Bake to image used for rendering glitch (bake feedback loop) #27120
Reference: blender/blender#27120
%%%I have noticed these three troubles and these appear randomly... Artifact it's lack of alpha support in bake and also irregular fill of 'black'. I have tested in trunk r36281 on Windows 7 (polish language). All details are in .mov and .blend files (after unpack .zip).%%%
%%%I use this method for generating UV Margin after I finished painting texture.%%%
%%%Ups... My mistake... It support alpha. I have forgotten to enabled it correct in material settings... But artifacts still appear sometimes...%%%
%%%assigning to myself.%%%
%%%The problem is you're baking onto the same image you're using to render with so you get a feedback loop during the bake.
The fix here would be to duplicate the image buffer for baking or not allow this to happen at all and give an error.
Leave this open for now.%%%
%%%I prefer 'duplicate the image buffer for baking', because IMHO it's bad design (It's frustrating, and not artist friendly...): creating new UV Texture slot and new bitmap file JUST FOR simply adding UV Margins on texture which has finished editing, which it just need last touch - adding UV Margins...%%%
%%%ubuntu 11.04 64bits Rev 40164
Alpha seems correctly supported,here.
You have to enable Use Alpha option in Image Sampling Panel in Texture Properties.
But another artifact came from your modeling. Overlapping faces for the ear is not a good choice.
You can use Two-sided Option in Texture Face Panel in Mesh Properties.
And you must detach ear from rest of the head to avoid white artefact.%%%
%%%It's a bit complicated to detect if image should be duplicated or not and the only working way would be to detect feedback loops during baking and duplicated images if loop was found and then somehow images should be merged back. Detecting loop is simple enough but that image duplication is a really tricky thing and make code tangled and difficult to support. Discussed this with Brecht and he've got the same thinking.
Attaching patch which prevents baking to image used for rendering, want Brecht to glance at it before commiting.
Think if you're using such configuration for adding margin only it'll be more useful to have margin filter in image editor.%%%
%%%Commited to revision r43554. It might be improved, but for now it's the only way which fits design.
Thanks for the report, closing it now.%%%
