Sequencer strips ignore drivers on rendering (works in playback) #26560
7 Participants
Reference: blender/blender#26560
Duplicates: #27788
%%%play animation on provided file. see how the color is driven by the cube's zloc
now render an animation. see how animation is stuck in one color
cheers%%%
%%%Clarification of the problem:
When the file is loaded, scrubbing the timeline shows the color strip's color being affected by the driver (the strip in the sequncer, the property, and the sequencer preview all show the color changing).
Once the scene is rendered (animation render), the strip adopts a color (it looks like the one that was active when the rendering started) and won't change again until the file is reloaded. By "won't change again", I mean that although the strip display in the sequencer and the property still change, the sequencer preview (and the rendered clip) both show only a single color (vs color changing in response to the driver).
Attempted fixes I've tried:
Since it seems that the animation system side is functioning fine (properties update ok), I suspect it might have something to do with some imbuf locking tricks that sequencer uses when it thinks something won't change. Leaving for a sequencer guru to hack...%%%
%%%when you clear cache after rendering the preview starts working again%%%
%%%by clearing the cache I mean hit the Refresh Sequencer button%%%
%%%Maybe Peter can help!%%%
%%%Ive attached SequencerDriversRand.blend. In it Ive modified the driver to print a random value every time it runs, and guess what, it never stops printing right after opening the blend file!%%%
%%%After a quick debugging session we came to the conclusion that the sequencer does not do scene updates before rendering, probably because it was assumed that scene properties have no influence on the sequencer outcome, but not taking drivers into account. I found this little piece of code excluded in sequencer.c: seq_render_strip_stack, which was apparently meant to do just that, but disabled:
if 0 /* commentind since this breaks keyframing, since it resets the value on draw */
endif
Looking at how regular rendering handles scene updates, i tried to make a quick patch using the scene_update_for_newframe function (attached), but since i'm not familiar with rendering or sequencer code, i have no idea if this is a proper fix.
The constant driver updates in the most basic system call are creepy, is this really intended? Potentially dangerous too i guess ...%%%
%%%The main problem is the sequencer preview renderer and the fact that the sequencer can contain it's owner scene as a strip.
The piece of code Lukas found is problematic (and #iffed out) because if the animation system is evaluated when the preview render runs it becomes impossible to keyframe pretty much anything as an update call (and thus a redraw of sequencer preview) is issued immediately when a value is changed. This update then resets any user changed value.
There could of course be exceptions to make preview and actual rendering do different things, but I'd much rather see the whole preview rendering implemented properly with the job system (this is already on the todo list). However not to make things too simple using the job system for preview rendering will currently face the same kinds of problems as normal rendering with sharing the scene data between rendering and ui threads (with the added complication that users will change values that effect the preview rendering pretty much constantly while the sequencer is rendering the preview).
The nice random value example Daniel found is most probably due to the preview rendering being called from the ui drawing update call.. basically anything that sends a redraw call will also start a sequencer preview rendering. After the first render this will be very quick as the images are just read from the sequencer cache, but it's still a full preview rendering each time none the less.
So basically this is a todo item (with a solution that relates quite a bit to how normal preview rendering will be brought back), but I'd love to hear Peter's opinion on all this too before closing the report.%%%
%%%There're already several bugs related on how preview system works in tracker. It's indeed need to be re-thinked. There was already a note in our todo list which referenced to 4 different bugs. Added another one link there http://wiki.blender.org/index.php/Dev:2.5/Source/Development/Todo/Tools#Sequence_Editor
So wouldn't consider this is really a bug, just thing which needs major improvements. Thanks for the report, but will close it now.%%%
%%%I just hit this issue in 2.67a - I tried to use drivers in the sequencer and they behave lazy. They update rarely, and randomly. The values don't change while I play the sequence back in Blender almost at all.%%%
