Cycles materials cannot be manipulated using drivers #31834
Reference: blender/blender#31834
Duplicates: #31834
%%%Hello,
it is possible to add a driver to cycles materials, but when trying to use the driver it doesn't work, it doesn't change any value.
When you turn on the debug info the "Value" in the variable field isn't even changed at all, even if you for example move the connected bone while using transform channel.
I don't know if this is a bug, or by design, but if this would be by design, why would the UI allow me to even add a driver?
Attatched is a file demonstrating the problem.
If you move the bone up the global z axis the Fac value in the monkey's material should change, but it doesn't.
If this is an already know issue, I apologize, I couldn't find much about it.
Thank you!
MD%%%
%%%Brecht, can you please look into this? Probably that's just a limitation you already aware of.%%%
%%%Joshua, do you know if and how this is supposed to work? I can't find any place in the code where drivers for materials or their node trees are evaluated, only for scenes and objects.%%%
%%%Closed duplicate http://projects.blender.org/tracker/index.php?func=detail&aid=31834&group_id=9&atid=498%%%
%%%Brecht: indeed there was never any code for this. I was under the impression that there was some code in place for recalculating the drivers, just that this wasn't able to get called for whatever reason.
I've applied a fix for this in svn (r.48515). It seems to fix the problems, but further testing is still required to see if it has any really nasty performance penalty.%%%
