"Make Segment" on path-curves gives wrong result #31909
Reference: blender/blender#31909
%%%"Make Segment" (shortcut F) will give a new segment which appears "linear" (propably has a problem at assigning "knotsu" while making up the new spline)
I've attached two examples demonstrating this. Just open up the blend and hit "F".
This will only happen when "joining" two seperate splines (nu1 and nu2 in the code). It will succes if you do it on start and endpoint of a single spline (aka make cyclic).
The resulting wrong segment will be recalculated/corrected once it is
(1) subdivided
(2) upping the "order U" in Properties Editor > Curve Data > Active Spline, (followed by lowering it again to return to original curve-order).
I've had a go at this myself and attached a patch that of solves this by calling BKE_nurb_knot_calc_u() afterwards. While there is propably a more elegant solution (by "fixing" the loop in the code - I added a comment in the patch) I think this is still better than outputting a somewhat wrong result...%%%
%%%Really strange no one ever noted that before… I’m quite sure it’s here for a fair amount of time!
Now I’m not much aware of NURBS, so I don’t understand what happens here. But from a quick glance at the code (BKE’s curve.c, makeknots() and calcknots()), I just find knots creation is not "simple", and can vary quite depending on flags (e.g. Bezier flag seems to change knots step…). So I highly doubt we can have a simple copy working in all cases! More over, calling BKE_nurb_knot_calc_u() does not seems much performance-critical to me (it ultimately summarizes to a single loop), imho it would be much simpler and safer to just always call it!
Btw, BKE's makeknots() creates its knots array with
MEM_callocN(4 + sizeof(float) * KNOTSU(nu), "makeknots");
Where from hell do those +4 come from???
%%%On the one hand cyclic shouldn't be an issue here -- here joining knots happens for two different acyclic nurbs. But on the other hand this nurbs could contain knots calculated for different order number. Would need a closer look here.%%%
%%%In fact, calculating knots seems to be easiest way until we'll support manual knots editing.
Fixed in svn rev48234. Thanks for the report, closing it now.%%%
