Collada: meshes without faces raise an out of index exception #31320
Reference: blender/blender#31320
%%%I attached 2 files:
test_primitive_mesh_circle.dae (created by blender)
circle_from_sketchup.dae (created by sketchup)
Both files can not be imported into blender.
The reason seems to be that the data contains no faces.
proof: as soon as i add a face, the object imports to blender.
I have seen this error in revision 46309 (but it's been around since at least bledner 2.62)
AnimationImporter.cpp: line 807 (Index out of bounds) (revision:46309)
A closer look at the differences between the 2 collada files also shows that sketchup uses a
datablock to specify the edges. While Blender only specifies the vertices.
I guess, the correct way for Blender to handle this is to also export and to recognize as input.%%%
%%%Gaia, maybe you might look into this? Or re-assign to somebody else from collada team. Thanks :)%%%
%%%Indeed, lines-geometry isn't supported yet :)%%%
%%%I have the exporter part ready. I am still struggling with the importer part.
I have attached a patch. Maybe this patch can even be committed already
as "work in progress" because it already adds some improvement ?
Current state of exporter:
Seems to work for static meshes.
I tested the exported dae files (simple static meshes with some lose edges) with Blender 2.49. There they import with no problems.
Current state of importer:
It does recognize the LINES tag but it currently does not yet import the edges.
I get a couple of errors during import. The model imports but of course
the edges do not yet show up because i dont read
the LINES section.
I am still trying to understand how to fill the edges in :)
Maybe some hints about how the code actually works would be helpful.
Is it correct that loose edges have no normals ?
Then i know how to get rid of the first warning.
Tips and hints are very welcome! But please let me try to finish this work
before you step in :)
thanks,
Gaia%%%
%%%So, here is the import export patch for loose edges.
I tested it with static meshes. Please review
and comment. and or check it in if appropriate.
Thanks to everyboy who helped me to get it done :)%%%
%%%Nathan networy has pointed me to a problem with Mingw64 and Collada Export.
In fact any Collada export crashes at the same Collada function;:
prepareToAppendValues()
This function is called from several places in the Exporter and every call crashes
when Blender is compiled with Mingw64. I only can verify that mingw64 builds crash,
while builds with visual c++ 2008 express work with no problems.
So i need some help to pinpoint the cause of this problem.
To reproduce the crash:
Now Blender crashes
Any help is appreciated.
%%%oups, excuse me Nathan for misspelling your name.%%%
%%%Fixed in svn r46691%%%
%%%When you fix a bug Gaia, please close the report. :) %%%
