Select All By Layer seems not to work. #31752
2 Participants
Reference: blender/blender#31752
%%%I am using Blender 2.63 SVN Rev 47595 Debug Build on a Fedora 16 Linux box.
I noticed that the 3D View Editor Header > Select > Select All By Layer command seems not
to work.
See attached blend file also attached my system-info.txt file.
It has 3 cube objects in the scene.
The 1st cube is on Scene Layer 1, the other 2 cubes are on both Scene Layers 1 and 2.
If I then use the Select All By Layer command and tell it to select objects on layer 1
only the 1st cube gets selected, the other 2 cubes which are also on layer 1, will not.
If I change the Active Scene Layer so that one layer 2 is active and then do the
Select All By Layer command again but this time setting the Layer value to 2 in the
Operator Panel, cube 2 and 3 do not get selected.%%%
%%%Not actually a bug -- just it used to check for exact match which ended up with non-selected objects which you expect in this case.
Fixed by adding extra option to operator to say whether you want exact match or select objects which shares specified layer in svn rev47613.
Thanks for the report, closing.%%%
