Properties cant have Spaces in names when using interval as a evaluation. Or else it'll fail to activate actuator. #31122
Reference: blender/blender#31122
Category: Logic
%%%If a property contains spaces in it's name, then the connected actuator won't activate.
I have to rename the property by removing spaces from its name, then I update all the logic bricks to match the new name. And then it works just fine.
But once I rename it again (adding spaces back in) then update the logic bricks to the new name, it stops working.
This only happens with the Property sensor that uses "interval" as a evaluation. All the rest of the evaluation types can use all properties (no matter what the name is)
The Blend file explains in more detail, and contains different layers that show a comparison.
Thanks%%%
%%%whoops, uploaded the wrong blend
"Properties cant have Spaces in names when using interval 2.blend" is the correct blend file that shows the issue%%%
%%%Confirmed. The code here is quite silly, it generates an expression string and then evaluates it, but doesn't seem to prevent spaces (or +, - and other operators) from messing things up.%%%
%%%Moved from Blender 2.6 Bug Tracker to Game Engine%%%
%%%This should now be fixed as of r48662. Let me know if you still have problems. In the mean time, I'm going to close this report as "Fixed."%%%
