OBJ Importer corrupts a model (crash in edit mode) #31835
Reference: blender/blender#31835
%%%Hi guys!
Obj importer corrupts a model. According to the issue here: http://projects.blender.org/tracker/?func=detail&atid=498&aid=31679&group_id=9
Obj model and blender model: http://dl.dropbox.com/u/26887202/blender/rat.zip
In blender file, just get in edit mode and switch to Faces and there will be CRASH.
Linux 64 bit, Blender revision 47774 64 bit.
LOG (with importing the obj):
mifth@mifth-3d:~/Documents/blender$ ./blender
./blender: /usr/lib/x86_64-linux-gnu/libtiff.so.4: no version information available (required by ./blender)
connect failed: No such file or directory
ndof: spacenavd not found
found bundled python: /home/mifth/Documents/blender/2.63/python
ImportError: cannot import name urandom
search for unknown operator 'BRUSH_OT_sculpt_tool_set', 'BRUSH_OT_sculpt_tool_set'
FRS_set_context: context 0x0x58b5748 scene 0x0x5e55648
importing obj '/home/mifth/Desktop/123/rat/rat/r.obj'
0.0180 sec
0.0013 sec
finished importing: b'/home/mifth/Desktop/123/rat/rat/r.obj' in 0.0329 sec.
BMESH_ASSERT failed: /home/i7deb64/blender-2.5-svn/work/freestyle/source/blender/bmesh/intern/bmesh_core.c, bmesh_elem_check(), 462 at 'err == 0'
check_element failure, with code 32 on line 134 in file
bmesh error: infinite loop in disk cycle!
check_element failure, with code 4194304 on line 330 in file
check_element failure, with code 32 on line 616 in file
check_element failure, with code 32 on line 636 in file
check_element failure, with code 4194304 on line 647 in file
%%%confirmed. importer did the mesh validation before calculating edges. should be the other way around. will post patch next.%%%
%%%attaching two patches:
now the importer produces a valid mesh.
there is still something wrong with either the input OBJ or the importer (in the example rat obj file mesh validation removes a face and looking at the detection of sharp edges we have one sharp edge that the importer assumes to consist of two identical verts...) but that's for later maybe. at least it outputs a valid mesh now.%%%
%%%Well, i'd wouldn't say fix seems correct for me. If mesh is not being validated before calculating edges, then that code might easily crash because of some buggy topology. If mesh is valid before mesh.update() and not valid after mesh.update() then there's a bug in this mesh.update() function and that should be fixed instead of moving validation after updating mesh.%%%
%%%Hey Sergey!
Thanx for reviewing,
have only seen your comment now. I've talked to Campbell and he was fine with this so I've actually commited this :S
Doo you want me to revert?%%%
%%%OK, reverted for now%%%
%%%Sergey:
I'll be looking into mesh.update() to see if I can spot a bug there but dont know if this is over my head...
What if we validate before AND after mesh.update()? This will be slower, true, be at least we can be sure to import valid meshes this way. We can mark as TODO and see if we can fix mesh.update() afterwards? I know this is not ideal but it might be a compromise to get rid of a CRASHER. Let me know what you think...%%%
%%%Well, validate before and after would solve the issue, but that's in fact short term solution. I'll look into the issue of mesh.update and let you look into funnier reports :)%%%
%%%Fixed in svn rev48364. Thanks for the report and patches tho, closing now :)%%%
