Cases where verts and edges are selected but not relevant faces #31715
Reference: blender/blender#31715
%%%-Windows 7 - 64bit
Tested,
There are times where a face is not selected whilst the surrounding vertices are.
In one instance there are the loop cut tool doing this with cuts greater than 1.
Another instance is when I presume after certain conditions whereas using L key to select linked will only sect the vertices and edges (0 faces are selected). It appears to consistently happen after an undo.
I am not sure it happens only after an undo but this is the time I can reproduce it.
%%%Verifying loop cut, will work if going from vertex to edge mode then to face, but not directly from vertex to edge (same if starting in edge mode and attempt to go straight to edge mode.
Unable to verify second part as the instructions seem to have an error in the order or a missing step.
Can't use select linked (default ctrl+L) after deselecting everything (no selection for linked definition)%%%
%%%About the second part, selecting linked there is using (L) on its own while hovering over the vertice/edge, ctrl key is not involved.%%%
%%%Ok, verified, seems to work if in face selection mode, other modes fail as you say.%%%
%%%Fixed in r47733%%%
