Sequencer Preview doesn't update properly #21378
5 Participants
Reference: blender/blender#21378
%%%Sequencer preview doesn't update properly if transform strip keys are moved around in Dope Sheet.
To recreate:
Make a transform strip in sequencer, animate position/scale, and move those keys to another place in Dope Sheet.
The sequencer preview image won't update properly when you go around the current frame (by dragging the green line with the mouse, or also Alt A). It will flicker between the old and new position/scale.
If you go to after the very last frame, and back again, there's a chance that it behaves normal again (but not always).
In the sample file, I used a non-animated wipe effect instead of an image, because I couldn't pack a sequencer image into the file ( https://projects.blender.org/tracker/index.php?func=detail&aid=21377&group_id=9&atid=498 ). However, with an image the effect seems to be even worse than with the wipe.
Doing the same in the F-Curve Editor makes no problems.
2.51 svn 27163
Win XP SP 3
AMD Turion 64 MT-30 1,6 GHz processor
1 GB RAM
Nvidia GeForce Go 6200
On xubuntu (another PC, not mine) it updates properly after you release and click again with the mouse. %%%
%%%There is a refresh button for this very purpose.%%%
%%%Haven't seen it, it's true. But I tried working with it, and it's quite annoying, to click down there after every little change. If it works with F-Curves without hitting the refresh button, why can't it work for DopeSheet? %%%
%%%Hrm. While I can't say beyond a shadow of a doubt the reasoning, it isn't difficult to see the performance hit.
Imagine grabbing 100 fcurve points and dragging slightly... now you wait stuck while all of the various updates happen.
It is not productive nor condusive to an industry grade set of manipulations. What works for simple work likely doesn't work for complex work, which Blender is typically aimed at.
It could very well be that there is a broken update auyomatically toggle somewhere, but the default response is valid. %%%
%%%This is a bug, since it works in the graph editor but not the dopesheet. Both have a Realtime Update in the View menu. There's an easy way to fix this but it also would be slow when transforming many channels at once (calling DAG_id_flush_update hundreds of times is very slow in more complex scenes), will try to think of a good solution.%%%
%%%Anna: brecht committed better dependency handling, maybe this works now? I tried the file, but nothing shows strange here.%%%
%%%The bug is that it doesn't update when you move keyframes in the dopesheet, that still happens here. I'm not sure what the right fix is, probably it should loop over all f-curves involved and call their update functions, so attach a patch that does this. Not sure this will work in all cases, so assigning to Joshua to get his opinion.%%%
%%%A possible solution to the performance hog could be to have an asynchronous process (I.e. a thread) execute the latest order. Possible pseudocode could be:
global image current_preview;
global fcurves current = null;
global fcurves next = null;
global Mutex mutex;
void thread_fn()
void on_update(new_fcurve_params)
%%%Sorry for the messy code. I don't know how the markup works on this site (standard HTML?).%%%
%%%I will move this to wiki as future todo. Adding hacks in our code to circumvent this are only going to work against us.
There are also many work arounds available:
A proper fix will really be to improve our timing system in general, which is a large project.
Wiki todo link:
http://wiki.blender.org/index.php/Dev:2.5/Source/Development/Todo/Editors#Video_Sequencer%%%
