DopeSheet GreasePencil Mode Window won't scroll up #31476
Reference: blender/blender#31476
%%%Minor bug, 2.63a (not new)
If you have a rig with lots of bones keyed and you scroll down in the dope sheet window - action editor mode, then you switch to Grease Pencil mode, you can't get to your grease pencil keys because scroll up doesn't work, i.e. the dopesheet window is stuck in the last vertical position it was in when switching from action editor view. You can't move the scroll select on the R side of the window.
To get around this you can either hit Home key or go back to action editor view and scroll to top of that window and then switch modes.
In case the file is too big to upload, here is a link example:
https://docs.google.com/open?id=0B5_Z2GiKjL5IOHFvQ0lneDNmZVE%%%
%%%Tested the provided file in Blender 2.63a for Windows x64 and can not find the problem described. Grabbing the scroll bar, using the scroll wheel over the name-space, or using the scroll wheel while holding shift on the graph-space all scroll up in Grease Pencil mode. You can test this by scrolling to the bottom in action editor, switching to Grease Pencil and scroll up, then return to the action editor to check results.
It looks like nothing is happening due to the lack of visual feedback in this case. It is odd that the DopeSheet modes share the scroll location though, I can see where that becomes confusing.%%%
%%%The problem I was referring to is related to my habit of using the scroll bar at the right of the dope sheet window to scroll up. THAT scroll doesn't work, however, scrolling in the left panel works fine as you pointed out.%%%
%%%I just re-tested it using your provided .blend again. Using that scroll, grab and pull to the top of your screen 4-5 times, and you will find that it is in fact scrolling up.
It's working, it's just not working as you are expecting it to. That changes the nature of the problem, I suspect, to a feature request.%%%
%%%fixed r50938.%%%
