Crash on Shift-D to duplicate image node in compositer. #26031
Closed
opened 2011-02-11 10:33:29 +01:00 by Christopher Barrett · 10 comments
%%%Something has changed in the compositor since rev 33780 that causes Blender to crash with the latest builds, or 2.56a Official, when you load an image sequence into an image node and shift-D to duplicate it. This causes an immediate crash! This worked fine with 33780.
I'm on Windows using 64 bit Blender.%%%
%%%Something has changed in the compositor since rev 33780 that causes Blender to crash with the latest builds, or 2.56a Official, when you load an image sequence into an image node and shift-D to duplicate it. This causes an immediate crash! This worked fine with 33780. I'm on Windows using 64 bit Blender.%%%
%%%ubuntu 10.10 rev 34776
I just duplicate an image node with sequence of .png.
No crash, here.%%%
%%%ubuntu 10.10 rev 34776 I just duplicate an image node with sequence of .png. No crash, here.%%%
Member
%%%Duplicating goes fine here too, latest svn.
  • Create a simple anim with frames 0001.png etc in /tmp/ and add a .blend here that crashes for you consistently.
  • There's always a small chance your build didn't go OK. Rebuild clean is a good test
  • Or maybe the svn you checked had this bug, and got fixed in the meantime..
  • Trying someone else's build also is a good advice, check graphical?
  • And of course, don't apply patches! We can only verify bugs for svn trunk.%%%
%%%Duplicating goes fine here too, latest svn. - Create a simple anim with frames 0001.png etc in /tmp/ and add a .blend here that crashes for you consistently. - There's always a small chance your build didn't go OK. Rebuild clean is a good test - Or maybe the svn you checked had this bug, and got fixed in the meantime.. - Trying someone else's build also is a good advice, check graphical? - And of course, don't apply patches! We can only verify bugs for svn trunk.%%%
I'm getting reports on my tutorial site that others are having the same problem with 2.56a.
I downloaded one build off of Graphicall that also had the same problem.
I just downloaded "Blender 2.56 Trunk SVN r344630 Windows x64" built by Stargeizer and it worked fine. I think that's a typo on Graphicall, it's 34630.
If you guys know this problem has been solved go ahead and close it out, but it is there on the 2.56a official release from the Blender website, and on at least one current build on Graphicall.
I'll attach a simple example that crashes 2.56a%%%
%%% I'm getting reports on my tutorial site that others are having the same problem with 2.56a. I downloaded one build off of Graphicall that also had the same problem. I just downloaded "Blender 2.56 Trunk SVN r344630 Windows x64" built by Stargeizer and it worked fine. I think that's a typo on Graphicall, it's 34630. If you guys know this problem has been solved go ahead and close it out, but it is there on the 2.56a official release from the Blender website, and on at least one current build on Graphicall. I'll attach a simple example that crashes 2.56a%%%
%%%Well, I can't get the file to attach here. I go to the Attachments tab, enter the file with the Browse button, click on save changes, but I get an error about missing parameters. I'm not sure if your file uploading system is functioning properly.%%%
Member
%%%If you press "Save changes" while having Attachment tabs visible it should work...
When it still fails mail me a file, up to 5 MB gets accepted: ton at blender org%%%
%%%If you press "Save changes" while having Attachment tabs visible it should work... When it still fails mail me a file, up to 5 MB gets accepted: ton at blender org%%%
Member
%%%BTW: the "missing parameters" error also happens when this websites decides to log you off... happens too often for me too :)%%%
Member
%%%Cleaning tracker... if you have a blend file post here or mail me, i'll check it!%%%
Member
%%%Possibly, I'll show my crash this Monday. But that was when I tried to Shift+D two connected nodes (and not Image... that was Mix and Blur). Probably that was related to some unsuitable usage of a script (but I'm not sure). I tried to "insert" 3d Pix script as Addon (I didn't got the difference then) and after this all Addon section became "clear" (empty).%%%
Reference: blender/blender#26031
