Dupli-Particles are rendered on wrong layer #29028
Closed
opened 2011-10-25 18:59:45 +02:00 by Tobias Oelgarte · 7 comments
%%%I add some objects to layer 2 and put them into a group. On layer 1 i added a mesh with a particle system. It is in Dupli-Mode which renders duplicates of the group instead of the particles. But curiously the "particle-objects" aren't rendered on layer 1 but instead on the same layer as the original objects. This is in this case layer 2.
I appended an example file. It contains the same situation as described. As you render the first time you should see nothing. If you switch to render layer 2 (inside layer mask and 3d-view), then you will see them together with the original objects.
I assume that the dupli-particles should be rendered on layer 1 while the originals are hidden on layer 2.%%%
%%%I add some objects to layer 2 and put them into a group. On layer 1 i added a mesh with a particle system. It is in Dupli-Mode which renders duplicates of the group instead of the particles. But curiously the "particle-objects" aren't rendered on layer 1 but instead on the same layer as the original objects. This is in this case layer 2. I appended an example file. It contains the same situation as described. As you render the first time you should see nothing. If you switch to render layer 2 (inside layer mask and 3d-view), then you will see them together with the original objects. I assume that the dupli-particles should be rendered on layer 1 while the originals are hidden on layer 2.%%%
Member
%%%Your description of what you'd expect to happen is exactly correct. The problem with the attached blend is that layer 2 (layer with the objects to be duplicated) is disabled in the render layers, so it's not considered in any way during render time (not even for duplication). You can still hide the objects from actually rendering by not showing the layer as a "visible layer" (buttons under the "Scene:" lable), but you need to have the layer selected as "render layer" (buttons under the "Layer:" lable).
Closing the report.%%%
%%%Your description of what you'd expect to happen is exactly correct. The problem with the attached blend is that layer 2 (layer with the objects to be duplicated) is disabled in the render layers, so it's not considered in any way during render time (not even for duplication). You can still hide the objects from actually rendering by not showing the layer as a "visible layer" (buttons under the "Scene:" lable), but you need to have the layer selected as "render layer" (buttons under the "Layer:" lable). Closing the report.%%%
%%%This isn't quite true. If i enable the speed pass (vector pass), then it is not rendered, even if i follow this description.%%%
Member
%%%Ok now there is an actual bug!
Reopening report. Will investigate further after the Blender Conference.%%%
%%%Ok now there is an actual bug! Reopening report. Will investigate further after the Blender Conference.%%%
%%%To clarify my previous comment, based on the settings of the appended example.
If i enable both scene layers and limit the render layer to layer one, then anything is rendered as expected. But as soon as i enable the vector/speed pass, the particles won't show up. They are instead rendered, together with the speed pass, at the second layer, which is or should be excluded.%%%
%%%To clarify my previous comment, based on the settings of the appended example. If i enable both scene layers and limit the render layer to layer one, then anything is rendered as expected. But as soon as i enable the vector/speed pass, the particles won't show up. They are instead rendered, together with the speed pass, at the second layer, which is or should be excluded.%%%
%%%Fix in svn for the speed vectors, thanks for the report.%%%
Reference: blender/blender#29028
