UV Editor, Manipulator disappears if AABB of selection has zero area. #103868
Reference: blender/blender#103868
Operating system: Windows 10 Home
Graphics card: GTX 1660Ti
3.4.1
In the uv editor, when choosing the transformation tool, if you select the mode of edges or vertices, under normal conditions a white manipulator should appear with which you can manipulate the selected edges or vertices. example on screenshot 1.
However, when selecting a part of edges or several vertices, the manipulator does not appear as it should, but a white bar appears that does not allow moving edges or several vertices.
I think this is a bug, the manipulator should work the same in all selections.
Added subscriber: @Ghostil
Added subscribers: @Chris_Blackbourn, @PratikPB2123
Hi, thanks for the report. I'm not sure how exactly you're expecting a gizmo to be displayed in 2nd case.
Can you elaborate it?
The following patch will "Fix" the issue, but I'm kinda terrified to check it in:
I guess that means this is technically "Confirmed in Debugger" ???!
Can someone with a bit more familiarity with the transform gizmo take a look?
(the
ggd->cage->matrix_offset
is degenerate)Changed status from 'Needs User Info' to: 'Confirmed'
UV Editor Bugto UV Editor, Manipulator disappears if AABB of selection has zero area.This issue was referenced by
6c8db7c22b
