Geometry Nodes Mesh Boolean unexpected difference result #103952
Reference: blender/blender#103952
Operating system: macOS-13.1-arm64-arm-64bit 64 Bits
Graphics card: Apple M1 Apple 4.1 Metal - 83
Broken: version: 3.5.0 Alpha, branch: master, commit date: 2023-01-16 22:58, hash:
7241ab6ede
Worked: none
Geometry Nodes Mesh Boolean Difference does not work as expected.
Node setup:
Unexpected boolean difference:
At certain positions of Cube.001 some of the small cubes will disappear when they should not.
Thanks!
test06.blend
Added subscriber: @fuvesib
Added subscriber: @MiroHorvath
Even though disappearing is annoying, it's a bit daring to expect getting correct result when faces of both meshes are perfectly lined up in Y axis(check in Top view).
To get a correct result you have to scale Cube.001 in Y axis(in case this is the result you're expecting).
Sorry for the confusion, I did indeed forget to scale Cube.001 in the Y axis slightly bigger.
However, I did not mean the cubes circled with green, which could be explained by floating point uncertainty and which is expected when the faces are close to each other. But the cube circled with red which is way further to be explained with a floating point error in my opinion.
It is possible to get a similar result when Cube.001 is scaled bigger on the Y axis than the small cubes.
Blend file for the above picture:
test08.blend
@fuvesib I see, this is quite annoying, Boolean documentation says:
... so it should give you proper result(while changing Cube.001 transformation) as both meshes are Manifold.
Exactly because of getting these kind of issues when working with Boolean, I typically separate all the meshes within one object by Loose Parts(P-key in Edit mode) and then assign GN modifier to each newly created objects to minimize problems, it's indeed automated with Python API.
Thank you for the suggestions.
I found this issue when a complex node setup started crashing with 3.4. I was able to reduce the problem to the Boolean node.
The crash issue has been solved (#103072) however, the flickering remained.
Although this is quite a niche issue compared to the crash, I think it would be nice to have it solved sometime in the future. So I opened this new report for this incorrect difference issue.
