Loop Selection on wireframe selects vertex behind #31900
Reference: blender/blender#31900
%%%Hi,
When in wireframe, or solid view with "Limited Selection to Visible" enabled, when selecting a loop via Alt + RMB, if we do it close to a vertex in the background, it will select it as well.
It happens in the simplest of cases, attached is an image of how it looks, and a blend file where you can reproduce this:
Thanks for your time.%%%
%%%Indeed… Probably because loop-select works on edges, while “normal” select works on vertices?
Will have a look at that.%%%
%%%Confirmed it also happens when in with edges during Edge select and faces on Face select.
Thanks!%%%
%%%Eeeep, I believe I might have introduced this error. I'll investigate tomorrow.
Here's my commit information:
Fixes [#31577] Select N-th vertex/face/edge doesnt work
http://projects.blender.org/tracker/index.php?func=detail&aid=31577&group_id=9&atid=498
Also solves both TODOs in the commented code.
Loop select now calls mouse_mesh() to handle setting an active vertex/edge/face.
Modified Paths:
Modified: trunk/blender/source/blender/editors/mesh/editmesh_select.c
+++ trunk/blender/source/blender/editors/mesh/editmesh_select.c 2012-06-20 07:31:19 UTC (rev 48105)
@@ -1044,6 +1044,7 @@
// if (EM_texFaceCheck())
+#if 0
@@ -1058,6 +1059,8 @@
* belongs to the selected edge could be set to
* active here in face select mode */
+#endif
%%%Yep, was just investigating this, can confirm commenting out this mouse_mesh() call fixes the problem! :p%%%
%%%Fixed in svn48272!
Thanks for reporting. :)%%%
%%%Thank you both Nicholas and Bastien! :D
/me does the compile dance%%%
