Texturepainting: Mipmap Levels aren't updated #31539
Reference: blender/blender#31539
%%%If i draw on a mesh and zoom out i get graphic errors. The reason is that Mipmaps of the texture I'm painting on aren't updated. They still show the texture as it was before painting. (r46796, Nvidia Geforce 7600, Ubuntu 10.10)
It worked fine in previous versions (one week ago or so).%%%
%%%I can not reproduce the issue here neither with nvidia card nor with intel one. Also code seems to be handling mipmaps properly in texture painting.
Is it still issue for you? If so having sample file where the issue is 100% reproducible would help a bunch.%%%
%%%I posted this bug a longer time ago. But i will see if i can still reproduce it. If so, then i will attach an example file or let you know that i can't reproduce it anymore. %%%
%%%Still happens in r50551. All i need to do is the following to reproduce the error:
I appended a screenshot to show the issue (I guess that there is no need for a file). I painted all over the cube, but only see the result at lowest mipmap level.
Additionally i happens (only for the first time) that the brush circle in the UV/Image Editor is missing after i leave the texture-paint mode (going to object mode) while paint mode in UV/Image Editor is active.%%%
%%%Developer note:
Issue seems to be caused by rev43462, where call of GPU_paint_update_image was changed to always do partial image update.This works fine for texture painting from 3d viewport because mipmaps are disabling for such painting. In other cases it seems to be tricky to distinguish whether mipmaps are enabled for object or not.
Could see couple of possible ways:
Antony, that was originally your change, what do you think about best way of solving the issue?%%%
%%%I can't reproduce the issue here predictably with the steps you have outlined (Actually I only managed it once).
I have found a similar issue where -undoing- between object and texture mode would invalidate the gpu texture image state (because GPU textures do not get recalculated properly on undo since they do not belong in the Scene but on a separate static GPU state struct).
On this issue: Usually texture verification (happens on mesh display) catches the zeroed IMA_MIPMAP_COMPLETE flag and calculates the mipmaps anyway.
Which is exactly the reason GPU_free_image, line 892 works: On verification the image will be reloaded.
Can you really always reproduce the issue with these steps? An exact way to reproduce would help me decide better on this.
My vote would be not to disable partial update, but more on this once I get a fully reproducable bug. %%%
%%%I can always reproduce this steps. I tested it on a Geforce 7600 under Ubuntu 10.10 and a GTX 560 TI under Ubuntu 12.04. Both show the same result. The only requirement is that you leave the texture paint mode and then start to paint on the texture in the UV/Image editor. If i do so then i can see that the highest resolution (close to view) is updated, while the lower resolution mipmaps are not.%%%
%%%OK, I got it reproduced but only with generated images. Investigating...%%%
%%%50730 should do it, closing. Please poke if still buggy. Also, can you please file a separate report about the brush bug if it's still valid?%%%
