Crashy .blend: Nasty Multires + Subsurf combo #29366
Reference: blender/blender#29366
%%%Attached example .blend that crashes on render (internal), just open and F12.
I've tried to replicate in a fresh mesh, since this happened on an old .blend I started working on again, but couldn't redo, the only way was appending this faulty object to a new .blend, still crashes there.
I know editing a multires mesh + having subsurf is very nasty, but the result I was achieving was quite cool :) at least could not crash.
Tried in very latest trunk, and in official 2.60.
Simple backtrace from my non-debug build:
http://www.pasteall.org/26670
%%%Noticed that if you:
Apply the Multires Modifier, crashes.
Apply first Multires, then Subsurf, also crashes.
Apply first Subsurf modifier, then Multires, it doesn't crash.
:D%%%
%%%Developer's note:
It's something wrong with DerivedMesh for which tanget layer is adding: some vertices has got NaN coordinates. Not sure if it's multires itself which produces such coordinated (didn't see anything bad with coordinates/data in multiresModifier_disp_run), but NaN appears in ccgDM_copyFinalVertArray.%%%
%%%Forgot to mention, there's fiew edges in that mesh which aren't connected to any faces. If this edges are deleted before rendering, there's no crash.%%%
%%%Made further investigation. NaN vertes appears in DerivedMesh after running ccgSubSurf_stitchFaces() from multiresModifier_disp_run(), so suppose problem is how this function works for meshes with edges not shared with any faces.
It's a bit tricky code to start tweaking without working on it before. Brecht, maybe it's simple for you now to fix this issue? Thanks.%%%
%%%Fix in svn, thanks for the report.%%%
%%%great catch! thank you both for research and fix, cheers! :D%%%
