Context copy bug when cycles is chosen as render engine #30505
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
Reference: blender/blender-addons#30505
%%%Hello,
when i try to copy a button context when cycles is chosen as render engine, following error happens:
AttributeError: 'Context' object has no attribute 'texture_slot'
To reproduce, run script in provided blend and click on object panel. A new subpanel "MyPanel" should appear
Choose Cycles as render engine and click on "Copy Context. Now the above error should pop up.
Tested under Ubuntu 11.10 64 bits, blender rev 44682.
Specs:
CPU: I7 2600
GPU: Geforce GTX 580
RAM: 16 GB%%%
%%%Brecht was working on this report. Assigning to him to prevent doing duplicated work/
Brecht, if you wouldn't manage to find reason of this issue feel free to assign to me :)%%%
%%%Cycles doesn't support texture slots, is that it? Shouldn't run as error maybe.....%%%
%%%Fix in svn, thanks for the report. This is a pretty strange corner case, not sure why you would copy the context or if that would even be reliable for reuse later, but doesn't give error now.%%%
