2D Fill issue with intersecting curves #104241
Open
opened 2023-01-30 22:43:17 +01:00 by Hoang Duy Tran · 6 comments
Member
Operating system: macOS-10.15.7-x86_64-i386-64bit 64 Bits
Graphics card: Intel(R) Iris(TM) Plus Graphics 645 Intel Inc. 4.1 INTEL-14.7.8
Broken: version: 3.5.0 Alpha, branch: master, commit date: 2023-01-29 00:10, hash: 042775ad48
Suspicious error happens when two curve circles are intersected in 2D, with Fill Mode set to others than None (Back, Front, Both)
  • Add two curve circles
  • Move one of them so they are partly intersected
  • Select them both and 'Ctrl+J' to join them together
  • In Properties, Curve panel, select 2D, Geometry -> Extrude 0.35m, Fill Mode->Back/Front/Both
You will see uncertain fills with errors in fillings, not sure what logic the filling is trying to do, especially in corners.
**System Information** Operating system: macOS-10.15.7-x86_64-i386-64bit 64 Bits Graphics card: Intel(R) Iris(TM) Plus Graphics 645 Intel Inc. 4.1 INTEL-14.7.8 **Blender Version** Broken: version: 3.5.0 Alpha, branch: master, commit date: 2023-01-29 00:10, hash: `042775ad48` **Short description of error** Suspicious error happens when two curve circles are intersected in 2D, with Fill Mode set to others than None (Back, Front, Both) **Exact steps for others to reproduce the error** - Add two curve circles - Move one of them so they are partly intersected - Select them both and 'Ctrl+J' to join them together - In Properties, Curve panel, select 2D, Geometry -> Extrude 0.35m, Fill Mode->Back/Front/Both You will see uncertain fills with errors in fillings, not sure what logic the filling is trying to do, especially in corners. ![Screenshot 2023-01-30 at 21.41.55.png](https://archive.blender.org/developer/F14215394/Screenshot_2023-01-30_at_21.41.55.png) ![Screenshot 2023-01-30 at 21.34.58.png](https://archive.blender.org/developer/F14215366/Screenshot_2023-01-30_at_21.34.58.png)
Author
Member
Added subscriber: @hoanguk
Member
Member
Pratik Borhade changed title from Curve - 2D Fill Mode error to 2D Fill issue with intersecting curves 2023-01-31 03:44:25 +01:00
The scanfill algorithm implementation used here is notoriously bad at overlapping geometry.
If you need to get the work done you can try to use the Fill Curve geometry node instead.
The scanfill algorithm implementation used here is notoriously bad at overlapping geometry. If you need to get the work done you can try to use the `Fill Curve` geometry node instead.
Added subscriber: @mano-wii
Solving this, I believe it would solve #42071 (Fonts with self-intersections not displayed correctly) as well.
Philipp Oeser removed the
label 2023-02-09 15:27:03 +01:00
Reference: blender/blender#104241
