SEGFAULT: Regression in free_imbuf_seq #28601
Closed
opened 2011-09-09 22:57:07 +02:00 by Troy Sobotka · 8 comments
%%%Loaded an older file and tried to change scenes and a segfault happens.
Can't share the dot blend. Apologies.
Program received signal SIGSEGV, Segmentation fault.
0x0000000000e628c6 in free_imbuf_seq (scene=0x7fffe15ab228, seqbase=0x8,
  check_mem_usage=0, keep_file_handles=1)
  at /home/aphorism/Source/blender/source/blender/blenkernel/intern/sequencer.c:2776
2776 for(seq= seqbase->first; seq; seq= seq->next) {
(gdb) bt
0 0x0000000000e628c6 in free_imbuf_seq (scene=0x7fffe15ab228, seqbase=0x8,
1 0x00000000014a4bf7 in rna_Sequence_update (UNUSED_bmain=0x7fffe111aeb8,
  scene=0x7fffe15ab228, ptr=0x7fffe14895d8)
  at /home/aphorism/Source/blender/source/blender/makesrna/intern/rna_sequencer.c:566
2 0x00000000013e9b00 in RNA_property_update_cache_flush (
  bmain=0x7fffe111aeb8, scene=0x7fffe15ab228)
  at /home/aphorism/Source/blender/source/blender/makesrna/intern/rna_access.c:1491
3 0x0000000000d5d09e in BKE_animsys_evaluate_animdata (scene=0x7fffe15ab228,
  id=0x7fffe15a2d88, adt=0x7fffe15a33a8, ctime=1142, recalc=2)
  at /home/aphorism/Source/blender/source/blender/blenkernel/intern/anim_sys.c:2216
4 0x0000000000d5daff in BKE_animsys_evaluate_all_animation (
  main=0x7fffe111aeb8, scene=0x7fffe15ab228, ctime=1142)
  at /home/aphorism/Source/blender/source/blender/blenkernel/intern/anim_sys.c:2334
5 0x0000000000e50717 in scene_update_for_newframe (bmain=0x7fffe111aeb8,
- Type <return> to continue, or q <return> to quit---
  sce=0x7fffe15ab228, lay=1)
  at /home/aphorism/Source/blender/source/blender/blenkernel/intern/scene.c:1029
6 0x0000000000b85803 in ED_update_for_newframe (bmain=0x7fffe111aeb8,
  scene=0x7fffe15ab228, screen=0x7fffe158f6b8, UNUSED_mute=1)
  at /home/aphorism/Source/blender/source/blender/editors/screen/screen_edit.c:1816
7 0x0000000000b84cce in ED_screen_set_scene (C=0x217e388,
  at /home/aphorism/Source/blender/source/blender/editors/screen/screen_edit.c:1490
8 0x00000000008b7a01 in wm_event_do_notifiers (C=0x217e388)
  at /home/aphorism/Source/blender/source/blender/windowmanager/intern/wm_event_system.c:226
9 0x00000000008b5583 in WM_main (C=0x217e388)
  at /home/aphorism/Source/blender/source/blender/windowmanager/intern/wm.c:383
10 0x00000000008b4b0f in main (argc=1, argv=0x7fffffffe248)
  at /home/aphorism/Source/blender/source/creator/creator.c:1283
%%%Loaded an older file and tried to change scenes and a segfault happens. Can't share the dot blend. Apologies. Program received signal SIGSEGV, Segmentation fault. 0x0000000000e628c6 in free_imbuf_seq (scene=0x7fffe15ab228, seqbase=0x8, ``` check_mem_usage=0, keep_file_handles=1) at /home/aphorism/Source/blender/source/blender/blenkernel/intern/sequencer.c:2776 ``` 2776 for(seq= seqbase->first; seq; seq= seq->next) { (gdb) bt # 0 0x0000000000e628c6 in free_imbuf_seq (scene=0x7fffe15ab228, seqbase=0x8, ``` check_mem_usage=0, keep_file_handles=1) at /home/aphorism/Source/blender/source/blender/blenkernel/intern/sequencer.c:2776 ``` # 1 0x00000000014a4bf7 in rna_Sequence_update (UNUSED_bmain=0x7fffe111aeb8, ``` scene=0x7fffe15ab228, ptr=0x7fffe14895d8) at /home/aphorism/Source/blender/source/blender/makesrna/intern/rna_sequencer.c:566 ``` # 2 0x00000000013e9b00 in RNA_property_update_cache_flush ( ``` bmain=0x7fffe111aeb8, scene=0x7fffe15ab228) at /home/aphorism/Source/blender/source/blender/makesrna/intern/rna_access.c:1491 ``` # 3 0x0000000000d5d09e in BKE_animsys_evaluate_animdata (scene=0x7fffe15ab228, ``` id=0x7fffe15a2d88, adt=0x7fffe15a33a8, ctime=1142, recalc=2) at /home/aphorism/Source/blender/source/blender/blenkernel/intern/anim_sys.c:2216 ``` # 4 0x0000000000d5daff in BKE_animsys_evaluate_all_animation ( ``` main=0x7fffe111aeb8, scene=0x7fffe15ab228, ctime=1142) at /home/aphorism/Source/blender/source/blender/blenkernel/intern/anim_sys.c:2334 ``` # 5 0x0000000000e50717 in scene_update_for_newframe (bmain=0x7fffe111aeb8, - Type <return> to continue, or q <return> to quit--- ``` sce=0x7fffe15ab228, lay=1) at /home/aphorism/Source/blender/source/blender/blenkernel/intern/scene.c:1029 ``` # 6 0x0000000000b85803 in ED_update_for_newframe (bmain=0x7fffe111aeb8, ``` scene=0x7fffe15ab228, screen=0x7fffe158f6b8, UNUSED_mute=1) at /home/aphorism/Source/blender/source/blender/editors/screen/screen_edit.c:1816 ``` # 7 0x0000000000b84cce in ED_screen_set_scene (C=0x217e388, ``` scene=0x7fffe15ab228) at /home/aphorism/Source/blender/source/blender/editors/screen/screen_edit.c:1490 ``` # 8 0x00000000008b7a01 in wm_event_do_notifiers (C=0x217e388) ``` at /home/aphorism/Source/blender/source/blender/windowmanager/intern/wm_event_system.c:226 ``` # 9 0x00000000008b5583 in WM_main (C=0x217e388) ``` at /home/aphorism/Source/blender/source/blender/windowmanager/intern/wm.c:383 ``` # 10 0x00000000008b4b0f in main (argc=1, argv=0x7fffffffe248) ``` at /home/aphorism/Source/blender/source/creator/creator.c:1283 ``` %%%
Author
Author
%%%Attaching dot blend without files.%%%
Author
%%%Linux amd64 (Ubuntu 11.04) r40046%%%
%%%Actually, it's NULL-pointer dereference in rna_Sequence_update caused by RNA cache. Not sure why this cache is needed and how it should work, assigning to Joshua.%%%
Member
%%%Sergey: These caches are in place to make sure that RNA updates can get called by animsys without slowing things down massively by having a few update callbacks get called thousands of times to perform some update operation requiring only some shared common ancestor (i.e. properties of several modifier properties getting updated, when really, only the ID-block will get used by one RNA update callback).
In this case, I think adding some simple null checks for no editing data is sufficient...%%%
%%%Sergey: These caches are in place to make sure that RNA updates can get called by animsys without slowing things down massively by having a few update callbacks get called thousands of times to perform some update operation requiring only some shared common ancestor (i.e. properties of several modifier properties getting updated, when really, only the ID-block will get used by one RNA update callback). In this case, I think adding some simple null checks for no editing data is sufficient...%%%
%%%I was thinking about checks for NULL but wasn't sure it was correct fix. If you think it's correct i can add them. But how can we be sure there'll be no crashes in other update functions =\ Maybe cache can store scene to which it belongs to?%%%
%%%Joshua, i've commited that null-check. Hope you're ok with this.
Troy, should work fine in rev40648. Thanks for the report, closing.%%%
%%%Joshua, i've commited that null-check. Hope you're ok with this. Troy, should work fine in rev40648. Thanks for the report, closing.%%%
Reference: blender/blender#28601
