Mirror Modifier and Particle System do not Work Properly #25838
Reference: blender/blender#25838
%%%Hi again guys, this time I think i've actually got a real bug that doesn't seem to be recorded =). If this has already been posted just shout at me and I'll promise i'll never bug (no pun intended) you guys with my non-existant/duplicated bugs again =P =).
Alrighty, reproducing:
With the particle system after the mirror modifier in the modifier stack, the particles are only emitted from the mirrored side. But if they are in the opposite order the particles are emitted from the "real" side (this bit works as expected).
I've attached a .blend file to quickly illustrate the problem. To use it just open it, Hit Alt+A and mess around with the order/visibility of the modifiers.
Thanks
Matt%%%
%%%Well... strictly speaking it's not a bug :P, but it's a good issue to bring up as it definitely belongs to the todo-list.
Particles and constructive modifiers don't really mix well together as particles are emitted from the mesh surface using the mesh's non-modified structure. Subsurf works because there is quite a bit of special handling behind the scenes so that particles can work for example with different view and render subsurf levels. Subsurf is also special in the sense that you can always calculate which original face a subdivided face belongs to, no matter how many subdivisions there are. For the mirror modifier all the faces are duplicated so there is no way to map the faces one to one.
Of course some special cases could be added for some modifiers, but then again this becomes more and more complicated when you stack different modifiers before particles. I'll add this to the todo-list in http://wiki.blender.org/index.php/Dev:2.5/Source/Development/Todo/Tools#Particles.2FHair so that a proper way to handle this can be designed at some point. Until then you'll just have to do without particles and the mirror modifier together.%%%
Added subscriber: @JuB
Removed subscriber: @JuB
