlers_do /blender/source/blender/windowmanager/intern/wm_event_system.cc:3361 - 26 0x3a3faee in wm_event_do_handlers /blender/source/blender/windowmanager/intern/wm_event_system.cc:3954 - 27 0x39fac44 in WM_main /blender/source/blender/windowmanager/intern/wm.c:640 - 28 0x7cc0c6 in main /blender/source/creator/creator.c:585 - 29 0x7fac0ec2950f in __libc_start_call_main (/lib64/libc.so.6+0x2950f) - 30 0x7fac0ec295c8 in __libc_start_main_impl (/lib64/libc.so.6+0x295c8) - 31 0x7cb454 in _start (/build_linux_debug/bin/blender+0x7cb454) 0x602000144aa0 is located 4 bytes to the right of 12-byte region [0x602000144a90,0x602000144a9c) allocated by thread T0 here: - 0 0x7fac16aba097 in calloc (/lib64/libasan.so.8+0xba097) - 1 0x1c4374e3 in MEM_lockfree_callocN /blender/intern/guardedalloc/intern/mallocn_lockfree_impl.c:208 - 2 0x55c6183 in bNodeSocketValueBoolean* MEM_cnew<bNodeSocketValueBoolean>(char const*) /blender/intern/guardedalloc/MEM_guardedalloc.h:302 - 3 0x55bb943 in node_socket_init_default_value /blender/source/blender/nodes/intern/node_socket.cc:316 - 4 0xffd68d in node_socket_set_typeinfo /blender/source/blender/blenkernel/intern/node.cc:1213 - 5 0x1001212 in make_socket /blender/source/blender/blenkernel/intern/node.cc:1549 - 6 0x1002461 in nodeAddSocket /blender/source/blender/blenkernel/intern/node.cc:1704 - 7 0x1002bae in nodeAddStaticSocket /blender/source/blender/blenkernel/intern/node.cc:1925 - 8 0x55d3cd4 in blender::nodes::decl::Bool::build(bNodeTree&, bNode&) const /blender/source/blender/nodes/intern/node_socket_declarations.cc:272 - 9 0x55b9437 in refresh_socket_list /blender/source/blender/nodes/intern/node_socket.cc:196 - 10 0x55ba901 in refresh_node /blender/source/blender/nodes/intern/node_socket.cc:252 - 11 0x55bad56 in node_verify_sockets /blender/source/blender/nodes/intern/node_socket.cc:265 - 12 0xffbab4 in node_add_sockets_from_type /blender/source/blender/blenkernel/intern/node.cc:1079 - 13 0xffc708 in node_init /blender/source/blender/blenkernel/intern/node.cc:1131 - 14 0xffd3d9 in node_set_typeinfo /blender/source/blender/blenkernel/intern/node.cc:1191 - 15 0x1007074 in nodeAddNode /blender/source/blender/blenkernel/intern/node.cc:2217 - 16 0x1007679 in nodeAddStaticNode /blender/source/blender/blenkernel/intern/node.cc:2246 - 17 0x3cfd30d in version_geometry_nodes_primitive_uv_maps /blender/source/blender/blenloader/intern/versioning_300.cc:862 - 18 0x3d388c9 in blo_do_versions_300 /blender/source/blender/blenloader/intern/versioning_300.cc:3822 - 19 0x3bb5da7 in do_versions /blender/source/blender/blenloader/intern/readfile.cc:3539 - 20 0x3bbaf29 in blo_read_file_internal /blender/source/blender/blenloader/intern/readfile.cc:3873 - 21 0x3db1c8f in BLO_read_from_file /blender/source/blender/blenloader/intern/readblenentry.cc:400 - 22 0xbed6eb3 in BKE_blendfile_read /blender/source/blender/blenkernel/intern/blendfile.c:502 - 23 0x3a623ef in WM_file_read /blender/source/blender/windowmanager/intern/wm_files.c:963 - 24 0x3a6ebad in wm_file_read_opwrap /blender/source/blender/windowmanager/intern/wm_files.c:2594 - 25 0x3a6fbaf in wm_open_mainfile__open /blender/source/blender/windowmanager/intern/wm_files.c:2716 - 26 0x3a6ef26 in operator_state_dispatch /blender/source/blender/windowmanager/intern/wm_files.c:2630 - 27 0x3a6fe0d in wm_open_mainfile_dispatch /blender/source/blender/windowmanager/intern/wm_files.c:2740 - 28 0x3a6f1e6 in wm_open_mainfile__discard_changes /blender/source/blender/windowmanager/intern/wm_files.c:2669 - 29 0x3a6ef26 in operator_state_dispatch /blender/source/blender/windowmanager/intern/wm_files.c:2630 SUMMARY: AddressSanitizer: heap-buffer-overflow (/lib64/libasan.so.8+0x49d20) in __interceptor_memcpy Shadow bytes around the buggy address: 0x0c0480020900: fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa 0x0c0480020910: fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa 0x0c0480020920: fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa 0x0c0480020930: fa fa fa fa fa fa fa fa fa fa fa fa fa fa 00 04 0x0c0480020940: fa fa fa fa fa fa fa fa fa fa 00 00 fa fa 00 04 =>0x0c0480020950: fa fa 00 04[fa]fa 00 04 fa fa 00 04 fa fa 00 00 0x0c0480020960: fa fa 00 00 fa fa 00 04 fa fa 00 00 fa fa 00 00 0x0c0480020970: fa fa 00 00 fa fa 00 04 fa fa 00 04 fa fa 00 04 0x0c0480020980: fa fa 00 00 fa fa 00 00 fa fa 00 00 fa fa 00 04 0x0c0480020990: fa fa 00 00 fa fa fd fd fa fa fd fd fa fa 00 04 0x0c04800209a0: fa fa 00 00 fa fa 00 00 fa fa 00 04 fa fa 00 00 Shadow byte legend (one shadow byte represents 8 application bytes): Addressable: 00 Partially addressable: 01 02 03 04 05 06 07 Heap left redzone: fa Freed heap region: fd Stack left redzone: f1 Stack mid redzone: f2 Stack right redzone: f3 Stack after return: f5 Stack use after scope: f8 Global redzone: f9 Global init order: f6 Poisoned by user: f7 Container overflow: fc Array cookie: ac Intra object redzone: bb ASan internal: fe Left alloca redzone: ca Right alloca redzone: cb ==1805984==ABORTING ```
This issue was referenced by 2fb829a2de
This issue was referenced by 2fb829a2deb809af6589a2eec19c16fdf4718de6
Member
Added subscribers: @HooglyBoogly, @JacquesLucke, @CharlieJolly
Member
Caused by d397ecae32 which added a new socket, so version_geometry_nodes_primitive_uv_maps was getting the wrong socket with ->next
Possible fix incoming...
CC @CharlieJolly
CC @HooglyBoogly
CC @JacquesLucke
Caused by d397ecae32 which added a new socket, so `version_geometry_nodes_primitive_uv_maps` was getting the wrong socket with `->next` Possible fix incoming... CC @CharlieJolly CC @HooglyBoogly CC @JacquesLucke
Philipp Oeser changed title from Segmentation Fault opening a file to Regression : crash opening file with uv from GN primitive 2023-01-13 13:07:44 +01:00
Added subscriber: @mod_moder
Seems more like a versioning issue... But not sure
Member
Philipp Oeser self-assigned this 2023-01-13 15:00:37 +01:00
5 Participants
Reference: blender/blender#103837
