Ray Visibility (glossy, diffuse, transmission) on light sources generate a different result when using hit by the BSDF or next-event estimation #103977
Reference: blender/blender#103977
Operating system:
Graphics card:
Broken: (example: 2.80,
edbf15d3c0
, master, 2018-11-28, as found on the splash screen)Worked: (newest version of Blender that worked as expected)
When changing/disabling the ray visibilities on a light source (glossy, diffuse, or transmission), the result becomes
inconsistent when using only BSDF sampling, next-event estimation, or MIS between both.
The reason for that is that the contribution of a light source is completely neglected when the type of the BSDF closure used for sampling the direction is disabled on the light source.
During next-event estimation, on the other hand, the light source ALWAYS contributes. Only the BSDF evaluation components multiplied with the light contribution differ [ eg. instead: Lglossy + Ldiffuse -> L*diffuse if glossy is deactivated].
The example shows a scene with one big rectangular light at the ceiling, where glossy rays are disabled on.
As you can see, the BSDF image is darker compared to MIS, and the NEE version is a little bit brighter.
The MIS image is more or less a blended version of BSDF and NEE.
Because both BSDF and NEE do not converge to the same result, the MIS one is inconsistent/biased.
Since the blending factors/mis weights depend on the sampling strategies, the result changes when using path guiding or the light tree.
This makes these optimized strategies unpredictable and can confuse the artists.
In the worst case, they report bugs on for the light tree and path guiding.
A WIP fix is proposed in D16965
Added subscriber: @sherholz
Added subscribers: @LukasStockner, @Christophe-Hery, @brecht, @Stefan_Werner
Changed status from 'Needs Triage' to: 'Needs Developer To Reproduce'
Hi @sherholz, it'd be really nice if you fill out
steps to reproduce
field from the bug report template.On first run through the code, the changes make sense to me.
There are always complications and subtleties stemming from multi-lobe MIS and LPEs (here ray visibility flags).
Sebastian Herholz referenced this issue2023-05-08 17:53:23 +02:00
