(iTaSC) Assertion failure in jntarray.cpp on Linux (2) #31544
2 Participants
Reference: blender/blender#31544
Relates to: #31430
%%%I'm resubmitting this as a bug related to #31430 because I don't see a way to reopen my own bug report...
The attached patch to #31430 (which was committed according to the comments) does not fix the described problem - it fixes a similar issue which causes a premature crash for my reduced testcase.
NDEBUG would migrate it - but I'm currently developing with debug builds and it's becoming rather annoying... so - I tracked down the actual bug in iTaSC itself:
If the last added segment is a None joint (no DoF) q_nr will reference a non-existing element in the joint array - TreeFkSolverPos_recursive::recursiveFk will reference that non-existing joint:
... and pass the value to KDL::Segment::pose() which will then ignore the passed value in case of a None joint.
Note that my original comment was wrong - there is no actual memory access happening... but if you hope to some day get rid of the iTaSC crashes (there are quite some - also with NDEBUG builds) you need to be able to run it with assertions enabled...
I'm not going to talk about iTaSC's very questionable API passing pointers to possibly never-referenced values (or maybe more than 1, depending on the joint type) as references to the first element here... this results in some (IMHO) very fragile code in Blender's itasc_plugin.cpp with all the DoF counting...
I'm not sure how this should be fixed properly... the iTaSC API really should be repaired, but you could work around the issue by always having an additional dummy value in the joint array at the end... That is, unless you accept that iTaSC must never be used with assertions enabled?
I suppose one should possibly report an upstream bug for this but I have no idea how the relation between Blender and the iTaSC project is, so I'll wait for some feedback on this report.
In case you consider this to be a non-issue - sorry for the noise...
%%%Thanks for the report. I fixed the bug in revision 47438. Note that your test case is a very special one: the armature has no joint at all since all 3 axis are locked.
Regarding the strange way of passing pointer, I totally agree with your comment. The reason I did this is because this part of iTaSC is in fact a separate library called KDL that didn't support nDoF joints. Adding proper support for nDoF joints in KDL would have required a significant redesign of the library, which was not in the scope of my project. I left this to the maintainers of the library, but never got to the bottom of it. I don't even know if it was ever fixed in the original library.
Nevertheless, the trick I'm using in iTaSC is safe provided that the joint exist, which is now guarantee by the patch.
