dict(prop) crashes if prop is a PropertyGroup with nested PropertyGroup #30906
Closed
opened 2012-04-11 09:51:34 +02:00 by Julien Rivaud · 3 comments
%%%Open the attached blend file. It is factory defaults apart from a script defining a trivial operator with PropertyGroup nesting
Executing the operator SEGFAULTs
Note that the line "self.item.item.value = 1" is needed to trigger the bug, if the nested propertygroup is unchanged then the operator prints {} as expected.
Steps to reproduce:
run the script%%%
%%%Open the attached blend file. It is factory defaults apart from a script defining a trivial operator with PropertyGroup nesting Executing the operator SEGFAULTs Note that the line "self.item.item.value = 1" is needed to trigger the bug, if the nested propertygroup is unchanged then the operator prints {} as expected. Steps to reproduce: run the script%%%
Author
%%%fixed r45534.%%%
%%%fixed r45534.%%%
2 Participants
Reference: blender/blender-addons#30906
