bpy.data.curves.new(name= "test" , type = 'SURFACE') does not create a surface #29369
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
2 Participants
Reference: blender/blender-addons#29369
%%%import bpy
create a nurb-surface with function class bpy.types.BlendDataCurves.new()
surf = bpy.data.curves.new(name= "test" , type = 'SURFACE')
code for splines and control-points
obj = bpy.data.objects.new("test_obj", surf)
bpy.context.scene.objects.link(obj)
create a surface with primitive function to compare the results.
bpy.ops.surface.primitive_nurbs_surface_curve_add()
%%%It's failure of code which tries to guess object type from Curve datablock. It's needed in cases when you're changing object datablock.
Probably it can be improved so it wouldn't change object's type when it's not obvious which type to use and when both of Curve and Surface types can be used.
Will look into this issue.%%%
%%%thanks, Sergey for the quick response.%%%
%%%Fixed in svn rev42126. Thanks for the report, closing it now.%%%
